A German customer brought this to my attention and just want to share the info with you guys, while multi-pistons caliper upgrades are far superior in terms of performance and bling factor, not everyone budget allows them to spend $4k on brakes.
What you will need is E60 M5 rotors, calipers (incld carriers), the biggest upside of this set up is you can buy spare parts from your BMW dealers, and you can potentially do this whole swap for well under $1500.
The hardest part is to modify the carriers, I believe there are some running custom carriers on the front, but according to the lad, the rear requires minimum modification to make it fit.
Here are some photos he sent me
and some he show me from other E39 owner that has done the swap in Germany with machined carriers.
the downside is you have to run minimum of 18" wheels, while 19"s is a much safer bet.
Hiya Chigga,
Now this looks very very interesting to me ! running 19 inch wheels already so I'd be good on that side of things. Is there some knowledge on what the modifications are required to make this fit and possible to do? I could then perhaps approach some of the specialists I know here to have the work done. Is the machined carriers that you've shown here available from the German contact?
Cheers, Dennis! West London UK!
Super legit
Are the E60 brakes that much better than E39 M5 brakes?
PRICE CUT on ALL FABRICS
^Probably not. But I dont think anything will be able to beat what chigga is running on his 5 right now. What were the ones ur running 8 piston, or something like that lol?
A good mod with factory parts...can't beat that
12 pistons front, 6 rear, I'm just sharing the ideas with fellow board members, as lot of people want to run nice big brakes, but spending at least $4k on brakes just isn't possible.
E60 calipers use twin pistons up front vs single on E39, I believe the piston area is also larger so more brake force can be applied, not to mention they are ginormous in comparison, they are 374mm in diameter (my car is 388mm front), the downside is unsprung weight increase.
Hey Dennis, from what I've been told, you need to bore the centre bores out, and the carrier brackets either needed to be machined or made from scratch, the dust plates also need to be trimmed, but the rear hand brake shouldn't need any modification.
Hmm, i'm waiting for somebody to retrofit the 6 piston calipers from the 135i/335i Preformance package.
There is a guy on bimmerboard who did this mod to his E38 quite a while ago. I'll try to find a link!
Google rescue!
http://public.fotki.com/pkortun/our-...brake-upgrade/
Are stock brakes inadequate? I've never seen a BMW on the street with poor brakes.
My stock brakes are bomb proof. They're quiet and they work beautifully every time. Obviously I maintain them well but I sure as hell wouldn't spend $1500-$4000 on brakes..... unless I already upgraded the entire suspension and had a supercharger ready to go in.
I agree with most of you fellas that our hard earned money could be better spent else where... !
Agree, if I track and have lots of money then maybe.... but I presume the majority of us are not going to spend 20-60% of the cars value on a big brake job. Especially when the stock brakes are pretty darn good already.
It's a forum, people toss out their ideas and opinions.... nobody flamed Chigga for the info. Info is good. Reality checks are also.
Say it with me: First supercharger, then brakes.
Resident Third World Country Advisor
Neither of which are necessarily a sign of inadequate brakes.
Did you actually measure the run out on the rotors, or did you simply "feel" the pulsing in the pedal when you warped the brakes? Most times the rotors are not actually warped, but just have pad deposition...and either some good firm stops will clean them up, or have them lightly scrubbed with a scotchbrite pad.
The cracking on drilled rotors is a known problem as well, and can sometimes be attributed to non-factory drilled rotors, or just inherent in the design, and something to watch out for. I have not had an issue personally with drilled rotors.
2001 540 M-Sport (cdn), ST X (KW) coilovers, H&R 15mm spacers, Eibach anti roll bars (28mm/18mm), Beastpower rear antiroll bar brackets, M5 rear chassis reinforcements (traction rods), Strong Strut front upper strut bar, Dinan Stage 1 software, factory M-Audio subs, Bavsound speaker upgrade, Bluebus bluetooth integration, Stop Tech SS brake lines, ATE coated brake rotors, ATE ceramic brake pads.
I don't see any plausible reason on purchasing slotted/drilled rotors for an OEM brake system (cooling factor?), especially for people who DD their car, I heard it isn't much different from blank ones, if so it is insignificant. But BBK is mandatory for powerful cars or regulars at the track. Otherwise stick with blanks, OEM brake system if you're a casual track person but do upgrade brake line to steel ones and brake fluid to blue racing fluid.
+1
Had the same experience with "thought to be" warped rotors. Turn out to be caused by uneven brake pad deposition. If pad is slightly uneven, hard braking should clean that up. Severe brake damage require replacement.
