MAKE ME A OFFER ON THE CAR IN AS IS CONDITION AKA PERFECTLY FINE ASIDE FROM EXTERIOR
Buy this car is as is condition and swap everything over to your m3, sell the parts you took off your m3 and have a fully built 600whp beast at a bargain!!!
Up for sale is my 1998.5 M3 2 door
- Estoril on rare Mulberry interior
- Staggared LTW wheels
- Factory trunk spoiler (no 3rd brake light on the rear shelf)
- Rare illuminated front driver and passenger foot wells
- Electric non-heated vaders
- HK sound system
- Factory BMW alarm
- Full OBC
- VIN: WBSBG9336WEY79653
- 91,XXX miles on chassis
Here is a teaser video of the car. I’m waiting for the final video to be finished and as soon as it is I will post it up!
[ame]http://vimeo.com/17154024[/ame]
I bought this car stock from the second owner back in 2005. The car was prestine and maintained at the same dealer by both the 1st and 2nd owners with a extended warranty. I have all original service records from day one as well as all the spare original keys and the original window sticker. I put 6k miles on it, did some mods and sold the car to a guy in Phoenix. I ended up buying it back in late 2007 and it has since then undergone a transformation.
Ever since JT (got psi) let me drive his turbo E36 I was hooked and had to have it. So….
Everything below was done about 10k miles ago unless noted otherwise.
Engine – Assembled by JT (got psi).
Bottom:
- M50 block bored to 84.5mm
- Block grooved for copper o-rings
- CP 8.5:1 forged pistons
- Eagle forged connecting rods
- S50 crankshaft
- ARP main studs
- Everything replaced (oil pump, main/rod bearings/all tensioners/guides/chains etc)
Top:
- Ferrea competition 1mm+ intake/exhaust valves
- Ferrea springs/shims/retainers
- Mild porting of intake/exhaust ports done by my head guy
- Custom reground camshafts by Elgin Cams
- New OEM lifters installed during engine build
- ARP 2000 head studs
- Vanos seals/anti rattle done less than 1000 miles ago
The engine has solid compression/leakdown numbers and does not burn/consume any oil. The o-ringing of the block and installation of the stock HG was done less than 1,000 miles ago because the MLS let go. Coolant temps have been rock solid and no pressurization what so ever. The seal is perfect and car is dead reliable again. During the engine build it also got all new sensors (cam/crank/knock), new ignition coils, a new idle control valve and all new hoses etc.
Fuel System:
- 60lb/hr fuel injectors
- In-tank Bosch 040 pump with AN bulkhead fitting (no rubber hose)
- In-line Bosch 044 pump
- Custom -8 fuel rail that has a -6 feed on each side and a -6 return in the middle
- BMP adjustable fuel pressure regulator
- All stainless braided hose used with AN fittings for entire fuel system
- Both pumps independently wired directly to the battery with inline fuses and independent relays
- Billet in-line fuel filter with replaceable screen
Cooling:
- PWR 57mm radiator
- Stewart water pump
- Euro expansion tank with factory lines/hoses
- 16” Spal electric fan triggered by radiator temp sensor
- Custom aluminum fan shroud
- Ireland engineering oil filter cap
- BMP oil cooler
- Mocal oil cooler thermostat
- AN -10 stainless braided lines/fittings for oil cooler
Lubrication:
- Amsoil 15w50 racing oil changed every 2000-3000 miles with OEM filter
- AN -4 turbo oil feed line
- AN -10 turbo oil drain line to welded bung on the oil pan
- BMP oil distribution block for oil temp and pressure gauges
Exhaust:
- Custom schedule 10 stainless 6-1 tubular exhaust manifold. Manifold is designed so draw through can be run, down pipe tucks down and does not go over the valve cover, and so it can be removed and reinstalled in about 2 hours with engine in the car.
- 3” turbo back exhaust with Vibrant resonator and muffler
- Turbine housing, manifold, wastegate pipe and downpipe all ceramic coated
- Three v-band connections with Vibrant easy release v-band clamps
- Recirculated wastegate dump
- Welded fitting with check valve for crank case evacuation
- Extra o2 bung for dyno a/f hook up
Turbo system:
- Turbonetics T66 ball bearing/oil cooled turbo (CHRA just replaced)
- Tial 44mm wastegate
- Synapse blow off valve recirculated
- 31x12x3 intercooler with 3” inlet/outlet
- Silicone couplers and t-bolt clamps
Electronics/Tuning:
- Converted to OBDI
- TRM in-house tune using draw through 803 MAF and 93 octane fuel 604whp/510wtq. I belive it’s still the highest whp car that TRM has tuned.
- Blitz SBC ID III electronic boost controller
- Stri racing boost/vacuum, oil temp, oil pressure and water temp gauges
- PLX wideband air/fuel ratio system
- Gauges and boost controlled mounted in custom molded sun glass holder angled up towards driver. Boost/vacuum and air/fuel gauges mounted on top of the steering column using the ATI gauge pod holder.
Suspension/Steering/Drivertrain/Brakes:
- Ground control coilovers with dual-adjustable front shocks, rear top adjustable shocks
- Ground control front camber plates, and rear shock mounts
- UUC front/rear sway bars with spherical links
- UUC motor and transmission mounts
- UUC braided stainless brake and clutch lines
- Racing dynamics rear strut bar
- BMW x-brace
- Euro floating front rotors, brembo blank rears
- New OEM front control arms installed
- 225/45/17 Toyo T1r front tires, about 70% tread left. I have 2 extra new ones that come with the car.
- 15 mm spacers in the front
- 245/40/17 Toyo T1r rear tires, about 80% tread left.
Within the last 1500 miles the following was done/installed:
- E32 750 3.15 limited slip differential conversion with CES bracket
- E46 S54 6-speed transmission
- Shortened/rebuilt driveshaft by powertrain industries
- UUC evo3 Short shift kit with all shifter bushings replaced
- Rebuilt clutchnet LTW flywheel, pressure plate and 6-puck clutch
- New Z3 quick ratio steering rack with new OEM tie-rod assemblies/boots
- Front and rear calipers rebuilt and Porterfield R4S pads installed
- New front FAG hubs repacked with redline CV2 grease with new dust shields, dust caps and nuts.
- New rear FAG wheel bearings repacked with CV2 grease with new dust shields, dust
caps, snap rings and nuts.
- Rebuilt halfshafts repacked with CV2 grease and new inner/outer boots/clamps
- New bimmerworld HD upper/lower trailing arm ball joints
- New e-brake shoes, springs and hardware
- AKG aluminum subframe mounts
- AKG aluminum differential mounts
- AKG spherical trailing arm mounts
- Bimmerworld spherical inner/upper control arm mounts
- AKG spherical ajusteable rear camber arms
- AKG spherical front control arm mounts
- All suspension/steering bolts/hardware replaced with new
- Custom completely reinforced differential carrier (subframe, see pics)
- AKG swaybar tab reinforcements
- Bimmer world trailing arm pocket reinforcements
- AKG front subframe motor mount tab reinforcements
- Entire suspension/calipers/brackets and misc items powdercoated (35 pieces total)
- Completed 4 wheel alignment on a hunter rack at work.
Items done very recently:
- All fluids in the car were replaced about 1,000 miles ago. Amsoil racking brake fluid, amsoil syncromesh trans fluid, amsoil 75w110 diff fluid, bmw coolant, ATF power steering fluid.
- Cabin micro filter replaced
- Hood and trunk shocks replaced
- Windshield replaced
- Windshield cowl piece replaced
- Drivers window motor and regulator replaced (door panel got all new clips as well)
- BMW business CD43 head unit installed
- Battery is BRAND NEW (oem BMW)
- Bosch reman alternator just installed
- Fresh 30% tints just installed
- Front grilles, front bumper lip, bumper mouldings, and body side mouldings just got painted a satin black finish (tired of the faded grayish look you get after waxing). All installed with new clips.
- Front fog light covers painted estoril
- ZHP 6-speed shift knob installed
- Recovered Euro M-tech steering wheel installed (love this thing)
- Car just received a professional detail including polish/wax/sealant
See the fully documented build thread with many pictures to see this car come to life from scratch - http://forums.bimmerforums.com/forum....php?t=1216803
The exterior of the car is in near perfect condition. All original paint that has never seen a winter and just has the expected rock chips here and there. Interior is very clean as well. I’ve taken the seats out a few times to do theral cleaning of the carpet and seats.
There are only 3 issues with the car. The headliner is sagging a tad to the left of the sunroof panel. Sunroof could use some attention; the interior panel is loose and the sunroof binds when opening (tilt works fine.) I rarely use the sunroof so it has never bothered me much. The front speakers are crackling. THAT’S IT.
I have about 35k worth of PARTS receipts for this car (I have stacks of them in a folder.) Plus about 500-700 hours of my labor to get it to where its at. I simply put 93 octane in the car, lay down 600+whp, daily drive it to work, take it to the strip, and take it on long trips without hesitation. It’s really a joy to drive.
Best I’ve done at the drag strip was 11.8 at 135mph on bald street tires. Car should be good for mid 10sec with proper tires/driver. Trap speed is right where hpf stage 2.5 cars on race gas/meth are at! There was a 9 second hyabusa at the strip that was trapping the same speed as me.
It’s geared to 203.xx mph which I’ve never attempted but I’m sure the car would have no problem getting up there. I’ve hit around 180ish 1 time (for the video) and the car was still pulling HARD. Car felt stable and I had pure confidence in it. Wind noise was getting a bit loud though!
This car with the power it makes has been plenty fo fun to drive and I feel is at the ‘just right’ level. With the built/reinforced/solid suspension/drivertrain it has perfect traction in 3rd gear and 1st/2nd are suprisingly decent as well as the car does not build as much boost as quickly. If more power is what you desire the engine, fuel system, turbo, suspension/drivetrain can support quite a bit more. Would just need bigger injectors, and tuning.
This car has been a pure pleasure to build. It will be missed and I will not sell it to anyone I feel won’t appreciate it or take care of it properly. By no means am I desperate to sell, so if it stays in my garage, I won’t be bummed.
Asking price is $33,400
I have access to a tow vehicle and a trailer. I’m willing to deliver it to your door.
Luke
03 330i
bros sn
Luke
03 330i
wow. lots of effort in that build
very impressive car.
glws
Garrett
OMG thats a really nice car.
Amazing, just amazing. But why?
wow what a beautiful car, all i see is effort and passion put into it,
is the 200 mph verified LOL
Every time i am in or around this car i find myself smiling uncontrollably! This car is coming from a true enthusiast with a lot of talent. I can't wait to see the rest of the video Luke!
Absolutely gorgeous car! The cleanest E36 M3 turbo I have seen.
Cheif Senior Hitman Engineer 1st Class
BfcOT Mafia
seen it and heard it in person. probably one of the cleanest, meanest sounding, absolutely mint e36 M3's i've ever seen. GLWS Luke!!
maybe throw up the dyno sheet too
Good luck with the sale.
Whatever happened with the newer M5 trade? Any luck?
Doug
'97 M3/4
How do you get it to pass obd2 emissions testing?
Sick Sleeper!
Good-luck with the sale
I'm moving out the house and need the money.
I don't have the balls lol
Thanks Mike. And thanks for all the help with the build/tweaking.
Thanks Cat!
I wanted to get a fresh sheet for the thread but snow put a big stop to that
Here is the sheet from when it was tuned at TRM. Dips that you can see could never be felt but either way they should be cured with the vanos rebuild I did.
I sent him a email with no reply. I'm guessing he's no longer interested.
It's converted to OBD1 so it will not pass OBD2 emissions. TRM should have obd2 and 80lb injectors ready to rock and roll soon enough
Luke
03 330i
Beautiful car, best of luck with the sale!
Hey, that's my garage in that video!
I'd challenge anyone to find a finer example of an e36. I can't stress enough how clean this thing is!
Best of luck Luke!
Amazing car! I hope one day my car will be as nice as this one. I would definitelly rather drive this instead of any other car out there.
I'm speechless. Goodluck with the sale. Are you running spacers in the front?
fantastic car, hope you can get that price, it will do well for the whole f/i community here if you do.
so you have a euro 6-speed? did you look into the e46 m3 tranny swap?
it's a e46 m3 6-speed
Luke
03 330i
nice car!
just a heads up...... there is a remote control that looks like it is desperatly trying to get inside your motor. Just saying, you might want to keep an eye on that little fella.
Wow. Unbelievable work. Good luck with the sale. Worth every cent!!
That car is beautiful. I especially love all the reinforcements and the powder coating. GLWS!
