so recently fuse number seven on my 92 325i keeps blowing every time i turn off the car. its the fuse that controls the central locking system and, power windows, and interior lights. i first noticed this happening about 3 months ago and it seemed to be very random and sporadic. i thought that the problem was exposed wires in my head unit wiring harness so i cleaned that up but the problem still showed up every once in a blue moon. well Friday night it got to the point where i couldn't turn the car off without that fuse blowing. Ive checked the wiring by the trunk and that's fine no frayed wires or anything. so i was wondering if anyone else had any ideas as to what it could be??
thanks
Bump
bumpo
you got a short somewhere man. they are a nightmare to find sometimes.
Could be a short in the trunk lid wiring.
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
Trunk wires in the loom can crack. Open the trunk and pull back the rubber cover on the left side. Look for bare wires underneath! Read the write ups for more info.
im assuming you mean check the voltage at the battery? and which ground ? also the battery?
thanks
I just dealt with the same problem last night. Both fuses 7 and 35 were blown. I changed out #35 with no problems, but fuse #7 kept shorting.
After doing a little research on the forum, I found that the problem would most likely manifest itself in the truck wiring loom. With trepidation I peeled back the waterproofing around the wires and found all but two of the wires with exposed metal. There were two wire that had completely broke in two.
I rewrapped them with electrical tape, soldered and heatshrunk the broken ones and moved them to reduce the amount of wear when opening and closing the trunk. Now, the alarm works and the central locking works again!
PM me if you needE46Touringparts
are you reffering to the little bunching of wires near the driers side trunk hinge? if so ive peeled that open twice and never found any exposed wires
Dang. Somewhere the central locking is shorting. Best of luck finding it.
no not the battery..the wiring where that fuse is for.. check ur wiring how much voltage is thier and its ground see if ur geting 12volts on ur power supply and ur ground should be 0volts. u gotta re route the wiring.. it kan cause that.. kuz if ur geting ur fuse to blow all the time its because its short to ground meaning thiers another ground thats touching ur power to ur lights and its trigger it to blow
The wires can break inside the insulation. I had 5 broken wires on my sedan. Check them carefully because that is what the symptoms point to.
