So I figured I would just start a thread for this thing since I have a lot planned for it. Its a 94' two owner car that has a Dinan Stage II system on it.
Current to do list...
M3 Bumper - DONE
M3 Side Skirts - ON HOLD... Paint the steel?
OE M3 Side Strips - DONE
BMW Wind Deflector - DONE
New Rear Trailing Arm Bushings - HAVE THEM NEED INSTALLED
Fix Interior Trim - DONE
Replace Glove Box -
Smoked Turn Signals - DONE
Smoked Tails - DONE
Smoked Side Indicators - DONE
Smoked Fogs - DONE
Front License Plate Delete Trim - for sale...
MB Quartz speakers in stock locations w Alpine head unit and JL Audio 6 channel amp - DONE
10" Sub with JL mono amp - DONE
iPhone hardwired to Alpine unit - DONE
Paint lower rear bumper factory paint color to match - DONE
Lower the front suspension only more - HAVE SPRINGS NEED INSTALLED
Paint Wheels - COLOR? Black, Silver, Grey...
Replace Top - This will have to wait... I never put it up anyway!
New Floor Mats - DINAN ON THE WAY>>
New Headlights - What will fit with a Dinan intake? DEPO will NOT...
OK so here are some pictures of the car before most of the work started...
Shot at 2010-09-08
Shot at 2010-09-08
Shot at 2010-09-08
Shot at 2010-09-08
Shot at 2010-09-08
Shot at 2010-09-08
OK so here is some progress work...
JL Amps mounted in the trunk
Shot at 2010-09-27
Here are the trim pieces you need to be able to securly mount the factory windscreen mine as you can see were trash
Shot at 2010-09-27
New ones
Shot at 2010-09-27
My new to me BMW windscreen... this is a must have item for these cars you can run with the AC or Heat on in any weather with this thing.
Shot at 2010-09-27
A little bump for the trunk... Not much space on these cars so I built a custom box to fit in where the cubby/ski pass was located
Shot at 2010-09-27
iPhone connection done routed it under the center trim... not sure if I will keep it here or not.
Started replacing on the orange with smoked lenses
Shot at 2010-09-27
Replaced the front license plate holder with the cleaner trim one but now that I have found the DDM M3 bumper it will be up for sale soon...
Shot at 2010-09-27
I know it was a little thing but these were loose as some of the clips were broken so ordered new clips and here you go no more loose trim!
Shot at 2010-09-27
This drives me crazy, everyone else thinks I am crazy to care about it but I will have to replace this once I find a nice used one for a good price.
Shot at 2010-09-27
1994 325ic - 5spd - Dinan Stage II - CF Intake - Exhaust - Throttle Body - Software - Suspension - M Bumper and Door Trim - Smoked Lights
Cool, nice build!!!
I have the same problem with the glove box. It is not just the vinyl that is sagging, it is the entire plastic door. I can't find an old one that is not sagging so I am thinking about taking the heat gun to it and trying to bend it back into shape.
I will do it as soon as I get some free time, so you'll know if it worked or not. Right now I am busy fixing the popular driver's side floor leak
Let me know if that works I was thinking the same way...
OE M3 side trim will go on tomorrow! Skipping the DDM ones since everyone says that the fitment is poor. I am also thinking about skipping the DDM side skirts (again ppl say they are too long) and just sanding down the steel skirts and painting them to match... Anyone done this?
do a search on the side skirt paint removal. the rubber paint can be stripped away w/ the body color is underneath it...
and i'm very jealous of how clean your interior is...mine is worn from florida sun damage
95 alpine white 318iC - my 1st bimmer!!! now even better w/ dasc, tokico illuminas, h&r sport springs, new wheels, new top & hid...just a few of the sunk costs in this money pit!!!
88 civic w/ zc swap
97 lifted tj
and a few more project cars!!!
What is a Dinan stage 2? Is that a turbo or supercharger?
nice. 94 is great.
Only difference with a Stage III is that it has the supercharger this stage II has everything but the mats and pedals. Suspension, intake, throttle body, strut bars, full exhaust, software.
I think its funny that we all have this glove box issue i was going to say the same thing. nice ride proper build, i owned one convertible and just wasnt for me def props tho nice color.
Nice BMW. What's up with the plastic wrap on the carpet?
Had the carpet cleaned and they laid it down just hadn't taken it off yet. Still trying to decide what mats to get mine are shot.
Looking good neighbor! I'd probably go with the Dinan mats since you have related Dinan mods. depends on price diff
Nice placement of the sub box. I did the same thing in my trunk.
Lots of bass and looks good!
"Once you're defeated mentally, you might was well not even go to the starting line."
-Todd Williams
Got the idea from BSW but I went with a 10" I'm getting a little rattle though sometimes from the trunk it could be the jack or something else loose I'm going to have to hunt it down and then maybe lay some dynamat too.
Yeah the Dinan ones are crazy priced they run $100 more than the OE ones. But I'm going to a Dinan open house this fall and may see if I cant get them cheaper there.
New side trim is on! These were easy but pricey... just 6 of the grommets were $20 from the stealer... You can see the lights better in these shots as well. I also was able to get a deal on some Dinan mats so while they were still more than the factory ones I figured they would "fit" the car better. This Friday I will start the paint work on the rear bumper and side skirts...
Shot at 2010-09-28
Shot at 2010-09-28
Shot at 2010-09-28
Shot at 2010-10-01
Shot at 2010-10-01
Shot at 2010-10-01
More pictures to come tomorrow...
What I did was scrub all the grey off like has been mentioned on here many times but mine were a little banged up so I then resprayed them with three coats of base and 3 coats of clear. Color looks good!
I like this; Just lower the front a bit but it's going great!! Good luck
maybe hardtop!?
RIP
325ci Topaz Blau/ 5 Speed
very nice doing the same to my side skirts also , respraying my car next weekend so im gunna prep stuff this week , fun fun lol
really clean...not a big fan of convertible..but it does look sexy
2000 BMW 528i / Manual Tranny / Sport & Premium package / Xenon headlight / Sport seats / Premium sound / DSC /
2011 BMW X3
+1 for getting a hardtop, if you can find one/have the funds. I'm not a fan of verts but E36's with hardtops look just fine.
wat size is that sub? mine just blew out recently and i would like to do one just like yours to save some space.
Yeah that is the primer used at the factory. I could have sanded it all out I guess but I was afraid it wouldnt be uniform so I left it. It's probably better to leave it anyway to prevent rust.
