Results 1 to 25 of 29
Thread: Headlight Adjuster Replacement (c. 2003 epoxied headlights)
    West Michigan
    98 540iA (Prd 11/97)
    The following is three different DIYs on the adjuster replacement. You'll have to decide which one is the best for your application.
    1-
    BMW 5-Series Headlight Adjuster Replacement
    2-
    Quote Originally Posted by Dude14 View Post
    My Headlight Adjuster replacement Story
    It was not difficult but it took alot of patience and finess. Having read all sorts of posts and seeing some pdf files, I tried the bake method. I beleive the sealant that was used is some sort of butyl that is used to seal windshields in and it did not take long for me to figure that I had to do something else. I saw one post on this forum where someone had cut the clear lenses off with what looked like a chainsaw. I knew that was not the way to do it.
    I removed the headlamp assy's.
    I removed all of the bulbs.
    Then I removed the rubber boots (be careful because they tear easily, ask how I know this)
    The projector lamp adjuster was fairly straight forward. I could see the adjuster. I removed the old peices ( that took the longest time) then took a T-8 torx bit and removed the socket that hold the ball. Then I installed the new adjuster. One key point here is not to snap the ball in the socket yet.
    Here is where the patience part comes in. On the high beam adjuster, I marked out a 2" x 2" square on top of the housing, just inside of where the adjuster tracks are. I took my trusty dremel tool with a cut off wheel and cut a window in the housing. I caution you to take your time! Beneath this window is the fiber optics receiver and cabling. Only cut deep enough to get through the 1st layer of plastic. I was able to see everything and perform the repair on the high beam adjuster.
    To close the window I had cut, I used a plug that is for 2" square tubing. I had to trim it so that it would sit flush on the housing. I used clear silicone to seal it, but I suppose you could use epoxy also.
    I would post pictures but I do not have enough posts yet to do so. Maybe I can make a DIY when the time comes, if anyone is interested...
    I have been an E39 owner for 4 months now and really enjoy this car. I thank everyone who contributes to these forums because it has helped me remedy the few problems I have had.
    Thanks!
    I wish the author would return and provide photos.
    __________________________________________________ _____________________
    3-
    Quote Originally Posted by Lone Star Bavarian
    Hey Gang,
    In the past we have all come to the conclusion that the later(2002-2003) E39
    headlight adjusters that are contained in the assembly with lenses that
    CAN'T be removed were not replaceable. These assemblies have a lens epoxy
    or bonding agent that is not breakable without damaging the assembly. I
    have noted that the glue or bonding agent is usually gray or brown in color
    and does not give, even if heated.
    I recently found a way to replace these adjusters via cutting a strategically
    cut hole for the high beam side (see picture below). The low beam side can be replaced through
    the low beam access hole. I had to remove the adjuster receiving end(torx)
    before removing the respective adjuster. I utilized a couple of surgical clamps (see picture below)
    and appropriate torx driver. After you are finished you will need to cut
    another piece of plastic that is oversized to epoxy back down to the headlight
    to cover the hole you cut. We are currently using Wurth's Replast Plastic Repair for
    this type of epoxy job. This stuff sets quickly and permanently. See the
    photos attached. I didn't take as many photos as I should have because my
    time was limited and I wasn't sure if this would work. I am satisfied that
    it will work for the future and plan to use this, with the clients
    permission, to fix the assemblies in question.
    __________________________________________________ ______________________
    3-
    http://www.m5board.com/vbulletin/e39...some-pics.html
    East Coast
    Pull n Release
    Quote Originally Posted by jamesdc4 View Post
    Its not easy. I have seen this work. Had them done to my lights. Not worth it to do it myself. I have massive hands. No good.
    Another FP5241 Creation
    Parting out M54 Engine. Intake and all. Cats avail as well. PM ME!
    West Michigan
    Quote Originally Posted by Gumbi4u View Post
    I hear you, Ken.
    When Mark used the term "incision", I got the idea that there had to be some serious, detailed surgical work. At least this guide might provide an alternative to someone in a pinch. The funny thing is I'd be more comfortable doing this kind of procedure than replacing a VC gasket.
    San Jose, CA
    E39 540iA
    I have skinny girly hands, so I might be able to do this, lol
    Sep 2009
    USA
    any time, any place
    There is no need to make a giant hole in the light like that. If you search my posts you will see I have shared a brief how to that mentions how I repair these sealed lights. It's not overly complicated but you want to make sure that zero dust enters the light as you cannot exactly get inside there to clean it out. You also need to make sure the light is still sealed when you are done. Any moisture in the light will cause it to fog and look like crap when it rains or you wash the car.
    I have developed a special process as well as a couple tools to aid in adjuster installation to these sealed hella angel eye lights.
    I'm all for someone tackling DIY. That said if you want your Hellas fixed properly in a method that will withstand the elements just send me a PM or email. I've been fixing these e39 angel eye lights for several years and you can rest assured your expensive lights will be better than new.
    West Michigan
    Quote Originally Posted by Mark@EACTuning View Post
    There is no need to make a giant hole in the light like that. That looks like a butcher got a hold of it. If you need a set of sealed Hella angel eyes fixed just PM me, my method is a lot cleaner and the light will retain a good seal when the fix is done.
    Mark,
    This is the best I could come up with.
    It sure would be nice to be able to post up the best possible method, but until a better procedure surfaces or is shared, this is it.
    Costa Rica
    Blown 528i, KE30, Pathy
    Mark,
    +1.
    The best procedures are kept in secret. I understand the motivation behind it, but the "effing big hole" is the best I've seen for epoxy glued lights.
    Resident Third World Country Advisor
    West Michigan
    I agree about not getting any dust in the housing, but from my experience with the E39 headlights, they are not sealed or air tight. There are two vent tubes on the rear of the housing. Are the '03 lights different?
    Sep 2009
    USA
    any time, any place
    those are vent tubes and the way they are made they are the only airways in and out of the lights. They are designed in a manner to prevent moisture from entering the light. All e39 lights have those.
    What you don't want is an open hole or partially sealed hole elsewhere. I've done all the trial and error a man can do with these lights. Seal them up when you are done or they will fog up when it rains.
    Apr 2008
    Brooklyn
    02 530i
    Mark, how much would you charge for 02 halogen adjuster replacement?
    Sep 2009
    USA
    any time, any place
    sent you a PM with parts and pricing info. Thank you!
    West Michigan
    Thanks, Mark.
    When I installed CCFL AE inverters inside the light housing (pre-facelift lights) the only thing inside the tubes was a loose plug of foam. I had to remove them, thread the inverter wiring through, then reinstall. It seems unlikely the foam could prevent moisture from entering into the housing. It seemed to me that the angle and placement of the tubes had more to do with keeping moisture out than anything else.
    You can see the foam plug with the wiring threaded through in this photo I took during the DIY.
    One thing's for sure. Trying to remove the moisture from a headlight housing without opening them while not impossible, is a royal PITA!
    Sep 2010
    NY
    e39 530i e28 535is(Sold)
    Mark will you also do FX-R Bi-Xenon upgrades when you open these lights? I want to upgrade my halogens to xenons at some point.
    I was thinking of either buying some used OE Hella xenons or halogens if I can't find xenons. Depending on how I like the xenons or if I have to replace adjusters I was thinking of also doing the FX-R upgrade, but if I end up with lights that can't be baked open it would present an issue.
    E39 2003 530i: SP, CWP, PP, Manual, Sunshades, Split folding rear seats, 17" Style 42s|
    UUC SSK & DSSR, Eibach sway bars, Powerflex bushings, Angel Ibright V3, ZHP illuminated shift knob, e38 Euro Armrest, Dice Media Bridge, spec.dock, OEM Mtech F&R bumpers, Hella Bi-Xenon (EVOX-R)
    E28 1987 535is: Manual, Bilstein HDs, 16" Style 5v2 (from e38) [Sold]
    Dec 2007
    DFW, Texas
    03' BMW 530i 5sp
    I was able to replace the headlight adjusters in my 2003 headlight assembly tonight without removing the lens and without cutting any holes in the assembly.
    You don't need any special tools and everything can be done through the rear bulb holes. I will be doing my other headlight sometime in the next few days and I will take pictures and post a DIY so that this mystery can finally be busted.
    P.S. it is not easy and it does takes time and patience. Took me about 2 hours to do the first one. . . I think it will take about an hour to do my next one.
    Tampa, Fl
    2002 530iT/6, 2002 525i
    Looking Forward
    Quote Originally Posted by BenPRunkle View Post
    I'm looking forward to seeing your DIY. I have a 2003 E39, the adjusters are still working but a friend of mine is going to make me a set of titanium adjusters just for the fun of it and it would be nice to get them installed without cutting the housing.
    Chisum
    Champaign, IL
    2002 530i
    I too am looking forward to seeing this DIY. I have a 2002 530i. Today I installed the aluminum adjusters on my passenger side headlight. However, I could not get the driver side lens off. The passenger side came off easy with the baking method. Has anyone heard of one headlight having the gooey black stuff and the other having the un-openable epoxy? Hopefully with this DIY it won't matter. Please post soon!
    Quote Originally Posted by Chisum View Post
    Chisum
    West Michigan
    Aug 2009
    Lakeville MN
    2008 BMW 535xi
    This cutting method is fine if you need to replace the adjuster arm by the high beam. But if you have to do the one attached to the low beam housing the cut needs to be in a different place but it can be done.
    Feb 2009
    USA
    2001 530i (E39) 128k
    Not only is the non-bake replacement of the high beams physically impossible, cutting a hole in the top is also impossible to remove the adjusters.
    I don't care what anyone claims, there simply is no physical way to replace the high beam adjusters from the bulb hole or from a cut hole in the top. (ie: without baking open)
    The only way to fix your lights is to bake them open. If you can't bake open, buy new headlights.
    I'm entitled to my opinion, and do not believe previous posters (unless my 2001 lights have a different internal config)
    This is, by far, the most nightmarish DIY I have tried to date. If they don't bake open, you will fail.
    You need to be a surgeon with very specific tools for this to even have a 1% chance of working.
    There is no way to access the torx bolt holding the high beam ball socket. The angel eye wires do not move to the side.
    West Michigan
    Quote Originally Posted by OnTheFence View Post
    OTF,
    "I find your lack of faith disturbing."
    Look. No one said it was easy, but just because you have difficulty in successfully completing a procedure doesn't mean it's impossible. It just means you lack the skills to do it. Sharing your opinion is fine and perhaps will be a warning for those who are faint of heart to not try doing this themselves.
    Dec 2008
    Madison,WI
    E91
    -Not only is the non-bake replacement of the high beams physically impossible,
    -I don't care what anyone claims, there simply is no physical way to replace the high beam adjusters from the bulb hole or from a cut hole in the top. (ie: without baking open)
    -The only way to fix your lights is to bake them open. If you can't bake open, buy new headlights.
    -do not believe previous posters
    -If they don't bake open, you will fail.
    . YOU are the one that is a failure not the DIY. Just did this last weekend with no issues as my drivers side was a epoxy sealed version. I did the passenger side without baking also as I rather NOT BAKE the lens if I didn't have to. Took me about 3 hours total.
    You ask any ricer, any serious ricer. It doesn't matter if the other guy is racing or not. A win is a win.
    East Coast
    Pull n Release
    The hole method is how mine were done. Its possible and many have done it. Plain and simple. Either you "have it" or you dont.
    Nov 2003
    Fort Worth, Texas
    540it, 840csi, RoverHSE
    E39 Headlight Adjuster Replacement
    Since my method and write up from Odometer Gears is one of the mentioned examples in this string, I am going to chime in. I have heard of some using the heat/bake method and being successful. I think that method is great but we don't have access to an oven in our shop and I am not going to install one just so we can fix these headlights. I came up with the hole method by first experimenting on a set of lights off of a car that belonged to my shop. I was looking for a way to fix these expensive headlights and not have to tell a client they were forced to by a new one because two pieces of plastic failed. The method works fine and have used it on about a dozen since I came up with it. The key here is where you place the hole, and you only need one because the other can be done via the existing openings. To do this you definitely need something like medical clamps which used to be sold at Harbor Freight. I don't know if they still sell them but I bet a "google" search will find other sources. These medical clamps allow you to grab the old adjuster and pieces to remove. It also allows you to grab the new one and fish it into the right position to be able to pull it into place with the adjustment screw on the back of the headlight.
    The point is that like other members have pointed out, it can be done. When you are finished you need a highend epoxy(preferably two part and made for plastic repair) to glue a cover in place and seal the headlight. I use at Wurth product but there are several other good products out there.
    If you are an impatient individual this repair is probably better left to someone who is. I admit that I am not a patient person but I find patience when working on these cars since impatience can cost you lots of stupid money in broken parts, related and not. For me it comes down to keeping my clientel happy and giving them viable alternatives to dealer repairs and (dis)service.
    Have fun and take it slow.
    Trent Cole
    Lone Star Bavarian, Inc.
    Ft. Worth, Texas
    817-732-4888
    www.bmwfxr.com
    Tech Advisor, Lone Star Chapter
    Authorized Bosch Service Center
    ASE Master Techncians
    BMW Master Technicians
    BIMRS Member,16 years
    BMW CCA Member,25 years
    Reidsville North carolina
    2001 530I
    Bcminnc
    Thanks for the Head lamp Adjuster DIY. Question-Where is the best lace to buy the Adjuster replacement parts? Is that a dealer or aftermarket kit?
    Nov 2003
    Fort Worth, Texas
    Depends what headlight you have...if it is the earlier style then the dealer will have them. If it is the later style then odometergears.com[/url]
    Trent Cole
    Ft. Worth, Texas
    817-732-4888
    www.bmwfxr.com
