...is in!
I fitted one a couple of months ago, but didn't finish the project until 2 weeks ago, as I have the (Euro only) factory alarm option, which has the keyless entry module inside the factory mirror.
Compass mirror is now fully functional, including the remote control.
That last was the hardest part, the rest is basically plug & play. Problem with new BMW's is how the remote works, or so I understand. Different inputs for opening/closing etc.
So to get this work, only one option was left. Remove the remote control unit from the factory mirror and place it somewhere under the dash. Then figure out what wires from the harness are going to the mirror part and what to the remote part. And hope they don't have shared wires (which they do!)
Here's some snippets of the project.
Open up the factory mirror. This is hard. The bezel hardly pulls off. I somehow managed to get it off and don't break any of the tabs.
Things is, I didn't dare trying it on the expensive and much harder to find compass mirror. The best solution would be to open up the compass mirror, switch out the new for the old remote module (if they are the same size, which I don't know either and if the new mirrors actually have a remote module at all, as I have seen inside pics that showed no module), close it up and hook everything up. Maybe I'll try that in the future. Saves lots of work. So it's v1.0 for now.
Mirror opened, glass removed. This what you see is the remote control unit. The blue wire is the antenna.
Back of auto-dimm glass. Lots of electronics on this!
remote control unit removed.
To remove the wiring you have to take out all the pins on the black connector to pull the wires through. Make sure you write down which color pin is in what number position (or as I like to do, make digital pics of it).
The remote module fitted in a spare comb-connectors holder, switched upside down. A couple of small screws + bolts to raise it a little but, to protect all the electronics on the other side of the PCB.
And then fitted in the bowels of the dash. As I have lots of modules on mine, since I have nearly every factory option (and then some) I only had some space left under and right of the right glovebox vent tube.
And as the new style mirrors have different plastic covers, they also use a different style of grommet. So again, out with all the pins, feed them through the new grommet and put them back in the connector.
Now if you don't have a factory alarm (dealer installed/dealer approved) you already have the remote control in another location and you can just plug & play the mirror in. Oh well!
- I also ran 2 extra wires from the factory alarm led to the mirror for that όber cool alarm led at the bottom of the mirror. That way you can see from far away that the car is armed (and so do others) so you don't have to get next to the car and look inside.
Gives me an extra space for a switch in front of the gearstick, although I don't have any options left to fit that would use a switch in that location.
Maybe I'll hook up both leds.
Couple of pics of the finished situation.
Besides the mirror itself, this base is covered by two big plastic trimpieces, unlike the factory mirror.
I like the thick look that is creates, but what is best, is that, as you can see, the covers go all the way against the windshield, completely hiding the (hexagonal) mounting point. The stock metal base that has 2 small covers on the base itself, doesn't hide it.
The thicker rubber grommet, almost completely compressed. I was a little worried this might not fitted correctly as the position is slightly offset, but it all went in pretty well, although incredibly fiddly to do.
Side view of the base's trimpiece
On the factory (auto dimm) mirror, the light sensitive sensor was exposed behind a simple hole in the back of the mirror. On this later style mirror, there is a nice piece of transparent plastic that covers it.
All new look. Really liking this myself.
Why? Goes well with all the other switches, matrix displays and amber lights; I want them all.
PS: my car was factory fitted with alarm-remote control/keyless entry and auto dimming mirror.
For that, I already had a connector at the rearview mirror with 10(!) wires going to it (which is funny as the factory mirror only has 9 pins). The compass mirror also has 9 pins, but the one not used is in a different position.
Be assured that hte E46 onwards cars that had the compass mirror option have their radio receiver in the AM/FM amplifier. Fairly sure that's true for the cabrio too, but you can check the WDS can also check to see what all the other wires are for in the mirror.
(Search for A22 in the E46 and X5 - seems to be power, GND, LED, dim control for the wing mirrors and reverse signal).
You will need Java and Adobe's SVG viewer.
Nice job. I have the auto dimming mirror I plan to install which is much more pedestrian than your install. I have done the Gentex mirrors auto diming and with compass in my Ford Diesel Superduty and it is a nice add.
Nice look well integrated...
Anyone know the part number for the grommet?
Does the E36 connector (UK EC model, no DWA receiver) plug in directly to the later mirror or is a new connector?
E36 DICE MediaBridge BT and iPod support Photo location of the cabrio drain holes. Custom heated seats and lumbar support retrofit. Glovebox charging sockets and cupholders. E36 PDF Schematics UK Aftermarket E36 OBC bulbs Convert rear lights from non check-control to check-control DIY BMW E36 MFSW retrofit pictoral DIY All BMWs UK cheaper source for electrical connectors, Farnell, RS BMW INPA success E46/E39 onwards E36 vert mood lighting DIY BMW E36 puddle light and inner handle illumination DIY. E36 convertible flat bungee tension strap fix DIY BMW E36 PDF manualBMW E36 vert water in motor of tonneau area fix.
MPar... you truly are a marvel of electronic wizardry with our cars. Bravo!!
Just some additional notes on this from my ongoing project.
My 1998 UK E36 with EC mirror uses the same 10 pin plug as the E46, and the same plastic arm housings - no new grommet required.
The factory harness wires on the E36 are Violet/White (IGN), Brown/Orange (GND) and Blue/Yellow (Reverse, active high).
Some E36 EC mirror vs E46 EC mirror pics. E46 mirror is thicker and a smidge (1/2cm) wider. Same height. Housings have the same part numbers stamped inside.
I wonder if that is your original mirror or not because as far as I know, the E36 never came with the later style EC mirror, the one with the larger base foot that takes the larger encaps.
I think some previous owner fitted that to the car as it probably did not have an EC mirror before.
The 10-pin connector is the same for all model BMW's. Some have more wires than others. Mine had 10 wires going to the plug.
I can report the remote function still works as good the day I mounted it under the dash, though eventually I might open the compass mirror and see if the remote receiver fits in there.
Actually I'm pretty sure this is the case. The OEM E36 EC mirror is a (slightly) different model (thicker lower plastic edge) not visible in my pics.
Cool. looks like you got it just the way you wanted...
As you know, I went the other direction as I did NOT want an Alarm LED in my mirror and instead wanted autodimm + compass + HOMELINK.
Homelink is awesome as it gets rid of the need to carry a garage door opener remote (and also gives me 2 spare buttons to program to the garage doors at my mom's house and my sister's house).
1998 M3 Cabriolet (Estoril, Hardtop, Vaders, Dinan Stage 5, M50 Mani, Eisenmann Exhaust, UUC Pulley & SSK, Reiger Body Kit, 19" Staggered Axis Pentas, Momo Steering Wheel & Shift Knob)
2002 Audi S6 Avant, 2013 F150 Ecoboost (6"lift, 20" wheels, 35" tires) 2005 Kawasaki ZX-6R 636 (2 Bros Exhaust, Power Commander, Fender Eliminator, Flush Mounts, Throttlemeister, etc.)
Interested in using a Professional Fender Rolling tool w/ Heat Gun?. PM me for details.
www.TraysonsToybox.com
Yeah got what I wanted. I have no garage or anything to open so HomeLink would be having 3 non-working switches.
You have a green compass right? Any (night) pics?
The BMW compass mirror was a direct fit was well. Not need to change the mounting thing on the windshield.
PS: you have the led ambient lights on the wrong side of the interior domelight.
I have one of these compass mirrors retro fitted to the e39. I was thinking about doing the e36 good to have some one else go through the learning process first. Thanks for the write up MPar.
1996 320iC: leather, full elec hood, hard top, auto-dim, sport, revised front grilles, rear head rests (in storage now)
2006 630i SMG Sport: Sapphire black met, creambeige leather, SMG gearbox, 19' Style 218 alloys, heated sport seats, Sport trim, Dension iPod interface, factory Bluetooth, Xenons, Sat Nav/CCC retrofit, LM2 retrofit, Digital TV retrofit, reverse camera, Homelink/Compass mirror retrofit, etc.
2007 M6: Sapphire Black Met, Indianapolis red leather, TV, adaptive headlights, HomeLink, HUD, Dension iPod interface, Tracker, Logic7 Top HiFi, much more ....V10
2004 Mini Cooper S: 15% pulley, remap, r56 brake conversion, modified intake, and more!
OP Im sorry if I missed something, is the mirror you used OEM for an E36 or from another car?
Certainly not the first to have a compass mirror. But, Maybe the first to retrofit the alarm antenna stuff though...
But I get what you're saying, innovation is cool. I'd venture a guess that I very well could be the first to fit a Thule Roof rack like I did onto the E36 vert hardtop... Never know...
I have an e36 which I believe doesn't have an auto dimming mirror, uk 98 M3 vert.
Can I retro fit the mirror with the compass? I'm not fussed about the dimming or alarm features, just want the compass.
Which model is the mirror off too?
I can tell the compass is utterly useless
I dont think mine has any wiring in it as its a basic M3 Convertible. Dont think it dims? Anyway to check visually?
If compass is useless then might not bother if i have to route wires everywhere.
Thanks dude.
If there are no wires present, am i only going to need power for the compass?
Got a part number off the mirror?
Home link one is about £230 here.
