Alas. It's time to let go of my ///M Coupe. I've got to make room for another vehicle that can accommodate my family.
Some historical details on the car.
The car was in an accident on July 3rd 2007. I was side swiped by a drunk driver who hit the driver's side part of the hood and forced me up a curb. The hood was damaged as well as the driver's side front head lamp from the impact. The wheels, front control arms, front wheel hub, and front bumper were damaged from being forced into a curb. I've got all the records of everything that has been fixed and parts replaced as well as all of the maintenance records, and receipts of modifications done to my car.
If you do a carfax the accident will show up on the VIN#, which is WBSCM9342YLC61589. The car has a Clean Title.
The car is my weekend vehicle and saw 7 Autocross events with the Houston Chapter BMWCCA at the Houston Police Academy. My times were okay....I was only there to beat M3Roar, which I did at every Autocross event.
There's currently ~65,200 miles on the car.
Now onto The Good Stuff.
Below is a list of everything that I have modified on the car. Most of the modifications are track oriented rather than show. This is definitely a driver's car. If you're a track junkie, this car has your name written all over it. Coilovers are fully adjustable as well as the camber and toe. You'll also never have to worry about the dreaded BMW Z3 subframe issue since I added the comprehensive Randy Forbes subframe reinforcement kit as well as the dual earred Rogue Engineering Differential Cover. This car drives and is built solid.
Modifications:
Engine:
Active Autowerke Supercharger C30 (Rotex intercooled) 6 psi
Stewart High Flow Water Pump
Magnaflow Quad Exhaust
Suspension:
Ground Control Street/School Coilover Kit
Vorshlag (fka:Motor-Force) Camber Plates
Bavarian Hyper Sports rear shock mounts
Ireland Engineering Camber/Toe Rear Adjustment Kit
Wheels:
BBS CH 18 x 8.5 front/18 x 10 rear
Transmission:
UUC Evo2 Short Shift Kit
UUC RK3 Stainless Steel Weighted Shift Knob
Rogue Engineering Dual Earred Differential cover
UUC Stage 2 Lightweight Flywheel
E34 M5 Clutch
Subframe:
Ireland Engineering Rear Subframe Mounts
Randy Forbes Subframe Reinforcement Kit
Brakes:
Zimmerman Cross Drilled Rotors
Stoptech Stainless Steel Brakelines
E46 ///M3 Cool Carbon Brake Pads (Front)
Cosmetic:
Projector Z Daylight Demon Eyes and HID Kit
VDO Boost Gauge
Clear Corners
**Serviced and meticulously maintained at BMW of Houston North, Advantage BMW, Bimmer Workshop, and Bavarian Hyper Sports
**Most modifications installed at Bavarian Hyper Sports
I'm asking $19,995 or best reasonable offer. This is a real gem of a car that needs to be seen and driven to appreciate. Please e-mail me at 2000mcoupe4sale@gmail.com or PM me if you need additional pictures and information.
Paper work
A couple of extra pics when my car won Best BMW at the Hot Summer Night show at BMW of Houston North. This is what the car looks like with "dish".
Pics courtesy of Matt Chow and Chris Reeno.
2000 Estoril Blau ///M Coupe (SOLD)
-AA SC, UUC Stg 2 LWFW/e34 M5 Clutch, UUC Ultimate SSK, UUC RK3 Shift Knob, Magnaflow Custom Quad Exhaust, Zimmerman X-Drilled Rotors, GC Coilovers, BHS RSMs, Motor Force Camber Plates, Toureg VW Torch Lamp, ProjectorZ w/ DDE, Randy Forbes Subframe Reinforcement Kit, IE Subframe Bushings, IE Camber/Toe Adjustment Kit, Rogue Diff Cover, Redline Fluids
"I wasn't speeding, officer. I was qualifying."
Any possibility of trading the pzI's for a set of stock lights in very good condition?
I understand you want to keep the car as is, but figured I would ask.
GLWTS, someone should definitely pick this thing up quickly!
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
horsepower/torque numbers?
Looks sweet. Do you guys think this is smog legal for calif.?
Trade plus cash?
Is it sold?? I get no responce...
**Sale Pending**
Thanks.
Sold.
Thanks for all the great comments.
Admins. If you can kindly lock up this thread please.
Was it sold to someone on the board?
