It showed up on my instrument cluster and I cant use my Trip Computer or anything on the instrument cluster message board, whats it mean?
Umm as for looking in some forums its like narrowed down to something to do with RDC Sensor and tires. But everything is in German so its hard to translate it accurate. But looks like some kinda sensor to the wheels is faulty.
Re: E38 error RDC "tire control inactive or Reifenkontr Inaktive"
Hello
The garage has detected the error, it was a faulty wheel electronics in the rear left wheel. The error is corrected.
Yes one of the batteries in the RDC sensors are gone, try resetting it and hope it stays off
Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
It is probably complaining about the sensor in one of the wheels. They send are located on the valve stem inside each wheel and cost about $150 each to replace. They don't have replaceable batteries that I know of.
Will this reset it?
http://www.bimmerboard.com/forums/posts/129948
no it wont, i just tried
Only option is to replace or code off.
Try this ignition pos II hold the button till you see SET, then start the car and drive 10 miles minimum.
Trip computer you can always see.
The sensors in the wheels need or could need replacing
Your millage, trip and outside temp are not part of the message cluster.........................
If you decide to remove/code it off, I would love to buy the parts from you (except the wheel sensors of course). I have the dash wood without the button I can swap out as well.
Edwin, if he doesn't have access to Progman, can he pull the module and get it to stop throwing the error? I assume so because mine doesn't need coding to add DWS.
Pic to clear up confusion?
The display on the instrument cluster is NOT your OBC display. The display for the OBC is the MID (multi-informational display)...or the Nav screen (if your car has that option).
The display on the isntrument cluster is the CCD (check control display) and the CHECK CONTROL SYSTEM has first dibs on that display. There are 2 types of warnings that can appear there...priority 1 and priority 2. If it is a priority 1 warning...it will take over the display and remain there as long as the ignition is on. If it is a priority 2 warning...you can press the LEFT button on the instrument cluster and clear it...but "STATUS ARROWS" will remain illuminated on the left & right to indicate that there is something you need to take care of.
The ability to "PROGRAM" the OBC features into the CCD is just a secondary benefit. If you loose power (dead or replace battery) you will have to reprogram any or all of the OBC features back into the instrument cluster. Or if a Check Control warning is eminent...it takes over the display (like FASTEN SEAT BELT, DOOR OPEN, TRUNK OPEN, LIGHTS ON, etc).
I don't know why the warning is in German, though. When the car defaults back to German, there's usually an issue like low car battery voltage or other electrical issues.
Again, if you want or need to use your OBC features...all you have to do is press the BC icon on the MID button (if that's what you have) or use your NAV screen monitor...all of the OBC features will still be available to use.
(this is an image of the e38 MID...to use the AUDIO/PHONE/TIME CLOCK/OBC...just press the appropriate button (on the far right), and the available features will appear in the display...along with the prompt for the feature above one of the 6 "soft key" buttons)
If you have the Nav monitor...then pull up and select the OnBoard Computer using the knobs/buttons for the Nav
Yes, it says it where the OBC is
What ever...................
WTB: Dinan Spring set, for the 750iL
You work hard, discover that success is not a destination but rather a road you travel upon- mostly up hill. Then, after a while, people going down the other road look up at you, and they call you "lucky."
1995 740iA. Dinan DME. Kenwood Exelon system. Kicker Competition subs. DSP bypass. Servotronic bypass. ASA JH9 18" Wheels. Cherry Bomb exhaust. Resonator delete. 99-01 Euro crystal tailights. Xenon angel eye headlights w/ mild facelift. Kidney grills.
They are the two tire pressure monitoring systems that BMW used.
DWS - Looks at the reluctor rings at each wheel that are used for abs and compares the speeds of each wheel. if one wheel is not moving at the same speed and you are not turning it means that the diameter has changed. diameter change = low tire pressure.
RDC - Uses a pressure and temp sensor in each wheel and an antenna in each wheel well to scene the actual pressure in each tire.
Each system has it's pluses and minuses.
The RDC system was mostly used on cars that came with run-flat tires. This is because when a run-flat is low it holds it's shape more and may not set off the tire defect warning in the DWS system.
The RDC is a much more accurate system but more complex. it comprises 4 sensors (one in each wheel) that contain a lithium battery that is not replaceable. they tend to last about 4-6 years and cost upwards of $100 each. there are also the 4 antennas, the brain, and the switch on the dash.
BMW much preferred the DWS system (likely due to cost and maintenance issues) and the RDC system seems to be a relative rarity.
The give away for RDC is the metal valve stems. You can have no/DWS with metal valve stems but if you have rubber valve stems you defiantly do not have RDC.
Richard
thanks for the clarity, my 07 F-150 lariat has the sensors in the wheels, I hear it's expensive when it breaks...even on a ford
