Ok so the "coolant level low" warning is supposed to come on before it's dangerously low but when does that actually happen? I checked my reserve tank and my coolant is so low that I can't press the measuring stick down anymore. In fact it's low enough that I could see most of the stick and a bit of the base. If I had to guess its definitely 60% empty, maybe even 70-80%.
So yea...how much lower can this go? I want to flush it all out sometime in the near future and refill it with BMW-approved coolant.
Is this thread serious? I mean, how come you're running low on coolant to the point where the expansion tank is almost dry, and you still want to know how low could it go???
Go right now to the car and add some water until the stick reads the right level. You don't always need to use pure coolant if it's just to keep the thing from overheating and if you don't want to spend money only to flush it later. Bottled coolant is a mix of water with chemicals anyway, so adding a few ounces of water would have almost no effect on the coolant properties.
Your car will tell you it's running low on coolant when the expansion tank is around the 1/4 mark. Less than that and you're risking destroying your engine.
Resident Third World Country Advisor
too low is when you fry the engine conducting an unnecessary experiment.
It wasn't clear from your post.
If your expansion tank is dry and the warning never showed up, then your coolant level sensor is bad. I had to replace mine a few days ago, only that it was reporting the level as low when it was indeed fine. Again, at about 1/4 level you get the low coolant warning. Max level is around the 3/4 mark.
do all of these cars have a level sensor? I thought just the newer ones did.
>'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
I'm going to start a thread entitled: "Why are the call 'Idiot lights'?"
Often when these lights come on, it's too late.
Also, the coolant level sensors often fail, as they are exposed to corrosive fluids. My e36 sensor failed, but I routinely check the level (along with oil, etc...).
[ame]http://www.youtube.com/watch?v=ox-lfowevqA&feature=search[/ame]
PRICE CUT on ALL FABRICS
Only certain US 528s had them per RealOEM
http://www.realoem.com/bmw/showparts...35&hg=17&fg=05
My plan is to never have to see the idiot light by regularly checking fluid levels.
i was actually shocked at how low it was. i check on it from time to time, but i was gone for about a month and haven't checked since early june. can't believe how low it is now.
anyhow i poured some distilled water in and after the weekend i'll get it properly flushed and refilled.
In the US ONLY E39's with the HIGH OBC get a coolant level sensor. Most early M52/M52TU E39's don't have the HIGH OBC. I doubt your '00 528i has the low coolant level sensor. This is one of the DUMBEST moves BMW ever made in view of E39 cooling system weakness'. I'm attempting to retrofit one into mine. The expansion tank is factory ready for sensor. I can't decide between tieing into low washer fluid or brake fluid light circuit.
Paul S
BMW CCA 69606
Wow, I have to agree with you on that. Given how stupidly prone to failure these systems are, not including a level sensor is probably the most idiotic thing I have heard about our cars. As I said above, my car is a 12/96 build date and has the sensor, but it also has a High OBC. In other parts of the world it wasn't year related apparently.
I know the e36 m50 cars had a coolant level sensor. My only guess it that they did not have a spot on the standard e39 instrument cluster and did not want to tie it to the mid-obc. Really poor decision making. As great as the e39 is, the mid-90s management of BMW did not make the best decisions.
