Below is my experience with power steering on my 540, which is a common problem with these cars, but not emphasized enough. I have to say I was quite lucky both times. Realistically if this happens to you chances are your belt will either completely break or shred and wrap around the fan ( what happened to me), like I said this occurred in my driveway if it were to happen at highway speeds it could have been a very dangerous situation seeing as the belt runs accessories such as your alternator as well. You will also need a new pump immediately and a tow this could easily be a 1,000 dollar scenario and very inconvenient if you don't have a second car.
It's times like these I miss my 528!
Got another good one for you.
Customer's PS pump locked up, but the belt didn't shread. Instead, it sheared the pump off the timing cover, breaking the mounting points off the cover. Required a new PS pump, front timing cover, all gaskets, and we did the timing rails while in there.
If you think you have a PS problem, fix it now.
"If everything seems under control, you're not going fast enough. - Mario Andretti"
Great advice. I'll keep a close eye (and ear) on mine. Thanks.
same thing happened to me, sheared the PS pump mount right off.
uuuuggghhhhh!! WTF.... More detrimental Problems? Thanks for the heads up!
KEVIN
BMW CCA # 416146
Current 2001 525i-5 / 234,000 Miles
///M Weighted Shift knob.
CD43 with AUX retrofit + Bluebus
Auto Dimming Mirror upgrade
H&R Sport / Koni STR.T
OEM Xenon HID Retrofit
The Ex- 2000 540i-6 / 82,xxx miles to 186,xxx miles
CDV Free, 545i Shifter and ///M Weighted Shift knob.
Member of DSC Module Failure Club $$
So the bracket really broke this morning, the plan was to take it off this evening to get it welded Now it's coming off tomorrow and will hopefully be welded on Wednesday, interested to see how this goes...
Installed new pump today,, I think I need to go back and install new crush washers , slow drip on the big line.
I never look for trouble. If it looks for me, I'm usually around
My power steering comes and goes....
1991 M5 (in progress)
Restoring an old BMW, God help me.
A month or so after I bought my car in 2006, I fueled up at a gas station, got back in the car, turned the key to start her, and BAM!. Sheared the PS pump right off.
The belt did not break, but the PS pump was toasted and unrepairable. Only having the car for about a month, and with absolutely no experience working on her aside from an oil and spark plug change, I cut the belt off with a pocket knife, drove four miles home, and then had her towed to BMW to the tune of about $780.
Everything I've read about the problem generally relates to cars with manual transmissions, and having turned the ignition off before the car comes to a complete stop. This is exactly what I did right before mine broke as well, but my story may be anecdotal at best seeing as how I don't fully understand the correlation...
Just passing along my experience and limited understanding...
The upshot is: Aside from a few flat tires, I had absolutely zero problems after that until this past winter (over four years!).
[QUOTE=98 528i;20012092]Did you use new ones
No, tried to get away with using the old ones.
Happened to me too!
I think one of the bolts loosened, leaving the other bolt as the only attachment. At some point the mount sheared, leaving the pump cockeyed, belt slipped off on start-up.
Fortunately, the damage stopped there and I fixed it with a $100 used pump. Brutal!
Never seen or really heard of it....more m54 ps pump shafts sheering with the non updated pumps.
BMW Tech
Forgot to report back, I ended up just buying a new pump.
yea, you have to be very careful with installing the PS pump. I was in Gumbi's shop when it was discovered, niether he or I knew what could have caused it. WE both thought it was a bottom out, but we both knew that didn't make any sense. I took pics, and I see that one of the bolts was not installed properly by the previous owner, and it sheared off after getting too loose.
Let that serve as a warning to us I guess.
Thanks for the tip!
Checked mine today and both bolts were loose about 3-4 full rotations. Thanks for the heads up.
I'm going to check these today. I recently had my PS pump changed out with a used one, working with a friend. I'm getting belt squeal and some strange squeaks... so I'll see if anything loosened up. Thanks!
is this a 540 thing or should i check mine also?
While we're on the topic...
Sometimes when making tight right (probably left too) turns I hear a noise coming from the engine area - possibly like a electrical motor straining... Is it safe to assume this is my pump or another part? Are there some tests I can do to nail it down?
Thanks for the tip by the way, I'll make sure to check this since I'm due to crawl under the car and do an oil change anyways.
LUCAS POWER STEERING LUBRICANT?
ive used it on my 528 but im kinda sceptical to use it on the 540.... considering i already have a fault code for the power steering FML again! omg! i think im going back to the supra scene. i hate my car right now!!!!!!!!!!
