1996 BMW M3
-72xxx miles on chassis, ~5k on rebuilt motor
-5-Speed Manual Transmission
-2 Door Coupe
-NEVER driven in snow/rain
-Weekend Summer toy ONLY
-Garage kept (with BMW e36 car cover)
-Non-smoker
-Rarely ever driven with more than 1 passenger; NEVER with more than 2 passengers (nobody sits behind me... I don't scoot my seat up for anybody!)
-No Food/Drinks EVER allowed in car, except for bottled water
-NEVER tracked/roadraced
Factory Options
-HK Premium Sound System
-6 Disc CD Changer
-Electric Power Sunroof
-Heated Leather Seats
-OEM Car Alarm
Exterior
-Cosmos Schwarz Metallic (Black) original paint in excellent condition
-OEM US spec headlights
-OEM Clear Euro BMW taillights
-Smoked side markers (side lights)
-Limo smoked front corner lights (still transparent with amber bulbs; lights up amber at night)
-Front bumper velocity splitters
-Fog light delete covers painted to match Cosmos Black
-Side moldings and side marker moldings painted to match Cosmos Black
-Front plate delete
-Kidney Grills painted to match Cosmos Black
-35% Legal Tint on rear 5 windows
Interior
-Manual Vaders (seats)
-Dove Grey leather interior
-3spoke Steering Wheel
-Gauges (Boost, A/F, Oil Psi, and Temp)
-Full OBC (On-Board Computer) Display
Engine
-s52 3.2L OBDII
-Rebuilt motor (approx. ~5k miles)
-Rebuilt (port & polished, 5angle valve job) head by Pete McHenry with all new guides, springs, valves; resurfaced face
-VAC Multi-Layered Steel (MLS) Head Gasket (0.070 stock thickness)
-ARP Head Studs
-CP Pistons 9.0:1 compression (High temp thermal coating by LO-KO Performance)
-New Rod Bearings & Bolts from VAC
-Stock BMW Forged Rods
-Underdrive Power Pulleys
-New OEM Motor Mounts (less than 5k miles)
-New Engine Gaskets from VAC Motorsports (less than 5k miles)
-New OEM Radiator (less than 5k miles)
-New OEM Thermostat & Waterpump (less than 5k miles)
-M50 Intake Manifold
-Custom Exhaust (No Cat)
-Walbro 255 High Flow Fuel Pump ***hard-wired to Battery
-Mass Air Sensor (3.5” HFM) provided by: Nick Glantzis
-42# Fuel Injectors provided by: Nick Glantzis
-New Oxygen Sensor replacement (less than 100 miles)
Turbo & Components
-Garrett T60-1 Turbo T3/T4 .83 turbine, .70ar compressor, stage III wheel
-Turbonetics T3 Turbo Manifold (High Temp Thermal Coated)
-Front Mount Intercooler
-38mm Greddy External Wastegate (9.6mm spring)
-Tial ByPass Valve
-Greddy Profec-B Spec-II Boost Controller
-VDO Gauges: Boost, Air/Fuel (AEM Wideband), Oil Pressure, Oil Temp
-Tuned by: Nick Glantzis (Technique Tuning.com)
Software changes include: (Increased engine rev limiter, Increased vehicle speed limiter, Remapped fuel and spark maps for custom mass air meter and larger injectors)
Transmission
-3.23Limited Slip Differential
-SPEC Stage 3 Clutch & Flywheel
-Rogue Transmission Mounts
-New Bosch Starter
-New Flex Disc/Guibo
-AA Differential Support Bracket
Suspension
-Eibach Springs & Sway Bars
-Bilstein Sport Shocks & Struts
-Motorsport X-brace
-Sway Bar reinforcement plates
-Ground Control rear shock mounts
-Ground Control Shims
-OEM rear trailing arm bushings
-New OEM Control Arms
-New OEM Tie Rods
Brakes
-Brembo Rotors
-Hawk HPS Pads
-Stainless Steel Brake Lines
-Brake Calibers painted semi-gloss black and Rotor Disc centers painted matte black
Wheels/Tires
-Fikse Mach V Wheels 17x8.5 on
Yokohama Advan Neova AD07 245/40/17
Less than 1k miles on tires (<11/32nds)
OR
-Replica Lightweight M3 Wheels 17x7.5 on
Yokohama AVS ES100s 225/45/17 (nearly bald)
Spare:
-Authentic Lightweight M3 Wheel 17x7.5 on
Michelin Pilot SX 225/45/17 (~10/32nds)
Additional Notes
-Motor is capable of pushing 21+psi. I have personally driven the car on 21psi with no issues at all and it is FAST! Though, the car is tuned to 15psi and is typically driven on 9psi on the street. This thing is FAST. I'm talking Z06 killer! With forged rods, low compression pistons, thick MLS headgasket, and rebuilt head - this motor is bulletproof.
-SHOWROOM Condition
-Very minor rock chips (mostly front bumper and a few on the mirrors and fenders)
-ASC Light wills always be on dash (ASC disabled thanks to Nick Glantzis’ software update)
-OEM BMW Battery just put in (less than 3k miles)
-Solid Compression Test Numbers
Measured Fall 2009; roughly 58 degrees outside
Cylinder 1: 154
Cylinder 2: 150
Cylinder 3: 152
Cylinder 4: 152
Cylinder 5: 152
Cylinder 6: 154
-Last Dyno Numbers using Dynojet @ APG Performance:
435 rwhp / 377 @ 15.1 psi
-VIN# WBSBG9320TEY72748
I originally purchased the car in June 2003. During this time I had ran a carfax and even took it to Patrick BMW Dealership in Schaumburg, IL, for an inspection. The carfax turned out clean and the inspection came out in all good news.
A couple of years ago, I posted this car up as a feeler and somebody had ran the VIN via Carfax. An accident had been reported on my vehicle in Iowa from year 2001. This did not appear linked to the VIN # until 2008 --- 7 years later. It did not come up in the Carfax report when I originally checked in June 2003.
Since then, I've been in contact with Carfax to see if there was a mixup in VIN #s and why this was not on the original carfax report that I ran. Apparently, police reports may take up to years to be reported and linked to a VIN. My M3 sustained some kind of damage to the driver side.
On the plus side, I had this car professionally inspected and have had no issues driving it for the 7 years that I've owned it. Any potential buyers, I will gladly let you fully inspect or take to a local dealer to do an inspection.
I hide nothing and still label this M3 as MINT/CLEAN!
I've owned this car for 7 years and only put 20k miles on it since. This car has been babied. Seriously, I've been made fun of for lack of driving it. I'm just too paranoid to take it anywhere and want to keep it in prestine condition. I don't see what's wrong with that. Ha!
I am looking for $19,000 with the Fikse Mach V wheels /Advan Neova tires, as currently on the car --- or, $17,000 with the replica LTW Wheels/Yoko ES100 tires.
Serious buyers or any questions, please PM.
-Mark
500+ HP TURBO M3 FOR SALE!
***EDIT. ADDED PHOTO.
Here is a pic of most of the receipts during my ownership and some even prior.
I am going to have them all on PDF soon. Buyer will receive history.
Please PM if you have any questions. For serious inquiries, I will give my phone number/email via PM.
Wow, that's one heckuva of a clean car. I'm looking for a 95-99 M3 but I don't have that kinda cash right now.
Bump for a great car and seller.
I have looked over/driven this car and as you can see no expense was spared when building.
Who ever picks this up is lucky to find such a clean example of an e36 M3.
'95 M3 soon to be replaced with something more serious
your pics dont work
I saw your add on craigslist for your car and followed it back to bimmerforums. Car looks amazing. Goodluck with your sale and free bump.
1971 BMW 2800CS
1981 BMW Euro 635csi
1958 Lotus Seven Replica (4lbs/hp )
2005 Jeep Wrangler Rubicon on 37's
1995 BMW M3 (SOLD)
I forgot to mention that this built motor can easily boost 21+ psi, which I can say from 1st hand personal experience. Dyno numbers are only up to 15psi --- 421rwhp.
Stock forged rods, low compression pistons (thermal coated), thicker MLS headgasket, rebuilt head by Pete McHenry, ARP studs. This motor is bullet proof. It would take a lot to blow this thing up!
willing to trade for a built stroker s4?
Bump for the sickest e36 in chicago! lol
Sounds very appealing. However, the only trade I'm looking for is a briefcase full of money. Or a fat check.
The truth is, I don't want to get rid of my car and I would never trade it for any other car (unless theres somebody with a 911 turbo willing to trade haha). I've spent too much money and priceless time & emotion on this car.
Thank you! One of the cleanest and sickest in the US! Guaranteed.
I've had several potential buyers and a handful of people look at & test drive my car, but I'm not biting on their offers just yet.
I have been trying to contact you to discuss this car but have not gotten a response. Please contact me..
Mike, Andrew, Ronnie, Tim, and others interested,
I'm sorry for not responding to you previously. This account is linked to an old email address of mine that I don't check, which is only setup for message boards. This is the main and only reason why I have asked to be PM'ed instead of emailed. Nonetheless, I have responded back to all of your emails. From here on forward, please contact via PM or the phone number that I have provided for you. I apologize for the poor response on my end.
Mike, send me questions via PM or PM me so we can set up a time to discuss. Same goes for everybody else.
Thanks!
Passed emissions today, in case any California guys are interested.
Nice car man...someone would buy my 325is to free up some cash!
Thank you fellas!
Just got the car legally tinted at 35% and also professionally detailed. Prior to that, I got a new o2 / oxygen sensor put it and also had the calipers and inner-rotors painted black.
I have most maintenance/upgrade records during my time as owner. I can send via PDF file to any potential buyers.
This thing is Eco-friendly (not really) and can PASS EMISSIONS!
UPDATED PHOTOS COMING VERY SOON!
15k?
"Lamborghini, the tractor maker, wanted to figure out why his Ferrari's clutch kept crapping out (PITA, cost a lot of money). He complained to Ferrari, and Enzo didn't do anything. Lamborghini discovered it was the same, much cheaper clutch used in his tractors. The rest is history..."
I just got done replying to somebody with a similar offer. I might as well show my reply because I've been seeing $15k a lot as of late.
Copy & Paste:
I've had several offers on the car, but all lower than I'm willing to accept at this point. The 2 highest offers I've had thus far were was one at $15k (from my long-time friend) and the other was $15.5k, both offers were for the car without the Fikse wheels / Advan tires (with the LTW wheels and balding Yoko ES100 tires). I declined both of these, along with the other several lower offers.
As much as I would like to sell, I'm really not in a hurry. For the past month, I've been just testing the waters and see what kind of responses/offers I would get. Last weekend, I had the car tinted (35%, nothing too dark, just a classy look on a black car) and professionally detailed. The weekend prior, I painted the inner-rotors and calipers black for a cleaner look. I even went the extra route of buying a new ///M3 emblem to replace the 14-year old faded badge. This upcoming weekend, a buddy of mine will be taking photos of the car with his SLR camera and I will be putting up on autotrader or cars.com to increase awareness.
I will brag by saying that this car is extremely clean, greatly maintained by an extra paranoid, anal owner, and modification/maintenance record history to show the THOUSANDS spent on this car. Keep in mind that my car has 73k ORIGINAL miles and ~5k on the fully rebuilt motor, less than 1k on brakes and tires, and ~15k miles on the suspension. All fluids have been changed out. This car is pampered!
If you buy this car, you will NOT need to touch anything. Every last thing has been replaced. The only thing you will need to do is oil changes. Spark plugs were just changed out last week as well.
very interested in your car, some how i cant sent you a pm, please email me at suprafabs@hotmail.com
thanks
