In getting ready to do my tranny service I re-checked my research on the Valvoline MaxLife ATF.
It seem they changed their formula and they no longer list BMW or the LT 71141 spec on their updated pdf... here is probably why the change:
From their 7/6/2010 spec sheet
"It is formulated with premium base stocks, unique seal conditioners, long-life friction modifiers, ..."
from the original one listed on e38.org (spec sheet dated 8/3/07)
"It is formulated with synthetic base stocks, unique
Until we can get a verification from Valvoline direct it seems that the Mobil 1 Synthetic ATF is the last one left that states compatibly.
Richard
Mods... this might be a good sticky if it pans out...
WTB: Dinan Spring set, for the 750iL
You work hard, discover that success is not a destination but rather a road you travel upon- mostly up hill. Then, after a while, people going down the other road look up at you, and they call you "lucky."
Haha! I never trusted MaxLife any how. I was looking recently and it wasn't on their list anymore. Hey everyone SWITCH or USE
Also suitable for use in vehicles that specify the following fluid requirements:
Audi G 052 025-A2, G 052 162-A1
BMW LA2634
Esso LT 71141
I have 4 gallon jugs and 5 quarts in the trunk of my 7 and all of them have LT 71141 on the label. There are even two different labels between the jugs.
Did they change their formula or lose the cert?
As long as it is listed on the label you should be fine.. That is what I used on my rebuild. I believe they switched the formula recently and you have the older synthetic version which works good..
Avenging Angel: 2001 750iL Sport Schwartz II Metallic, too many upgrades to list here..
Kirsa: 2000 750iL Biarritz Blau Metallic, Born on 11/99. Sold 12/21/13
The Mistress: 1997 744iL Biarritz Blau Metallic, Sold 6/7/12. You will be missed Baby..
I trust Mobil-1 anyway.. I use their oil too. Mobil-1 everything
Thanks for the heads up
Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
The two gallons I picked up, which I haven't used yet, both say synthetic and have the BMW LT 71141 spec on them. I'm sure there's still a lot of it out on store shelves but yes, time to read the label if you want to use it.
I called Valvoline this morning and they said that they changed viscosities, thus the new data sheet. He went on to argue with me that it still meets LT 71141 requirements. It was a long and hardheaded argument where apparently the info in front of him is different what we have available.
Personally, if it isn't on the bottle I am not going to put it in. What I have says it's good, so I am going to use it.
I used their contact form. what you want is an official signed letter on Valvoline letterhead that says that Valvoline has tested for and approved their current blend to meed the LT71141 spec. And that it would be covered under their fluid warranty.
Anything short of that is insufficient. Unless it's in writing it doesn't count.
Richard
I know...for this morning I was more interested in why the new bottles didn't have the spec, as long as it was a change in spec what I had was fine as it said it on the bottle.
You're making the assumption that they changed the label and the formulation at the same time. Who's to say they didn't have a couple of boxes of the old labels on hand and a floor manager decided it didn't matter and used up the old labels even though he was processing the new formulation?
I've got a gallon bottle (that has LT 71141 on it) and a couple of quart bottles that does not. I think I'm going to use it all for power steering fluid, or some other use, and get some Mobil 1.
Thanks, DarkStar, for bringing this up. I noticed the quart bottles didn't have the LT71141 on them when I bought them, but didn't think anything about it (It was MaxLife and the big bottle had it on there, so I just figured it was an issue with space on the label).
rp
Castrol is a good alternative. Been running it in my 5HP24 for 6 months with no problems and shifts very smooth and they list LT71141 on the bottle. <$5/ bottle at autozone etc
2000 750iL (12/1999)
Bone stock except...
BBA Reman ABS/DSC control module
By the way, I have heard no response from Valvoline....
Richard
I was wondering that today. It's almost like you were reading my mind!
And they know about this post... I put the link in the email contact form
Richard
They know...but it's doubtful that they care.
Is Mobil1 the only option out there?
(9/94, GF61, JPN: M60B40, ZF 5HP30, 3.15:1)
(5/06, FB53, US: N62B44, ZF GA6HP26Z, 3.46:1)
I was at the store the other day and there was one other brand that had our code on it...I don't remember what it was though. I do remember I would spend the money in a heartbeat for Mobile 1 in comparison.
Hopefully Valvoline will pull through and clear us to keep using their product. Options are good.
Is any other brand bad for the E38 transmissions?
Anything that does not have the LT 71141 rating.
So, Lubro Moly is a no go, then.
Methinks I'm gonna have to source some Esso LT-71141 ATF.
I stand corrected. Ha!
http://www.liqui-moly.de/liquimoly/p...id/e_3680.html
I noticed this too when I was trying to look for an equivalent for the A5S360R transmission in my E46 323i. I read the latest PDF and I saw that the MaxLife did not have the LT71141 BMW on it. Since it's fairly new, just look at the bottle and if its still the old-style ones with ESSO on it, you're fine.
Other alternatives are either Castrol Multi-Vehicle ATF and Mobil 1 ATF. Castrol is cheaper though.
