Its pretty well known in the M3 community that there is an issue with (primarily) intake-side VANOS gear bolts coming loose/shearing, ultimately failing, and potentially causing engine annihilation. It was originally thought to be only later S54 cars, but some as early as 2002 have shown evidence.
Rather than paying $6000 to have a tech R&R with all of the specialized tools, timing equip, etc., this is a DIY writeup found on M3forum for the mechanically inclined by member 'excessive' and a master tech friend with a cost of about $50 in parts, and no need for specialized tools. I took the original DIY and put it into PDF form for easy downloading and printing to have by your side while performing an inspection, and service if necessary.
BMW M3 - Ferrari 348 - Chevrolet Chevelle
Part 2 of the DIY attached....
2002 Alpine White w/ Black 368 (<OO \(||][||)/ OO>)
Power: Custom Exhaust w/ High Flow cats, CSL headers, built, low-compression Supercharged and aftercooled S-54, ViPEC standalone ECU, Vortech V2 Si trim
Driveline: Euro 6 speed, 3.64 diff w/ 40% Lockup, Rogue Octane SSK, UUC Red TME kit, UUC Stage 3 LTW Flywheel/M5 Clutch, SS Shift Knob
Suspension & Brakes: TC Kline True Match Coilovers 500f/500r w/ adjustable camber plates, Racing Dynamics sways, Custom front sway endlinks, ATE fluid, UUC/Willwood BBK 6 piston f - 4 piston r , Slotted E46M3 Rotors, Stainless Lines, Strong Strut, IE Subframe & adjustable rear trailing arm bushings
ICE & Misc: Projector Z's w/DDE & 5k HID, 19'' Gold HRE C20's, Custom Aux pwr outlet, footwell lighting, ACS Splitters, Areo Sideskirts, Custom gauge pods, Z8 Start, Pioneer AVIC Z3, Clarus Components, 10" RE Sub in a Mister-X Enclosure, Alpine PDX 4X150 + 1X600 Amps
Coming soon: and a visit to Randy Forbes
Thanks for posting.
Just an FYI, a member on M3forum.net found out that his cams had moved after the installation. So the DIY is still good but extra care needs to be taken to ensure everything remains aligned at TDC.
Thread here: http://www.m3forum.net/m3forum/showthread.php?t=330465
Is there a TSB on this problem, or the "new and improved" bolts?
~gs2gf
I just got the heads up on this from my mechanic. The early S54's have this issue, too.
phrider
2001 Titanium Silver M Roadster with hardtop
1998 Titanium Silver E36 M3 Coupe
Former cars: Saab 900 Turbo, Rabbit, 1967 Chevy II, 1951 Packard Ultramatic Coupe (0-60 in under 0.3 minutes)
You need to cam time when the vanos is in initial position.
If it were me doing the job, I wouldn't be installing any BMW bolts. I would be using a much higher grade bolt to replace as an extra safety net.
Matt,
I know you spoke to me about this when we did the Valve adjustment. What do you think is the typical time frame needed to get this job done?
Thanks for this!
Chris
2010 X5 4.8i, 2008 135ic (For Sale), 2002 996TT, 2001 D2
