NJ: BimmerClinic E36 LS2 Conversion w/ NAHR parts - pic intensive Progress Thread!!
Ok, this thread was a long time coming. I started a teaser thread some time back in the Regional Section of the forums, but since we are at full bore now, I’ll start a new one in the Conversion section.
By me (Central Jersey), there is a shortage of cool e36 engine swaps (at least that I know of). A while back I was interested in switching out the M50 in my 1993 325i with a S50 or S52 with low miles. I had hard time finding one, and a couple of deals fell through when I thought I had one. So I started playing around with the idea of throwing an LS engine in there. I had been going to Bill and Co. over at BimmerClinic in Elizabeth, NJ for a while and knew they were top notch, so when I approached Bill about putting an American muscle engine into the e36 he was all for it…I knew I could trust them as they have done both regular maintenance and modifications to my e36s for a while, and I know Bill is always up for a challenge.
Jeff getting ready to pull the S50 out:
Jeff, Brett and Mike from the BimmerClinic (Bill and Matt were MIA for this photo):
Early on when I started looking around for parts and a drivetrain, I was doing a lot of comparisons between the different LS engines, as well as the different companies that offered prefabricated swap kits for the conversion. I spoke with a couple different companies and I will say that one of the most impressive by far when it came to customer service and parts quality was New Age Hotrods. Joe at NAHR is one of the most knowledgeable I’ve come across when it comes to these builds; his e36 LS6 supercharged build is all over the internet and speaking with him his level of technical expertise when it comes to mating GM parts to BMWs was amazing. The guy knew parts numbers of the top of his head for both(!) The parts that NAHR offers are no joke, CNC’ed and BUILT to last. INCREDIBLE stuff, really. NAHR even offers a service where they can source a drive train for you, or if you’d rather, than can do a turn-key installation. I knew I wanted Bill and his boys in my corner for this, so I decided to get the NAHR parts.
I was initially on the hunt for an LS1 with a T56 out of the same car. Having talked to a few guys and doing some reading I started to get pretty interested in the LS2 and LS6 for the extra power it could provide in stock form. I ended up with an incredible deal on an almost new LS2 except for the fact that it didn’t have a tranny attached to it. Since it was so new, I decided to purchase a brand new Tremec T-56 Magnum 6 speed tranny.
(Yes that is a vintage 2002 series in the background)
The NAHR parts started to roll in (these are not all the parts, just the mounts. More came in but I couldn't photograph them and the bigger parts - stainless headers, drive shaft, etc are being brought when NAHR comes down to help with the project):
The guys at BimmerClinic started to gut my car, and went the whole nine yards from there. The car was really clean to begin with, but any small indications of rust starting was stopped in its tracks and treated. Seam sealant cleaned out and new sealant meticulously laid down where needed. Rust proofing treatment on the entire underside. Thermo-Tec barrier will be laid down once test fitting is complete.
Jeff just wanted me to add this picture so the girls could see his herculean arms:
Any Good parts that could be salvaged off a donor M3 (for added support and durability over the 3 series parts) were cleaned, treated and if it would enhance the appearance, color matched with epoxy paint for use in the 3 series.
Now since we started laying the ground for a no-holds barred build, I started to stock pile all the parts for a killer e36. With Bill's help, we ordered all new OEM M3 parts, or if a superior aftermarket part was available, we ordered it. For example -
· Bilstein PSS-9
· Ground Control adjustable Rear Arms
· Turner adjustable front sway links
· Eibach sway bar kit
· Powerflex bushings
· Rogue Engineering rear shockmounts
· Perfection D2 Performance Clutch and Flywheel for the T56- Magnum
· Porsche (Brembo) BBK on all four corners with E46 M3 CSL rotors (thanks Eric @ Rallyroad.net) with Stoptech SS brakelines
That’s just some of the stuff, but you get the picture…
I’ll be moving my BBS RSGT’s onto this car as well.
I’m sure Bill will be glad when this project is over…he will have a good portion of the BimmerClinic real estate back.
Test fitting of mounts, engine and tranny has begun. Look at the beefiness of the NAHR parts- CNC'd aluminum and built like a brick f'ckn house...the engine and tranny are going NOWHERE once final mounting is done:
Joe and his brother Josh, the heart of NAHR, will be coming down with some of the bigger parts such as their newly offered stainless steel headers, fuel line conversion kit, and some other choice pieces and will be helping out the BimmerClinic team while they are here. They’ll be lending their expertise in the wiring and programming as well, and I'm sure to get more pics of their visit and update this thread...
Anyhow, this thread will be used to document the work that is going into this build. MUCH care and attention is being put into this project from BimmerClinic, and New Age Hotrods has been incredibly helpful and is slated to come down so they can get their hands dirty on this project too. This is all new to me. Though I’m pretty familiar with the e36, I’ve come to find that the conversion to the LS1 is a very different beast. Most of you guys who frequent the Engine Conversion section of Bimmerforums know that mounts, cooling system, fuel line, drive by wire, etc all need to be switched out when you transplant the LS2. Without saying, Bill and the boys at BimmerClinic are experts with the Bavarian side of things, and Joe is helping out with the Chevy side of things. I’m trying to keep things together with all the efforts that are going into this, and I know the BimmerClinic crew and NAHR Team are always incredibly busy with all the other projects and work they got going on. But this promises to be one kick ass ride when it’s done….Bill is even going brainstorming for a bad ass custom exhaust. I’ve sort of given him free reign to challenge himself and really put his skills to the test on this one. I can’t wait to see what happens.
For reference, I’m hoping to get somewhere in the area of 650 HP out of this when it’s done, with the help of a supercharger (if I can afford it) and a tune. Don't undersestimate these American engines though, even bolt on mods have a much greater effect on the American V8's than they do on most of the European stuff. You guys in the Conversion section know that already tho. I plan on showing the build at some shows, and also being raced a bit on the drag strip (not the street). The car has always been babied since I had it, but now it’s going to get a full makeover inside and out.
This thread is being created to document the build – all of the care that BimmerClinic is putting into this and build with top shelf e36 parts and the unmatched conversion kit and technical expertise on e36 LS swaps that NAHR brings to the table. For those of who are reading this section, hopefully this will give you an idea of the amount of detail and attention that NAHR puts into their stuff, and for those in the Northeast, this thread will prove that Bill and the boys at BimmerClinic really put everything into their work and stand behind it.
Stay tuned for more to come on this conversion, it will be updated as the build progresses…it promises to impress.
_________________________________________
