Page 3 of 8 FirstFirst 12345678 LastLast
Results 51 to 75 of 179
Thread: E21 racecar build....hopefully a loose Grp5 replica
  1. #51
    Nov 2007
    Orlando, FL
    1982 320i
    Here are a couple of examples of work done with urethane foam. This is a project done for a theme park ride car.
    A fantasy 57 Chevy. A computer model was made and sections were extracted and cut on a CNC router, then stacked and finished prior to making a mold.
  2. #52
    Dec 2007
    AZ
    98 318 Ti
    CNC router is the best
    Quote Originally Posted by davidgoerndt View Post
    Wow cnc router is the best way to stacked save money in the long run
    and much cleaner !!!
    VERY COOL FANTASY 57 CHEVY
    James
    My M30 carb intake
  3. #53
    Nov 2007
    Orlando, FL
    1982 320i
    Our company has been using this method of sculpting for the past 10 yrs. It saves the sculptors from having to waste time roughing in a shape so they can get right into the fine detail.
  4. #54
    Oklahoma
    996, 914, X5
    thanks to your prodding, David, I did buy a bunch of 4x8' foam sheets, stacked and glued them together to make a 6" thick section, and I'll start carving away in the next few days.
    photos to follow......
  5. #55
    Kansas City MO
    Too Many
    Subscribing
  6. #56
    Carson California usa
    1986 e30 325
    Wow Cant wait to see how would look
    keep up the good work
  7. #57
    Norfolk, Ct
    95' cruiser, 83' 320
    they are out there
    BMW Schnitzer 2L Race Engine
    Condition: good condition "needs rebuild"
    Price: $8,900 USD
    Description
    This is a complete engine out of a Group 5 touring Car, it is designed like an F2 engine with the difference being this is wet sumped. It can be converted to a dry sump setup with no problems. History
    This engine ran in group 5 GS Team BMW 2002, it is in good shape but, has been sitting for years. Specifications:
    • 1999cc 16V twin cam
    • 275 HP
    • Kugelfischer F.I.
  8. #58
    Tulsa, Oklahoma
    e46 325i
    This might help
    Just wanted to let you know that there is a go-kart race track near Tulsa and the guy that owns it has several E21 race cars. He was selling them a year ago. Here is a link http://www.jrpspeedway.net/Home_Page.php
  9. #59
    Oklahoma
    996, 914, X5
    cool, thanks. Looks like Alf Gebhardt. One of his old cars races at Hallett regularly.
    still waiting on my chassis to finish acid dipping in Dallas, so the project is on hold until I get it back.
  10. #60
    Oklahoma
    996, 914, X5
    After 8 weeks and $1650 US, I picked up the chassis from Dallas. It's amazing how clean it is now! Even more amazing is that some of the chassis sealer is still in the seams...hardened and brittle, but it's contaminating some of my welds now that I'm stitch welding the chassis seams.
    the car was overall in excellent condition, with no rust except around the bottom of the windshield frame, the battery box (couple of pinholes), and the driver side floorboard beneath the pedal cluster (slight pitting in the sheetmetal).
    as mentioned, I am now stitch welding all the chassis seams, and will begin work on the rollcage and the fuel cell cradle soon. The fuel cell is a 15 gallon ATL with aluminum can, and date of expiration is good for another 2 years.
    I purchased a weld-in rollcage kit from Kirk Racing. It leaves something to be desired, especially in the A pillar down tube. I'm going to have this revised to make the down tube hug the A pillar.
    And finally, thanks to all of your recommendations and input, I decided to go with a normally aspirated 6 cylinder S50B32 from Europe (Evo M3 motor). It's heavy, but the weight will be offset by the power potential and the reliability, not to mention the simplicity from avoiding a turbocharged engine. Thanks to gobuffs on the forums for selling me the motor at a reasonable price
  11. #61
    monterey, ca.
    e21, e30 m3. e46 330ci
    one of the weak points is the base of the "B" pillar. any E21 driven in anger will have crack the paint there. i have had both of mine brazed over the years.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
  12. #62
    Oklahoma
    996, 914, X5
    I was planning on mounting the main hoop on the ledge next to the rear seat, and tying into the rocker panels, similar to what was done here:
    http://forums.bimmerforums.com/forum...63&postcount=1
    Are you referring to the floorpan/Bpillar connection?
  13. #63
    St. Pete, FL
    83 320i,02 325i, 04 x3
    just tuned in to this build thread. all i can say is wow. its looking sweet. cant wait to see what the finished project looks like
  14. #64
    monterey, ca.
    Quote Originally Posted by jmitro View Post
    the base of the B pillar at the window sill. this could be corrected by tying the pillars to the roll bar. the seat belt anchor would work.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
  15. #65
    Oct 2005
    Dubai
    e21 race 320i road
    I Can get the evo ecu reflashed so it runs standalone
    Jason
  16. #66
    Dec 2007
    AZ
    98 318 Ti
    Seams...hardened and brittle, but it's contaminating some of my welds now that I'm stitch welding the chassis seams.
    YOU NEED TO BRUN THAT CRAP OUT !!!
    James
    My M30 carb intake
  17. #67
    Jul 2010
    Granbury, TX
    1982 320i
    Quote Originally Posted by e21Jason View Post
    Jason
    So you can't just strip off the BMW ECU and install standalone on a late model engine like that? Is that because all of the ODB stuff and Immobilizer would brick the car or something?
  18. #68
    Oklahoma
    996, 914, X5
    Quote Originally Posted by jimjim69 View Post
    suggestions? propane torch?
    it's really not bad; only a few isolated areas where it's bad enough to contaminate my welds. I'll post a photo comparing a clean weld and contaminated weld.
  19. #69
    Corona California
    79 320/6 81320i 65malibu
    Looking great jmitro, I've been thinking of doing the deep some day. You body looks in really great shape!
    Looking forward to seeing where you go with this. Adam and I are getting ready to make a few more mods to the track car this year. So we have found that our current weak points with the car are the slow steering and the brackets. Thinking of installing a Z3 "1.9" power rack if we can find one. Need to get some measurements off of it.
    Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
  20. #70
    Dec 2007
    AZ
    98 318 Ti
    Lightbulb Wow this is your GOAL !!!
    A propane torch works the best way!!!
    LOOKS VERY COOL
    James
    My M30 carb intake
  21. #71
    Herriman UT
    81 323i 86 535i 08 335i
    How did you have the body cleaned up like that? Soda blast?
    Edit: Acid dipping. Why not go with soda blasting?
    80 B6, 81 & 82 323, 85 745i, 86 535i-all euro. 01 750iL Blk/Blk 08 335i
  22. #72
    Oklahoma
    996, 914, X5
    i've read multiple times that no blasting method (soda, shells, sand, etc) would get through the undercoating and seam sealer; so to get it really clean, it was either spend hours and hours eating away with many, many wire wheels, or pay $$$$ for a super clean job.
    I felt like my time was worth the $1600 it took, so I chose that route.
    LOOKS VERY COOL
    yes, that is my goal.
    Quote Originally Posted by OLD MAN View Post
    thanks for the tip on the steering. your car has been a source of inspiration and information for me.
    yes, the body was in really good shape. Thanks to southern weather I guess
  23. #73
    Portland, Oregon
    E39 Touring, E53
    Subscribed. Are you gonna need those tail light lenses? I know a guy in need of a decent set
    Bucket
  24. #74
    Jun 2005
    Texas
    E21, E24, E34, E46
    The Z3 rack goes in front of the axle like an e30 (in fact I believe it can directly replace the e30 one without modification), which means even if you did fit it to the e21 the steering direction would be reversed. If you could source a RHD one and flip it over, then you might be on to something.
    WOW! That acid dip is amazing. That was a really clean shell to start with.
  25. #75
    Corona California
    Quote Originally Posted by Layne View Post
    Adam has an E36 rack for his E30 he has not put in yet, we will look at it this weekend.
