Hello everybody,
i know this is not the right forum / thread but may i get some help to re-program my 2002 X5 from Canada to EU specs. Xoutpost doesnt give me any help so far.
I have an IBM T30 with DIS V.43, Progman V.28 and yellow head. So far i was able to activate / deactivate several things, read and delete fault codes, change settings and so on.
Under Progman the only option to change i have is the Region: Canada or USA.
Any idea if it is possible with my Soft- and Hardware or do i need another software like NCS expert to do the job?
Mainly i need to deactivate the Sidemarker (there are stady on) for EU Registration / TÜV.
Many thanks in advance for your help.
Thomas
change the 4th digit of your GM string from a 3 to a 1, and recalculate the checksums.
OK, and where?
With Progman or NCS expert, have no clue how changing digits and do a checksum recalculate, sorry.
Thomas
how can you change language in ie. E39? i have inpa and DIS working...
Use NCS Expert.
Load the expertmode profile. Hit "VIN/ZCS/FA". Press "ZCS/FA f. ECU". Pick "E53" and choose EWS as the module. Hit okay and it will read the ZCS from the car. Now click "Enter ZCS". Select E53 and hit okay. Leave the VIN as is, and hit okay. Now you'll have a menu where you can edit the GM, SA, and VN strings
In the GM, the change the 4th digit to a "1" (if your car is currently coded as a US model, it'll be a 3 by default). Delete the last digit in all 3 lines. Click the "calculate checksum" box. Hit okay.
Click back. Click "process ECU". Pick the EWS. Change the job type to "ZCS_SCHRIEBEN". Click "execute job". Click "SG/SGET." Pick the KMB (or KMBI). Execute the same ZCS_SCHRIEBN job.
Now hit "Zur". Hit "VIN/ZCS/FA" again. Hit "back". Hit "process car". Let NCS Expert do its thing. Once it's done, every module should be coded to their European defaults.
I finally got around to getting the region changed.
My us region gm was 616300005 country code bn53
Ended changing it to it's bn51 equivalent which was 616100003.
Not sure why it wouldn't take 6161000005.
Probably because the last digit is used as a checksum.
Basically the 4th and last digit had to be changed.
Either way dis reports my car as being an eur_lhd model.
The Zeko tool was a very helpful tool in figuring this out. I was also able to change the production date.
this pepsi, from New Zealand. now i really got head ache about progamme my E60, and really need to you help. i have my japan imported E90 2005. and it only have japanese radio station, i read some on wed, so i brought ops with works with laptop. but i can't find out how to make it works. if you can help me, i am realy grateful, and i even can give the bonus .
cheers
Well currently I'm actually in central PA for school, though I sometimes go back to my parents' house on weekends. Sometimes I even head up to the Long Island area for other personal reasons... so we could probably figure something out.
But what car are you trying to figure out the region change for? If it's the E60 in your profile... well that's a special case, because the E60 535 was never sold outside of the US and Canada. You can still recode most modules to the European settings though.
I know how to do it through NCS Expert, but I'm unsure on how to get an OPS head to interface with NCS. If you can take care of that part, I can guide you through the rest...
i am trying to do this on my 02 E39. i have gotten a fair amount of the way through TerraPhantm, but am running into problem with this part of the instructions.
i have figured out that SG/SGET is Change ECU. i do not seem to have a KMB or KMBI to choose from in the next step. which module from the list should i choose for the E39?
thanks,
G~
Damn, every time I try to do this it gives a Cooapi error on a 06 Z4.
Mine is
ZCS GM : 65633813W
ZCS SA : 00002A4807B810687
ZCS VN : 00006406201
Changed it to 65613813 and deleted it the last digit from all three lines and checked checksum calculate.
it took it and changed it to 65613813U and other 2 lines were the same last digit like before, but when I hit back it gave me Coapi error 1000, and it wouldn't proceed!!!! any Ideas???
Thanks in advance!
Please post full error. 1000 error can be different. It can be ecu error or zcs faulty, etc.
HI
i have an m3 e46 US Version
i live no in germany and i have to code it to ECE, EU
can you help me?
i have coded several settings like, "peep on close" etc
hi:
TerraPhantm, do you have the email, or you can email me : nzautopartz@gmail.com.
thanks very much
