Hi this may help is from US 2001 e46 cabriolet
Prefacelift LSZ Comparison
Made an excel sheet comparing the US and Euro LSZs from the prefacelift E46... It's a similar file to the one I made for the facelift models. There are a couple parameters missing from my Euro list, but I think setting all of them to ece should do the trick (you'll see what I mean). Theoretically the corner delete is somewhere in there
My 2001 M3 does not have a sidemarkers_us option. Would it be possible to add it to the FSW_PSW file and write it with NCS Expert? For reference, this is my LSZ file.
No, it is based on the coding index of the module. So at best it will ignore it or at worst throw an error.
Changing the following settings:
SL_VO_ANSTEUERUNG
aktiv (from nicht_aktiv)
FERNLICHT_DRL
nicht_aktiv (from aktiv)
EINZEIT_DRL
wert_01 (from wert_02)
had the following effects on my car:
1) DRLs are disabled, just like I wanted
2) Corner parking lights do no turn on in position one, but still turn on with the headlights. This is pretty much the opposite of what I wanted.
I will play around with PROGRAMMPARAMETER_LSZ to see if I can fix that. I'll also try swapping SL_VO_ANSTEUERUNG back to nicht_aktiv to see what effect that has.
Sorry to bump this thread, but if I just want to change the LSZ to euro settings, do I have to change the region on the AKMB as well? Or can I just write it to the LSZ and everything will be fine.
Yep that should do it. Just make sure that the profile you use doesn't have manipulation enabled.
Also just so you know, having the euro settings will generate some bulb-out errors. This is because US-spec cars aren't equipped with the european-style parking lights (the so called "city lights"). You can disable these warnings via NCS expert
Just curious but which profiles don't have manipulation enabled?
I was still able to get what I wanted done, but I did it a different way. I erased all the info info in the psw file and then coded the LSZ, after that the bulb out error showed up. I then edited the PSW File and disabled the error by setting both CC_standlicht values to nicht_aktiv.
Awesome stuff. I was wondering something. My windshield was replaced with a regular wind shield without the rain sensor. This was done by the previous owner. Now when I try to run easydis v44 it gives me an error when trying to read all the modules. Basically it can't read the RLS module sense I have no rain sensor. I know you can edit the VO so I tell the car it doesn't have a RLS anymore. But how? Please help. I've been looking for a month now. no answer
Hi all the FA for your car are in ncsexpert/daten/e46zst.000 file the Regensensor is 521 so you will need to remove this from your VO ....
I responded to you in the other thread... here's that response.
Are you willing to use NCS Expert? If so do the following:
1) Load up expert mode
2) Read the FA from the car (from either the ALSZ or AKMB modules)
3) Hit "Enter FA" - verify the chassis is correct along with digits 10-17 of the VIN (first 10 dont matter, 18 is a checksum)
4) Now there'll be a list of codes. Find "$521", highlight it, and hit delete
5) Click ok, and then hit back.
6) Click process ECU, and select AKMB
7) Change job type to "FA_WRITE"
8) Hit execute job
9) Press SG/SGET, and select ALSZ
10) Change the job type to "FA_WRITE" if it isn't already
11) Execute job
Optional) Recode the GM5 so that you have proper functionality (intermittent wipers)
You've successfully removed the rain sensor from your VO if you did the above properly. DIS should no longer complain. If you ever add the rain sensor again, do the above again, except this time you'd be adding $521 instead of deleting it.
I don't know how to change VO through DIS, and from what I understand it's a lot more complicated.
Hey Thanks for that detailed response. I almost was able to do it today but I ran into a small problem. On the change job page, I did not have FA_write or FA_read. I've looked at some other pdf's online on how to do all of this. It was exactly like you described. I'm running NCS expert version 3.0.8 in expertmode. I'm going to see if there is a newer version out there. Everything else worked out ok so I don't know why my list of jobs to execute is missing some jobs. Ty again for the help.
Well i tried it again later on and was able to FA-write both the akmb and alsz. I didn't mess with the GM5 module. WAsn't sure by what you meant about proper funcionality of the wipers. Can you tell me what you meant. Thx.
Will changing the region of the car from US to Europe affect the DME at all? Things like engine mapping and power since Euro M3's have different ECU mapping?
It seems that the software uses something else to determine the appropriate DME flash. I've tried combinations of US and Euro VOs as well as SMG and non, and I couldn't get it to prompt a different software for the DME. I suspect one would need to know the euro flash number and input it manually, but I dont know which ones are which.
I'm looking into doing this however in Real oem It gives me two region and codes
BD51
BN51
If I type in my last 7 digits into Real oem it spits out bn51 after I change it to euro. What would happen if I choose BD51?
Process is different for your car. Your's is an 01 so you don't even have a VO. ZCS instead. You have to modify the GM string... (generally you just change the 3 to a 1 and let NCS expert recalculate the checksums for the GM, SA, and VN lines)
BN51 = prefacelift 330ci, BD53 = facelift 330ci btw.
If anyone wants to remove or add country specific settings (like Canada $838) see if your VO has any of these codes listed and remove them. Then "default" your entire car in NCS.
L801A National version Germany/Austria
L801A NATIONAL VERSION GERMANY
L802A National version Korea
L804A NATIONAL VERSION SWITZERLAND
L807A NATIONAL VERSION JAPAN
L808A NATIONAL VERSION ISRAEL
L809A NATIONAL VERSION DENMARK
L810A National version Australia
L811A National version Belgium
L812A National version England / Ireland
L812A NATIONAL VERSION GREAT BRITAIN
L813A NATIONAL VERSION FRANCE
L814A NATIONAL VERSION ITALY
L816A NATIONAL VERSION EASTERN EUROPE
L819A NATIONAL VERSION SPAIN
L820A NATIONAL VERSION LATIN AMERICA
L821A National version Egypt
L822A GULF VERSION
L824A NATIONAL VERSION SOUTH AFRICA
L827A NATIONAL VERSION SCANDINAVIA
L830A NATIONAL VERS. NORTHERN COUNTRIES
L833A country specification, Singapore
L838A NATIONAL VERSION CANADA
L846A Country-specific version Taiwan
L8AAA National version China
L8LAA National version, India
2 informations i just need to get rid of:
1. for changig your GM/VN/SN values zeko-zcs works like a charm (for calculating the needed value)
2. changing an mk3/4 navi language can be done via INPA, no need to get an ibus interface and navcoder...
Just typing this because the internet is sooo useless at this point if you're trying to find the needed informations, i coded the WHOLE car via progman to get the right language on it, but no, just inpa and a firmware cd needed...
