Hello
I am searching for a DIY to replace a leaking shift shaft seal.
I ordered the shift shaft seal but the part description says "23 12 1 228 443 shift linkage seal". Is it the same as the "shift shaft seal"?
Courtesy of BobC over @ Bimmerfest
And to answer your question I would assume yes. I've heard it called selector rod seal, shifter/shift link seal. BTW where did you get that terminology for it? "shift shaft seal" man I can't even say that! Well anyway good luck with changing that shitty shift shaft seal son lol
Well if you continue to use it do it very very slowly or there will be hell to pay lol. Are you looking for a seal for the Getrag?
No DIY write ups from me, but I replaced one just about a week ago.
There's not much room to remove the original seal without damaging the surface of the shift rod, but the seal bore is deep enough to push the original seal in, and fit the new seal "on top" of the original seal.
It was a major pita to pry the seal out and put the pin back in properly. Other than that, the other steps were straightforward.
Next time take Randy's advice but glad to hear you got it done. You didn't score the rod any getting out the old seal out did you?
You should be able to that in situ. Again, my recommendation is to push the original seal further in and apply the new seal in addition to that one.
I think it's unlikely, based on the cars I've seen, that the output shaft seal is leaking. I'm positive that it too could be replaced without pulling the xmsn, though I have not tried it.
Phil would need to clean the transmission up pretty carefully before trying that, I think. The output flange requires heat (ZF specs 90 degrees C, I think) to allow it to be pulled off the output shaft. To me, that would mean putting a propane torch on it. Since his transmission is covered in oil, that could be a dangerous proposition when under the car.
