I just posted this in Jason's Cooling System Bleeding thread in the DIY section.
posted in the DIY as well,
Well my first initial look at this question is that it may have something to do with the water valve in the latent heating system, in the older cars the heater core appears to be a side loop off the main loop, in the later cars, all flow from the expansion tank(where you add the coolant) seems to feed through the heater coor, it is also possible that the flow of the auxiliary coolant pump valve configuration actually reverses the flow through the engine/ heater core which would be counter productive to bleeding the system. I will look into this further as time permits to gain a better understanding of the flow pattern and the behavior of the water valve.
As to your question I suspect it is possible, however I am inclined after observing 2 other people use this method to believe that it may be a question of not filling the tank properly rather than one of the flow. Both people I observed seemed surprised to have to fill the tank as high as they did during the bleeding, another seemed to feel this was a static procedure(IE fill once and all the air came out) after a little explaining I got them on the right track. This is part of why i wanted to prepare a video so people could actually see what they were supposed to do when they added coolant and what it would look like when the system was blead out which is a little difficult to explain in words but makes a ton of sense when you see it done.
>'97 528i, 200000 miles, Hella Xenons, 17" Stilauto wheels, Vogtland Drop Springs, Dynomax Race Muffler, Homelink, 540 brake upgrade, 15mm spacers >'65 & '74 MG Midgets BFC OT Lego Club #48 Manual conversion in process!!!
Thanks for your response Jason.
If it's important enough for the Bentley to mention it, I thought the warning might need to be included in your original post as well as my thread on this topic.
I received a PM from a member, who will remain anonymous until I get their approval for the qoute, about their experience regarding the latent heat pump.
If the above is accurate, perhaps the flow isn't reversed by the pump.Originally Posted by 82bmw633
Edit: approval obtained.
The pump I am referring to in my initial response is mounted at the bottom on the radiator shroud on the driver's side. I am assuming this is the latent heat pump. When I refilled my system I turned the heater controls to full hot and the fan to high. The pump ran when I turned the key on without starting the engine. I could hear the coolant trickling through the expansion tank. Once the radiator was filled I started the car and bled the system using the bleed screws on the expansion tank and the upper radiator hose (from the thermostat).
I had also raised the front of the car so the bleed screw on the upper hose was the highest point of the cooling system. Simple process and never had any air trapped in the system.
If the pump I an referring to is not the one in question, my apologies for any confusion.
