Results 1 to 25 of 60
Thread: E46 control arm in an E30 :)
    fairfax,va, usa
    2 E30s and a maxima
    I got bored. lol.
    More info here: http://e30performance.info/viewtopic.php?f=23&t=1165
    mach 2 with my hair on fi
    many
    How is the spindle location any closer to the front by any chance?
    B.
    1991 bmw 325I <e30>
    First 8 second full body BMW with BMW independent rear suspension in the USA
    8.69 @160mph in a 1/4mile on slicks.
    drag radial tires record holder9.53@148. Also a world record holder for bmw overall 60-130mph 4.2 seconds.
    Bistein sport susp,turner sway bars,3:25lsd,m52 AEM INFINITY stand alone. MORAN 2500cc injectors E85 ,front mount 33x12x4 intercooler, 5lug conversion M3 front,Mcoupe rear Dss axles/driveshaft ATI Proglide.
    2003 Ford Expedition
    1998 M3
    1986 Mercedes Cosworth 190e 2.3 16v 5speed (sold)
    fairfax,va, usa
    2 E30s and a maxima
    looks like it to me. But I also have the THR lollipops.
    many
    Sh*t i can see tha caster a mile away.That is money for e36 5 lug just have to come up with the sway mounts! what e46 is it from?
    B.
    1991 bmw 325I <e30>
    1998 M3
    fairfax,va, usa
    2 E30s and a maxima
    5 lug swaps put the sway links on the struts. So that's solved. I have to retrofit them onto the E30 strut ala E30 M3.
    It's generic E46 stuff. Not E46 M3
    many
    are u going 5 lug?if so i have the 318ti stuff on my car i am getting ready to ditch for z3m stuff..Let me know if you can use it.
    B.
    1991 bmw 325I <e30>
    1998 M3
    fairfax,va, usa
    2 E30s and a maxima
    Nah. I like finding rims thanks
    Marietta, GA
    06 Impreza Wagon
    so you did just grind it down?
    fairfax,va, usa
    2 E30s and a maxima
    then sandpapered it smooth. Yes.
    It was actually easy with an angle grinder. Just checked it now and then. It's almost perfect.
    Sep 2008
    Forest Hill, MD/ KOP, PA
    95 1jz m3
    Please let me paint your car
    ps. I love it.
    fairfax,va, usa
    2 E30s and a maxima
    looks are secondary to driving right. The car is getting painted soon. I always say that tho...
    Sep 2008
    95 1jz m3
    Quote Originally Posted by protomor View Post
    Yeah I hear that. At one point I had a green nose panel black hood and a green trunk, but she purred. Going to hyperfest this year?
    fairfax,va, usa
    2 E30s and a maxima
    I believe so. I should be ass kicking by then.
    Jul 2006
    USA
    4 m52s,m50,m20,s52
    Quote Originally Posted by djborya View Post
    B.
    What do you want for it..im looking for a 5 lug setup.
    Cheif Senior Hitman Engineer 1st Class
    BfcOT Mafia
    Marietta, GA
    06 Impreza Wagon
    which tie rods?
    have you adjusted the camber out with camber plates up top?
    which exact control arms do you have? e46 m3? e46 ix? e46?
    fairfax,va, usa
    2 E30s and a maxima
    I used stock tie rods. my spacers give me enough room that I'm ok with it. over 1/2" of threading and toe is visibly decent. If you don't have the spacers, you'll have to double up with E34 tie rods. Like this:
    I haven't @#$% with camber yet. I just finished fabrication for the sway link and got everything together before rain found me.
    I used stock e46 control arms. No M3, no IX. Regular.
    Orlando FL/Englewood NJ
    dakar m3/4,e46ci,e36 rac
    what do u mean by dubbleing up on the e34s? are u using the stock e30 iners& the e34 mid & outers? or just stock e34s?
    also dou know of any "off the shelf" tie rods that r allredy the right lenth ? just cuz im planing on getting all new tie rods & i really dont want to have to get 2 different sets . that cost to much lol
    Fello Ambivero
    fairfax,va, usa
    2 E30s and a maxima
    E30 inner tie rods and E34 "tie rods" with the reverse splined ball joint on the other end. It's cheaper if you buy them with both ball joints on them though. You cut off the stock outer tie rod with about an inch of threading on it, then thread it into one side of the E34 tie rod. Tada! loads of length. Then it's up to you to cut them to length.
    Orlando, FL
    E36, E46, E53, GTV
    Looks like it will work! That tie rod situation is a little shady, but hey if it works it works! So I assume you will be modding your knuckles? That is the only reason to do this.
    www.ienjoydrifting.com
    2001 BMW 3 Series Sedan - 700hp/700tq M52 Drift car.
    Marietta, GA
    06 Impreza Wagon
    Quote Originally Posted by ienjoydrifting View Post
    i rub with just tie rod spacers.
    fairfax,va, usa
    2 E30s and a maxima
    Quote Originally Posted by Dominic49 View Post
    +1
    Orlando, FL
    E36, E46, E53, GTV
    you must have a high offset or wide wheel or both?
    fairfax,va, usa
    2 E30s and a maxima
    I ran 225/40/17s with ET 20 17x8s. but I ran 30mm spacers and still hit the frame/swaybar. The tie rod spacers are only 5mm. I'd love to mod my knuckles but even now I have fitment issues.
    The new setup that I'm running still uses 25mm spacers but I have about an inch before I hit anything.
    Marietta, GA
    06 Impreza Wagon
    205/50-15 on a et23 15x7 with 30mm spacers
    i found the solution
    e36/e30 brackets are 60mm it just so happens that turner makes a bushing specifically for the early style 60mm e46 brackets...
    E46 (Not M3) Delrin Control Arm Bushing Set
    Part #: 31126757623D
    Applications: 1998 - 2005 (E46)
    A solution to the inherent flex associated with the stock rubber parts. This bushing set offers stability that you will immediately feel under braking and high corner load. The car becomes more responsive, turn in is improved, and tire scrub is reduced. This kit is delrin and aluminum so it meets the Grand Am Cup rules (We use them on our Cup 330i) **Requires early 60mm Brackets or E46M3 Brackets **
    Price: $112.00
    http://www.turnermotorsport.com/html...D=31126757623D
    fairfax,va, usa
    2 E30s and a maxima
    That just slips over the hexagon shit?
    I'm not 100% it will work. I had to grind down pretty far on my control arm to get the distance right.
