Details:
EAC is proud to announce the official release of their new E39 EAC Coilovers. The EAC E39 coilovers include many features only found in more costly kits. These are, by far, the nicest coilovers you'll find for the same money.
The coilovers feature independent height and travel/pre-load adjustments. With this feature you are now able to raise and lower you car without changing shock/strut travel or spring pre-load. This also allows for very extreme adjustments. You'll be able to lower and raise the vehicle to dimensions far beyond what other kits offer.
18 dampening adjustments are also standard features. The dampening adjustments affect both rebound and compression. Rebound and compression are not independently adjustable.
Front and rear mounts are included. This allows for faster and easier installation without the need for moving factory pieces over to the new coilovers. For those wanting more camber alignment, front and rear camber plates are available as an option. You can purchase only front camber plates, only rear plates, or both sets.
Spring rates:
Front - 7kg
Rear - 6kg
Warranty:
Limited Lifetime Warranty to the original purchaser.
Applications:
E39 525 Sedan
E39 528 Sedan
E39 530 Sedan
E39 540 Sedan
Touring applications to be tested.
Pricing:
Coilover kit - $1250
Front camber plates - $165
Rear cabmer plates - $135
Purchase info:
http://www.eactuning.com/eac-e39-coilovers-p-540.html
Thanks!
Jared
Website:
http://EACTuning.com
Phone:
800.208.6448
PM:
jnyost or mark@eactuning
Email:
sales [at] EACTuning.com
(broken to prevent spam bots)
News, specials, parts lists:
http://content.EACTuning.com
"If everything seems under control, you're not going fast enough. - Mario Andretti"
So are you putting a pre-order list on this thread or making another for that?
Thanks, and good work Jared!!
There is a pre-buy link in the first post of this thread. Place your order there to be included in the pre-buy. There will be no other list.
I'll be looking forward to your feedback.
Thanks!
Jared
dammit, if i knew they were gonna be this cheap i may have waited!!
bump for a great deal!
Subscribed and proud indeed!
I'm crying inside these look beautiful
just out of curiosity jared, isnt the rear camber already adjustable on the E39 chassis, so what is the need for a rear camber plate?
That is correct. Front camber plates are definitely the most commonly purchased option and I only listed the rears because a couple people requested them. Some use them to zero out as much camber as possible for increased tire wear, while other use them to get a lot of negative camber so they can tuck the tires a little easier.
Jared: did you get my PM? I know you're busy, so maybe you haven't had an opportunity to PM back.
Replied.
Pre-ordered for a Touring. Can't wait. I'll let you guys know my impressions when I get them on in a month or so.
Thanks Jared!
So, who's testing the Touring set?
BMWCCA #389756
e39 Touring SOLD.
+1^^ I need new suspension for the Touring.
Whole order in a month. It took several months to get the test kit. Now that we've turned loose production it is a 3 week turn-around with no way to get anything faster.
These will not fit the M5?
997 Carrera 2S..the choice of 2 out of 3 Top Gear presenters.
