pretty!
i guess ill wait to buy coilovers till more details are out on this one!
independent height and spring pre-load adjustments, rad!
also, it looks a little like a KYB damper and/or Tanabe spring/mounts
I am interested in the feedback, of course...!
This could be the remedy for my wife...
I definitely need the camber plates though!
Mmmmm...looks tasty. I might be in on these. Im with newton...how can I should off the anodized finish?
"If everything seems under control, you're not going fast enough. - Mario Andretti"
I know a manu. that looks exactly like those. I'll hold my guess to myself.
sooooooo when are these gonna be out? like ASAP
They look solid. Can't wait for stats, such as lowering and adjust-ability!
VERY cool. Too bad I already pulled the trigger on c/o's.
What are the chances of selling the camber plates separate?
Last edited by Jason5driver; 03-26-2010 at 10:54 AM. Reason: Automerged Doublepost
For the camber plates, it somewhat depends on how many people choose to purchase the coil overs without them. We didn't plan on bringing them in as a separate item. I may consider it though.
You just need to do what turner has done for the e36/46 crowd and build race application suspension bits - control arms, endlinks, etc.
Special Introductory Group Buy?????????????????????????
yes please
so......what's up jared....how you doin....
Here's the tentative plans. This initial test set will be installed and fully tested. If it meets my standards, I'll probably open them up to a pre-buy. Pre-buys will help me in two ways. One, the items are already sold and they don't sit on the shelf. Two, it helps judge initial order quantity so we don't over order or under order. For this, the pre-buyers will get a discount.
I'm doing good Dan.
hmmm...i told myself that next month i will be smending money on the e39 only for maintenance purposes and try and save as much as i can...but...these....make me....wanna save and buy some coilovers!!!!! haha very interested! althought i will probably purchase belt tensioners and other things needed before these =/
More details added to first post.
id be in for camber plates... im getting terrible tire wear up front...
