What are you guys using to adapt the LS1 Hyd Slave Cyl/Throw-out Bearing to the BMW line?
thanks
Vorshlag makes an adapter with bleed line.
McLeod Industries 139026 (search on summit racing) that will adapt your gm slave to -4, then you'll need a -4 adapter to the bmw side....I believe its an m8 inverted flare, I forget.
Speedway sells a nice set of fluid lines for the clutch that hook-up to the GM factory quick-connects
E30-LS1 Swap Guide and Kits, email us at e30ls1@gmail.com !!! or check our website e30ls1.wordpress.com
Excellent call. After having issues with the stock master, I switched to a Tilton 7/8" unit, and run a braided line from Speedway (48") to the slave and like you said it has the GM quick connect. While on the topic, I'd also highly recommend a remote bleeder that will allow you to bleed the clutch without getting underneath the car...big timesaver.
1991 e30 318is Slicktop - Gone
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
2014 F-250 CC- Mostly stock
summit racing also has those.
i havent found a metric inverted flare fitting, let me know if you come across the part# thanks
well I'm not sure its an inverted flare either...I bought a few I'll see if I can dig them up for a part number.
Speedway was very helpful, got everything I needed from them
thanks
speedway rocks! and is just 40 minutes from me
would you please provide us with the parts # i need to get those lines too!!! HELP!!!!!!!!!! I called speedway and the tech could not help me find the right connector to the stock bmw master i need help
Pegasus has them.
http://www.pegasusautoracing.com/gro...=BRAKEADAPTMET
FYI Russell also makes an adapter in -3 and you get 2 for half the price as the Mcleod adapter.
Russell PN:RUS-640281
I ended up just getting the speedway 22" fbody clutch line (its -4) and got a russels 3/8" x 28 invetered flare to -4 adapter from summit, then got a m10 bubble flare to 3/8" x 28 inverted flare adapter, I'll post the stuff up on my build thread soon
This is what i did:
On the left(in red) is a adapter from summitracing, part number AER-FBM2937. You hook your -4 LS1 F-Body clutch line to this. In the middle is a brake line adapter, it is basicly a brake line with a 3/16 flare fitting on one side and a m10 bubble flare on the other. I got this from Autozone, sku# 568318. On the right(in white) is a M10 bubble plare union to connect to the stock BMW hyd clutch line. This was also from Autozone, sku# 845271
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
I use a centerforce 12" clutch and fidanza 12.5lb flywheel. My issues were with the clutch not fully disengaging at high rpms. This is very common in the LSx world (with any clutch setup), just look at all the adjustable MC's and slave cyl shims on the market.
I tried shimming the slave first, which helped a bit...but the Tilton was the true fix to the issue
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
+1 on the remote bleeder. I use a stock BMW master cylinder and have not had any problems.
Rob
Prior projects:
1998 540i with 6.6 LS2/T56 Chevy Power
- pictures and details
1992 325i with 6.6 LS2/T56 Chevy power - pictures and details
1995 M3 with 6.6 LS2/T56 Chevy power - pictures and details
Are you guys just using the standard OEM slave cylinder and getting a remote bleeder for it?
^ Thats what I did
Stock replacement slave cylinder - mine is shimmed .125, which is what a lot of people do with a LS7 clutch.
Rob
Prior projects:
Good info in this thread.
With a C5 corvette clutch and lightweight flywheel, would there be a reason for a shim? I take it the reason for the shim is like JoeZ said, problems disengaging the clutch at high engine speed?
