Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > M series > 1992 - 1999 M3 (E36)
1992 - 1999 M3 (E36) (1992 - 1999) BMW's second generation M3, and the first M3 to feature BMW's classic inline six motor. Featuring 240hp (european models had a 286hp and 321hp), a slick shifting gear box, and near perfect weight balance, the E36 M3 was named Car & Driver's "Best Handling Car At Any Price."
Old 02-28-2010, 03:04 AM
99MPower's Avatar
99MPower 99MPower is online now
I can haz?
Cars: 99 M3...
Send a message via AIM to 99MPower Send a message via MSN to 99MPower Send a message via Yahoo to 99MPower
SUPER complete Rear Suspension overhaul
To preface this thread, some of this work was completed last year
Here is a list of ALL parts used
(4) Lemforder Balljoints #2 and #3 part #33326775551 $35 each ($140)
(3) Diff bushings AKG Poly $120
(2) AST monoball RSM's (came with my 4200's) $280, but I got them with my suspension
(4) Powerflex Purple Subframe Bushings (Bimmerworld) $145
(6) McMaster Washers $20
(2) E90 Front suspension bolts #3 part #31106769908 $15
SPC Camber Arms $180
SPC Camber Arm spacers $45
AKG Swaybar Reinforcements (BEST reinforcements IMHO) $35
(2) Upper/Inner bushings #6 part #33321092247 $20
(2) Powerflex RTAB Bushings (Bimmerworld) $75
(2) Outer CV Boot kits #5 part #33217840673 $32
(2) Inner CV Boot kits #6 part #33219067806 $43
(4) Tubs of Redline CV2 grease $10 each $40
(2) FAG Rear Wheel Bearings #3 part #33411090505 $45 each $90
(2) Axle Nuts #4 part #33411133785 $5
(2) Snap Rings #2 part #07119934755 $5
(8) Cable Holders #23 part #33181181218 $5
RTAB Pocket Reinforcements (Bimmerworld) $40? couldnt find on website
(2) Crush Washer for diff #7 part #07119963355 $2
(1) Diff Gasket #3 part #33111211708 $2
(2) Royal Purple 75w140 gear lube $40
(12) Halfshaft to Diff Bolts #3 part #33211227664 $24
(6) Reinforcements #2 part #33211209543 $10
TOTAL $1133 without counting welding/press costs and paint/powdercoat. Also I did NOT include the RSM's into the cost, but EVERYTHING else is
To preface this, I rebuilt my new FAG rear wheel bearings using a DIY I found on BFC here. This thread also talks about the benefits of taking the bearing apart and repacking with new CV2 grease
http://forums.bimmerforums.com/forum....php?t=1231517
Also, I rebuilt my halfshafts and made my own DIY which is also in this section.
http://forums.bimmerforums.com/forum....php?t=1398300
This huge project was started because I was running the Powerflex purple rear subframe bushings and knew there were issues with the washers cupping. I ran into this thread and this issue was discussed and this is where I got the info for the Mcmaster washers and e90 front suspension bolt
http://forums.bimmerforums.com/forum...frame+bushings
Also, my halfshaft were leaking some fluid from the inner cover, and I knew there wasnt as much oil in there as there should be from an incident last year.
To complete my overhaul, my Bimmerworld swaybar bracket reinforcements were cracking and I knew I needed to get this fixed, and through some research and a visit to the "mad greek" at AKG (shop is 15min from my house), I found out the AKG swaybar reinforcements were by far the best. Also, after last years bushing overhaul, I didnt do the rear wheel bearings, and I wanted to knock them out as well.
On to everyone's favorite part, the pictures
Some pics from last years overhaul with the bushings
At this point, I didnt have access to a press so I took all my new parts and brought everything to a local shop and had everything pressed in
After all that work, I ran some track events, and when I was inspecting things this fall, I found this
To say the least I was not happy that my Bimmerworld reinforcements were cracking apart
Onto some pics from this years tear down, overhaul, and reassembly
Old 02-28-2010, 03:08 AM
99MPower's Avatar
I can haz?
Cars: 99 M3...
SUPER REINFORCED Diff Mounts
ALL DONE
Old 02-28-2010, 03:12 AM
REHaas REHaas is offline
Cars: are bad investments
Holy ish!
Good work Cal!
Old 02-28-2010, 03:19 AM
99MPower's Avatar
I can haz?
Cars: 99 M3...
Forgot to add pictures of the RTAB pocket reinforcements
Old 02-28-2010, 03:40 AM
das borgen's Avatar
das borgen das borgen is online now
Off-Topic King
Cars: 97 Arctic Silver M3
I like? No! I love
-Rich-
Old 02-28-2010, 05:51 AM
LUSTR's Avatar did not read the avatar rules!
LUSTR LUSTR is offline
Cars: 99 Dakar M3
Send a message via AIM to LUSTR Send a message via Yahoo to LUSTR
One of the top threads on BF.c for sure! One day I will follow this to each and every word. Great work bro.
-Ivan
Old 02-28-2010, 06:06 AM
mtechnica's Avatar
mtechnica mtechnica is offline
It can't be helped
Cars: '99 M3 / '92 Miata
Good work, to say the least
Old 02-28-2010, 08:11 AM
M3_MadBimmer's Avatar
M3_MadBimmer M3_MadBimmer is offline
Cars: 98 and 95 m3's
Send a message via AIM to M3_MadBimmer
This is the only way to do a rear end overhaul. Once and thats it
Luke
95 M3 Cosmos/Black: OBDI S52 - GC - Powerflex - UUC - Stromung - Cosmos
98 M3 Estoril/Mulberry: 2.8L Franken-stroker, Custom top-mount built by me, TRM tuned to 604whp http://forums.bimmerforums.com/forum....php?t=1216803
Old 02-28-2010, 08:43 AM
95s52's Avatar
95s52 95s52 is offline
Auto-x newb
Cars: 1995 BMW M3
Send a message via MSN to 95s52
Very nice work! How many miles does your car have?
Mods: obd1 s52, SS replica headers, SS race mid-section, SS exhaust, euro intake, 3.5" hfm, turner tune, 24lb injectors.
1/4 mile: 12.88 @ 107.4 Best trap 107.65 3080lb with driver.
Old 02-28-2010, 09:29 AM
Brent 930 Brent 930 is online now
Call me snake
Cars: 328is M3 Killer
Very nicely done. You shouldn't have any more issues.
I also got the RTA pockets welded up with BW's kit before finishing my project. Did you have stress cracks around the threaded holes? I didn't have any and just had the plates welded in there. I'm assuming that will prevent any cracking.
Also could you explain the reason for the E90 bolts?
Old 02-28-2010, 11:03 AM
99MPower's Avatar
I can haz?
Cars: 99 M3...
99,500miles The car is tracked and auto-x'd and all the bushings/bearings/balljoints were SHOT
RTA pockets were PERFECT when I had the reinforcements welded in. No issues there
E90 bolts are required due to using the thicker McMaster washers. Also a nice side effect is that they dont have that nut on the top.
Old 02-28-2010, 11:16 AM
Xiphos's Avatar
Xiphos Xiphos is offline
///Moneypit
Cars: '97 M3/4, '86 4run
What did it all end up costing you if you don't mind?
Brendan
"Speed has never killed anyone, suddenly becoming stationary... That's what gets you." -Clarkson
E36 M3 DIY Page
Old 02-28-2010, 11:23 AM
99MPower's Avatar
I can haz?
Cars: 99 M3...
due to the fact that it was done in two stages I'm not really sure... I could "guess" though and might guess there is almost $1000 in just parts there
I'll update my first post with prices when I get chance. Really depends on if u have a press, access to a press, make your own, or pay someone. Also, the welding required (paying someone else, have access to a friend, or yourself)
updated first post.... ALL parts except the RSM's (came with 4200 kit)
$1133 in parts without the welding/press cost, and paint/powdercoating
This can be cheaper if u use OEM parts where I use "performance" or just used you old lower camber arm and bought new inner bushings instead of getting adjustable ones like I did. I even got a cheaper set and still $180 added cost
Here is another overhaul that I helped with that wasnt nearly QUITE as extensive, but some other pictures
http://www.m3forum.net/m3forum/showthread.php?t=263751
Old 02-28-2010, 06:22 PM
SneauxM3's Avatar
SneauxM3 SneauxM3 is offline
I'll take ya eyez!
Cars: 95 M3. 68 Bug. Haro
Your bent lwr control arm is nothing, muah ha ha haaa.....this actually sucked kinda
Old 02-28-2010, 10:49 PM
99MPower's Avatar
I can haz?
Cars: 99 M3...
ouch...
my "bent" lower arm is was triggered that first overhaul
Old 03-01-2010, 06:30 AM
MBe36's Avatar
MBe36 MBe36 is offline
Cars: Fern Green 1999 M3
Send a message via AIM to MBe36
Can you explain how different the ride is?
WANTED: 3" Conforti Intake PayPal Ready
Old 03-01-2010, 08:56 AM
SneauxM3's Avatar
I'll take ya eyez!
You daily your car too don't you Cal? I've been debating subframe bushings or not depending on transfer of noise. Wanted to keep them factory but do the poly diff mounts.
Any input on how yours feels
Old 03-01-2010, 11:37 AM
99MPower's Avatar
I can haz?
Cars: 99 M3...
felt great with no issues, but mine is stripped and I have a pretty high tolerance for that stuff
the car is literally GLUED to the road.. I'll find out this week once I get my last order of stuff in from CMUZZY
Old 03-01-2010, 12:16 PM
KnudsonM3's Avatar
KnudsonM3 KnudsonM3 is online now
Cars: 87' Mazda B2200
Copied it and saved the DIY into a word file
So when are you doing mine?
Old 03-01-2010, 12:43 PM
99MPower's Avatar
I can haz?
Cars: 99 M3...
you can copy and save, but the links would all be gone....
Old 03-01-2010, 12:52 PM
KnudsonM3's Avatar
Links are all there....
God bless windows 7
OT: did you hear that we can now use Facebook, myspace on our gov comps?
Old 03-01-2010, 01:01 PM
///Montizzle's Avatar
///Montizzle ///Montizzle is offline
Honorary white guy status
Cars: 01 C5/98 Escort ZX2
Send a message via AIM to ///Montizzle Send a message via Yahoo to ///Montizzle
Doing WORK son
420rwhp/402rwtq
RagnarDanskjold's Avatar
RagnarDanskjold RagnarDanskjold is online now
Rational Primate
Cars: '95 M3/'00 ZX-9R
I ruff u.
I'm at 225k/mi and I've been planning a rear end rebuild for a while. This is beyond inspiring. It's damned informative and a great write-up!
Thanks for sharing this.
-Steve
Do you like large cats?
Old 03-01-2010, 01:02 PM
Mr Estoril Mr Estoril is offline
Cars: 1999 M3
Now I see what your little secret with the powder coating was. Good work!
/// 99 M3 Coupe
Old 03-01-2010, 01:04 PM
99MPower's Avatar
I can haz?
Cars: 99 M3...
Originally Posted by ///Montizzle View Post
Doing WORK son
thanks Monte
Originally Posted by RagnarDanskjold View Post
I ruff u.
no problem.. With as much work as I have into my rear suspension, I figured it would be a shame NOT to share everything, and all the information
Leif... I dont touch either with a 10ft pole.. you realize they can track EVERYTHING you do on the government computer
