Now it is just a matter of fitment...
B.
1991 bmw 325I <e30>
First 8 second full body BMW with BMW independent rear suspension in the USA
8.69 @160mph in a 1/4mile on slicks.
drag radial tires record holder9.53@148. Also a world record holder for bmw overall 60-130mph 4.2 seconds.
Bistein sport susp,turner sway bars,3:25lsd,m52 AEM INFINITY stand alone. MORAN 2500cc injectors E85 ,front mount 33x12x4 intercooler, 5lug conversion M3 front,Mcoupe rear Dss axles/driveshaft ATI Proglide.
2003 Ford Expedition
1998 M3
1986 Mercedes Cosworth 190e 2.3 16v 5speed (sold)
wow, whats that going on. You looking for 1000whp?
| 1997 Estoril M3 - TURBO - || GT35R | 8.5:1 forged internals | ARP stuffs | SS Oring Block w/ elring | Fully balanced & blueprinted 3.3L S52 | Nick G Tuning || 46mm Precision gate| 62# injectors | Dual Walbro's |Goal: 600+ whp pump gas reliable 10 second car.
-2007 335i Sport Package
You're gonna need more than those 65lb injectors in your sig for that
95 M3, 5.3 LS, PTE 7675CEA, TH400/Gear Vendors OD
10.4@136 Pump gas at 3530lbs.
Build thread
http://www.bimmerforums.com/forum/sh...LS-Turbo-build
I'm selling some precision 1000cc injectors and a peak/hold driver box for $450
97 M3 - 8.94@164 - 8 sec street machine, all BMW driveline, factory ECU
02 M3 - 9.74@145 - Maximum PSI stage 2 turbo kit, stock motor, factory ECU
16 M3 - 9.3@151 - Built motor/twins
15 M3 - 9.2@162 - Built motor/single turbo/Ecutek
BMW SOB's turbo E30 - 8.72@158.39
follow our latest builds and upcoming events! - facebook.com/maximumpsi - instagram.com/maximumpsi
Thats a good f'in deal
am going with the 1600cc injectors.
1991 bmw 325I <e30>
1998 M3
My manifolds powering 8sec and over 1000rwp cars
Home of the highest HP stock M30 in the world 550rwhp/622rwtq
1/4 mile---> 9.81 @138 C4 Auto
10.08 in car vid --->https://youtu.be/OiinFhUomjg
Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
Maybe straight meth? I don't know yet...We will see..I will start with 93 and work my way up.
1991 bmw 325I <e30>
1998 M3
build thread?
85' Turbo M50 E30 | 95' M3 Nitrous, Coilovers, DJ Autos, UUC SSK
1991 bmw 325I <e30>
1998 M3
If this sucker seals this will be the first built engine in the USA (that I have heard of) with Pyramid Rings to seal. I am praying for you man!
That turbo looks sooooo darn good! I do see that you have an OBDII valve cover. Is it plastic? If it is, you might want to switch to the OBDI metal one before you have a melt and then some oil on the turbine housing/DP and then a fire. Just looking out for you man!
I don't have my turbo nearly on top of my valve cover like that and it started melting to a near leak phase before I caught it and switched to a metal valve cover. Guys at the shop were sketch saying it could have been a fire waiting to happen.
I like where this is going...
SOLD -A dozen ///M3s of all shapes
those are just o-rings no pyramids(i don't like the idea if being a gunea pig), i am using stock gasket(erling)and orings .012 protrusion above deck no groove in head.
B.
1991 bmw 325I <e30>
1998 M3
The op was one of the first to be using that oring tool if I remember correct. Looks like it worked. this one will be fun to watch.
I used to work at a machine shop a few years back,and one of my good friends owns a machine shop,so i did it there before taking the block back home.(i guess you can say i did it at the machine shop).And, i got that number by measuring the depth of the groove cut for the o-ring and taking the wire size .041 and subtracting .029 groove depth wich leaves .012 protrusion above deck.
B.
1991 bmw 325I <e30>
1998 M3
Oh snap!!! It looks like you will be in for some serious power!
This is my signature....
