Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1983 - 1991 (E30)
1983 - 1991 (E30) (1983 - 1991) Born from the sporty character of the 2002 and the sharp design lines of the E21, the E30 was a blend of the best of BMW's heritage. The second generation 3 Series provided a thrilling driving experience that used the best technology available.
Old 02-09-2010, 12:36 PM
robmpulse's Avatar
robmpulse robmpulse is offline
Dumbass!
Cars: '93 E30, '01 E46 Mtec I
Send a message via AIM to robmpulse Send a message via Yahoo to robmpulse Send a message via Skype™ to robmpulse
1993 e30 cabrio strut inserts info
Okay, so I am trying to order Bilstein front strut inserts for my 1993 325i cabrio. According to Bilstein, my car does not exist. We all know this is not true. After speaking to their technical department, they show in their German catalog that the E30 did in fact list up to a 1993, with 1991 being the last year US E30. There catalog shows two different inserts. A 45mm outter diameter strut housing and a 51mm. Anyone know which one I will have in my 1993 E30 325i cabrio? I am not with the vehicle for a few more days to measure, and I would like to get these ordered before then. I am thinking maybe the difference could be touring, 318, or something like that. I can only assume that all 325i cabrio's would use the same insert. Thanks for any insight on this. If anyone has the Bilstein part number that is known to fit my vehicle, that would be of great help.
Signature Disabled - Check the Signature Rules... Fix your signature FIRST!
Afterwards post in the signature/avatar request thread in the forum suggestions forum.
Old 02-09-2010, 01:43 PM
VacMan's Avatar
VacMan VacMan is offline
Some call me...Tim?
Moderator
Cars: E30 cab, E34T S50/5
Use a '91 for all ordering. Your car has 51mm inserts, same as any other late-model E30.
1987 E30 cabrio | Bumper swap | H&R Sport | Koni Yellow | Eibach Sways | BavAuto strut bar | Cardinal seats | MTech2 wheel | Armrest | Smoked Hella Smileys | 5k HID | Stromung | lots more
1995 "530it" Uberwagon | S50/5 speed swap | Cams | Port&Polish | 24lb. injectors | Custom chip | 540 AFM | ZF310 5 speed | 3.23LSD | H&R touring| Bilstein Sport | Hartge catback | BBS RK
1988 "327i" AutoX Project | SuperETA block, I head | H&R Race | Bilstein Sport | Suspension Techniques sways | Recaros | Kosei K1's | Azeni 615's | junkyard plastic bumpers | Gutted
Old 02-09-2010, 03:10 PM
robmpulse's Avatar
Dumbass!
So the early model E30's used a 45mm?
and why does the cabrio have a separate part number?
Old 02-09-2010, 03:55 PM
VacMan's Avatar
Some call me...Tim?
Moderator
Only very early 318's and ETAs (up until '85) used 45mm inserts. Cabrios have always used the same since they didn't start production until '87.
They have different part numbers because they're valved differently because cabrios weigh more. The outer dimensions are identical. You'll find the same to be true with springs, for example I run H&R cabrio-specific springs but if you put them next to coupe springs you'd have a hard time telling them apart.
Old 02-09-2010, 04:07 PM
robmpulse's Avatar
Dumbass!
If they are valved differently, then will i not experience a difference in ride quality using the non cabrio shocks/struts?
Old 02-09-2010, 08:12 PM
Quailane's Avatar
Quailane Quailane is offline
E30 =/= E36
Cars: BMW 530Li
You aren't using the stock parts so that is a moot point.
Old 02-10-2010, 08:06 AM
Mini4x's Avatar
Mini4x Mini4x is offline
Cars: 1997 328i Sport
Send a message via ICQ to Mini4x Send a message via AIM to Mini4x Send a message via MSN to Mini4x Send a message via Yahoo to Mini4x
Also untrue..
I have a US Spec 1992 E30 Cabrio
"And so it will reign" - Derrick Dahl
Old 02-10-2010, 12:29 PM
robmpulse's Avatar
Dumbass!
OEM replacement parts should be designed as the part it is replacing. One should be able to assume that direct replacement parts will be valved correctly, so yes, that should make a difference and should not make this a mute point. Am I wrong to assume this?
Originally Posted by Mini4x View Post
Also untrue..
me entire post is here because this is a known false statement. lol Not sure what you are trying to say???
Old 02-10-2010, 12:42 PM
Quailane's Avatar
E30 =/= E36
Cars: BMW 530Li
But that's not what you are buying because Bilstein does not make OE replacement shocks. They have Touring, HD, and Sport, and share the same shocks for all models of E30. Touring is slightly more stiff than the OE shocks you would buy from Sachs or Boge. Both HD and Sport are the same other than the HD's being able to extend further.
