So today I got off of work at 2 and was headed to go meet a friend to hang out. I got into the car and locked the doors as I alwayse do, but when I turned the key the engine didn't start. First thought was oh fvck me, what now. Only light on the cluster was the airbag light, so i pulled on the door handle (that i just unlocked with the keyfob and locked with the center button) to get out and check the battery. Only the door didn't do its normal double pull unlock thingy. Then I was really freaking out. I started looking for fuses since none of the windows would work. Then after sitting there wondering what to do for a minute or two, I tried the passenger door handle which worked(I felt dumb for not trying it sooner). I popped the trunk and jiggled the wire on the negative terminal on the battery and the trunk lights lit up. After that everything is fine and has worked normally. How bizarre that without touching the battery, it could unplug itself while both wires are still plugged in. I think my e46 is posessed!
Sorry for writing a book here, but I thought it was eventful/funny enough that I thought yall would want to hear it.
Sounds like a bad connection. Take the battery terminals off and clean the connection then put them back and make sure they are nice and tight.
good luck
ROFL!!!
But yeah it's common for the battery terminals/connections to not make the proper contact while tightened.
- Life's short, live fast...drive a BMW -
(note: I'm not russian..nick I got from my friends - long story)
http://www.flickr.com/photos/noisestudio/
hahahahahahahahahahahahaha BLONDE STAR FTW!
Need a hug?
I have no idea, but that kinda freaked me out when it didn't. For some reason the double pull didn't work on the driver's door, but the passenger door worked like a charm. I thought it might have something to do with the door not being able to lock while open since only the driver's door does that, maybe? Idk tho, nor do I care because I tightened up the negative to the battery and when I update my tcu in a week I'll be sure to tighten it all the way this time.
