Time needed: 15 min
Tools: Hex driver
Symptoms could be, hard start (hot) bad idle, dip of rpm when coming to a standstill
Remove the acoustic cover
The M62-TU engine has 2 CPS sensors (M62 only one on the left)
CPS on the right side, undo the hex screw and pull out
Clean the inside
Old and new (ONLY! use Bosch and no after market version, they don't work)
Follow the wire to the connection box and unplug it
Insert the new one
Run back the wires and secure them
After replacement the hard starting and rough idle should be gone.
Edwin
Have a technical question, don't send me a PM but post it on the board so others can benefit from it!
