Given that the weather has not been cooperating for the last few days, and I have been swamped with work, I finally got a chance to get some work done on the AV install. Started with the trunk buildup.
The trunk will house an amp rack with 3 amps (Arc FD4150, Arc FD600.1 and a US Acoustics USB 4085). The DSP amp and the CD changer come out, and in their place, I'll be building some MDF contraptions to mount my CarPC, the RF 3Sixty.2, CDC Aux interface, the wireless router, RGsB adapter...and a couple of other things.
I need to house my Blue Sea fuse boxes, a couple of relays etc and these will go in the space "around" the spare tire. In that area you have two ABS plastic pieces that form the base around the spare tire, and the carpet fits into that. The two pieces have been junked, which gives me about 2" of space to work with. The whole trunk will be getting a new carpeted floor.
As it looks right now..
All of that extra wiring hanging off to the side, while working..
Ewww...dirty!
Ahhh...nice and clean after a bit of Simple Green and a scrub..
Now, I have spent HOURS knocking on all panels in the car (on the floor, doors, trunk etc) and while everything is SOLID, there's a few minor areas that could be improved. And that too only because the audio system now will have a lot more power than stock, so I wanted to make sure that things are dampened. Especially the trunk as it will be getting two 10" subs....
Lowes to the rescue! This is Frost King duct insulation from Lowes. It comes as a 12" x 15' roll for around $15. It's a closed cell foam substrate with a fairly thick aluminum foil backing, and is self adhesive. The adhesive is not that great, but since it's not going on any vertical surfaces (yet), I'm not too worried. I used aluminum tape where things might get a lil loose.
That's about all I got done today.
Will be using two JL 10IB4 subs in an infinite baffle bolted to the rear deck in the trunk.
The CDC is coming out. And so is the DSP amp. In place of the CDC goes the DF-BMW aux interface which has two aux inputs. One will be used for the CarPC, and the other will be hooked to the wiring in the cabin (wires already in place).
Still playing with the layout of the amp rack, but I think it's in my head now. These passive crossovers won't be needed, now that I have the 3Sixty. And one MORE amp (for the rear doors) added to the mix. Will be running active for the front stage and subs, and potentially passive for the rear doors (but time aligned, delayed with the Haas effect, L-R and R-L summed signals).
nice set up BUMP
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
Got the amp rack layout sorted out. Won't have to stack after all. Just had to get a bit creative, and ended up staggering the amps a bit, since only the FD4150 is the longest and the USB 4085 is the shortest.
Right now, the side supports are 3.5" high. I need to trim them about half an inch, to reducte the overall height as such, while making sure that the amps have enough clearance and the 80mm fans can fit in the back. 3" will be perfect. All amp controls are at the front (where the removable front panel will be), so tuning/adjusting should never be a problem.
Here's the "planned" system diagram, now with the 3Sixty incorporated.
Most everything is straight forward except for that damn rear fill signal. I'm thinking just a L-R signal, MONO, time delayed, attenuated and bandpassed, but fed to both rear fill sets should still be ok? As opposed to a stereo rear fill signal (as in L-R, and R-L), and if that's the case, can I just switch the phase of the right/left signal to make em stereo?
Didn't get a whole lot done in the last two days, but test fitted the rack in the car today, and it fits perfectly.
I reused the little trim piece that goes around the spare tire (and normally supports the carpet), chopped it off a bit, and screwed it to the base of the amp rack. This gives the amp rack a solid base to rest on and now it can be screwed into factory holes in the trunk.
I'm hoping I can finish the amp rack by the middle of next week, gotta wrap up the wiring...I think I'm gonna have to build a smaller second "level" in the rear half of the rack, to house some additional equipment like the 3Sixty and the two crossovers (which are HUGE!). There's no way I can fit them anywhere else.
We'll see.
Built myself a lil black box.....
I needed a "clean" way to house some of the AV related things. Namely:
- The IBUS interface
- Connectors for the TV Tuner (Video IN, Audio IN, Video Out, Audio Out, RV Cam In)
- A couple of relays:
-- One relay to automatically ground Pin 17 of the TV tuner, for the Rear view camera (SPDT), when the car is in reverse
-- One relay (SPDT) to do the same if my manual switch in the steering wheel is enabled. This is a ON-OFF-ON toggle switch, that allows me to activate the rear view camera even when the car is moving. And it's all wired up, so that when I add a front camera, I can switch between the two).
-- One relay (DPDT) to switch the video output between the front and rear cameras, depending on the position of the toggle switch, and feed it to the rear view camera input on the TV tuner.
-- One relay for the remote turn on of the 3 amps and the RF 3Sixty. I didn't want to hook up all these straight to the remote turn of our stock head unit. This is an SPDT relay as well.
All of these relays have protection diodes built in for the back EMF and have fairly high impedences, so they draw very lil current.
Well...enough talk...picture time!
Here's some of the inside and build pics.
BMW connectors....
The USB connector from the IBUS interface
The A/V connectors
I/O connectors
Molex 12 pin connector
This lil "black box" has all the required incoming and outgoing wires to do the following:
- Connectors for Video In, Audio In, Video Out, Audio Out, all connected to the TV tuner
- Two Video connectors for front and rear cameras, that are run off of the DPDT relay and fed to the TV Tuner's RV Cam input.
- Two L/R audio connectors for Aux input (still working on solving one small problem with that...)
- Has remote in and remote out, remote in is from the head unit and is piped through the SPDT relay to generate a remote out, that will be used to turn on the 3Sixty and the amps.
- The TV tuner automatically switches over to the RV cam input, when the car is reversed.
- Toggling the switch on the steering wheel can bring up the rear or the front cameras, even while the car is moving, and without trigeering the reverse lights.
- A holding place for the IBUS interface.
The whole box is about 6"x3"x1.5" Small enough. Now, I get to test this tomorrow...I'm gonna keep my fire extinguisher handy....
The amp bypass harness
BMW connectors...with stock radio pins at the end. Take off the existing ones from the radio, and plug these in. Plug and Play
The Amp rack in the process of being wired...
This is friggin awesome, cant wait for more...
Talk about ambition! Lookin good.
Looking good. I always wanted to do a complete install in one of these cars, but it won't be happening in mine.
Any reason you didn't just use Dynamat?
No need to. The E38 is rock solid in terms of panels. All I needed was a bit of decoupler and some sound insulation. Frost King is perfectly fine for that. And it can be removed fairly easily if ever need be. Dynamat is for reducing panel "resonance", by mass loading it, not for sound insulation.
more pics please
Front camera? Do you plan on going FLIR with it?
So when are you going to find a way of mimicking the F01's sideview? (the "look both ways before pulling out" cameras)
No, I'm not being a jackass...I REALLY want to know if and when you're going to try to do that.
Well....that's a tough one. I'm not even sure I'll have a front camera anytime in the near future. But, since I was building that box anyway, to house my IBUS, AV connectors etc, adding two more relays and a couple of wires wasn't that big of a deal. But yes, if I ever decide to infact install a front camera, it will be a thermal imaging type. No point in installing anything else, the windshield is a big enough viewport.
Sideview.....ahh....I'll just get an F01 Not worth the trouble.
Great job you are doing!
Follow me on Instagram @SEVEN40iL
Very impressive.
Sorry...I won't be able to buy an F01 any time soon...on that note, I'll let you know when the sideview project is complete.
I'm also in the process of working on a lane departure correction system.
Looking Good!
Why use a US amp and not another Arc? What made you decide on the 5.25" rear fill?
Bill M.
Bench tested the 3Sixty, amps and the PPI speakers today. Oh my...
First off, the 3Sixty is awesome. Not necassarily the BEST (that distinction is probably for the JBL MS8 or to a lesser degree the Audison BitOne), but WAY more than enough for what we are looking for.
I have it set up so that the FL/FR drive the front left and right mids (via the FL and FR of the Arc FD4150), and the output of the 3Sixty on these channels is split, so that it also goes to RL and RR of the FD4150, and that drives the second set of mids for midbass duties only. The built in amp crossover cuts off all frequencies above ~200Hz for the second set of mids.
The tweeters are driven by the RL and RR of the 3Sixty and are hooked to Channels 1 & 2 of the USB 4085.
The sub out from the 3Sixty goes to the FD600.1.
I was testing this by hooking up the analog outs from my laptop.
Right now, with no proper enclosures for the mids and only a sealed 10" sub for testing, the whole shebang sounded GREAT and LOUD. Damn. With only about 90W to each mid (all 4 of them), and about 85w going to the tweets, I couldn't turn the system up more than 1/2 way on the laptop! I doubt the system is utilizing even half the power of the amps, and it is amazingly clear and loud. Anyone that says you need more than 75-80w of clean power, has his ears stuffed! I'd go deaf if I turned this up all the way!
I can't wait to finish the install and get the speakers in their proper positions and enclosures. The subs will be running IB, the mids (all 4 of them) will be running IB, and thw tweets...well they are always without enclosures to begin with.
The test setup in the basement. (and yes, I'm getting yelled at BIG time by the wife....)
A jumble of wires right now....
The "source".
100A Circuit breaker built into the amp rack. The wire from the circuit breaker to the battery block is already sized and is about 12"
Distribution blocks built into the amp rack. The ground wire from the ground block to the chassis is about 8" long. Will be grounded to the rear firewall behind the rear seats, using a big bolt and washers.
All speaker wiring done as such.
The culprits....
Test sub. (notice the quick disconnects from the amp wiring?? )
From one "DSP" (stock) to this....
Rear fill "woofers" installed, using the stock woofer enclosure. This goes in the rear deck. Stock, this enclosure is actually vented to the trunk, I sealed up the underside of the enclosure to make it completely sealed. Another MDF panel will be sealed to the rear deck holes from the trunk side, to completely seal off the rear deck (since the subs will be IB through the ski pass).
These are el cheapo (about $12 a piece) Goldwood 5.25" woofers I had lying around, but they should do fine as rear fill with a L-R signal, bandpassed to ~200-3000Hz. We'll see how they "sound" :-) They are 8 ohms each, so each side will be run in parallel using one channel of the USB 4085.
The specs as such are:
*Power handling: 70 watts RMS/130 watts max
*VCdia: 1"
*Le: .40 mH
*Impedance: 8 ohms
*Re: 7.0 ohms
*Frequency range: 50-5,500 Hz
*Fs: 81 Hz
*SPL: 84.7 dB 2.83V/1m
*Vas: .13 cu. ft.
*Qms: 2.87
*Qes: 1.18
*Qts: .84
*Xmax: 2.0 mm
*Dimensions: Overall Diameter: 5-5/8", Cutout Diameter: 4-9/16", Mounting Depth: 2-1/2"
The US Amp is only powering the tweeters and the rear fill. Don't need too much power for that. And it was cheap! $90 for 4x85w at 4 ohms.!
As far as the 5.25" rear fill goes, these will go into the stock woofer enclosure that the 740 already has. Hence the decision to use 5.25" woofers for rear fill. These are the Goldwood woofers I already had and they fit perfectly with no modifications to the stock enclosure, and can play from 50Hz to 5500Hz (obviously not that well, given their quality). However, as rear fill, they will only be playing about 200Hz to 3000Hz or so, so they should be fine in that frequency band.
this is just unreal and awesome. cant wait for the finished result
2000 BMW 740i Sport
-Nav TV Retrofit
-Stealth Backup Camera
-Steel Gray Carbon Fiber Trim
-Umnitza Led Interior Light
-Umnitza V2 Orion + Euro Switch
-HID Foglights
-Intravee II w/Intravee Switch (aux)
-Nav Widescreen and MK4
-Alpina 20" Softlines
-Alpina Lip
-Anthracite Gray Color Change
-M Sport Steering Wheel w/paddle shifters
-Nex GT Coilovers all around
-Meyle Suspension Arms, Ball-joints all-around
-Dual Exhaust (Magnaflow) and Muffler delete
-Full Integrated ULF Bluetooth Kit
Gaithersburg, eh? Looks like I'll have to take a trip North to see the folks in Accokeek!
No need, you'll hear him from Tampa...
Looks killer. I wish we were closer, I'd love to see/hear this when it's done.
Wow! What can I say...very impressive! My son is Jr.in electrical engineer at Uiv of MD CP, and could learn a few things from you!
Is there any way we can insert dummy posts into this thread to limit it to 1 massive post per page? I only have 4GB of RAM...
Final subwoofer thoughts
After analyzing the ski pass opening for hours, and trying to think it 19 different ways, it seems like building a regular baffle and getting a good seal will be very very difficult, because of the complex contours near the ski pass opening.
Take a look at this picture of the ski pass.
As you can see the entire firewall has curves all over, there are curved protrusions against both sides of the opening (which provide additional structural integrity), and the opening itself is inset AND tilted from top to bottom. At the top it's flush with the firewall, but at the bottom it insets almost 1.5".
I tried a number of things, and I just couldn't come up with a good way of sealing a baffle "properly" against that opening. Then.....
This is a ski pass opening, so obviously there's a ski pass through module! So, I hunted on CL and eBay and bought a used ski pass assembly. And then of course I promptly took it apart to leave only the frame (which is what I need).
The side that "inserts" into the cabin.
Now, this of course is designed to fit perfectly into that opening, taking into account all curves, protrusions etc. The opening in the ski pass is ~ 9"x13".
My initial thought was to make a fiberglass enclosure around the ski pass assembly, instead of making an MDF baffle, as the fitment will be much better. Here's two 10" MDF rings placed on the assembly for reference.
They are obviously not in the correct positions, but you get the idea. The rings would be placed on the "sides" of the ski pass assembly, and then glass over everything to create a one piece, (hopefully) solid baffle/enclosure that will fit into the opening.
However, after talking to a few folks that are more familiar with fiberglass than I am, it does seem that no matter how creative I may get (roughing up the plastic piece, drilling holes etc etc), bonding fiberglass to that ski pass assembly will probably not provide enough strength for ~25lbs of free hanging weight. So, I'm gonna make a mold of the ski pass assembly, and then get creative with MDF to create the final structure.
Well....went ahead and ordered a bunch of stuff from US Composites. Gotta get this moving. This will be my first time with fiberglass..so...crap...this stuff seems scary!
The JL 10IB4 subs weigh about 10lbs each and normally the whole assembly mounts to the firewall using a single screw and is flimsy as such. So, my thought was to drill additional holes in the assembly and the firewall to secure it better. Here's the mounting points I was thinking of. (The one's in red are primary mounting points, and the ones in yellow are secondary, if I think the 4 bolts won't be enough).
I'll of course throw in weatherstripping/foam around the whole opening where the assembly touches, to decouple it.
Thoughts?
