Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1996 - 2003 (E39)
Old 11-25-2009, 09:19 PM
OJwerks OJwerks is offline
Cars: just germans
Send a message via AIM to OJwerks Send a message via MSN to OJwerks
Red face suspension part numbers...
anyone have a list of 540i suspension part numbers for all the bits, control arm, tie rods, etc etc...all the "wear" items that should be replaced when doing a susp. overhaul...
im sure it has been posted I just cant find it..
2001 BMW 540i E39
Eibach l Bilstein l iForged l Nitto l Magnaflow l Euro-Dyne
under construcion...http://forums.bimmerforums.com/forum...1#post16144513
Old 11-25-2009, 09:29 PM
mattmartindrift mattmartindrift is online now
Cars: 98 540i6
just look at the realoem.com diagrams.
anything that has a ball joint or bushing is a wear item.
front:
thrust arms
tie rods
sway bar end links
upper shock mounts
rear:
upper wishbone
integral link
lower ball joint
lower control arm (i forget if the bushing are replaceable, but I don't think so)
Old 11-25-2009, 09:37 PM
Cars: just germans
front:
thrust arms
tie rods
sway bar end links
upper shock mounts
rear:
upper wishbone
integral link
lower ball joint
will do!! thanks for the suggestion ....
just wondering if anyone had an actual part number list put together..
2001 BMW 540i E39
Old 11-25-2009, 09:39 PM
e39dream's Avatar
e39dream e39dream is offline
five a day
Cars: m52 powered
Send a message via AIM to e39dream Send a message via MSN to e39dream
PM coming.
Old 11-25-2009, 11:01 PM
Cars: just germans
Originally Posted by e39dream View Post
PM coming.
I kinda put together a list using Realoem before checking back in...
here it is.... just feel free to edit anything on it, it may be overkill, everything I could think of except strut/shocks and springs.
540i suspension parts: List Price:
Front Parts:
Front Lft traction strut without rubb.mounting 31121092609 $188.78
Front Rght traction strut without rubb.mounting 31121092610 $188.78
Front Set rubber mounting f traction strut (2) 31120006482 $66.97
Front Wishbone, left 31121141961 $212.11
Front Wishbone, right 31121141962 $212.11
Front Sway Bar End Link (2) 31351095664 $43.88
Steering Parts:
TIE ROD,CENTER 32211096059 $320.06
LEFT TIE ROD 32211091723 $82.31
RIGHT TIE ROD 32211091724 $81.31
Steering arm 32211141592 $97.23
Steering arm Rubber Mount 32211136452 $26.77
Rear Parts:
Axle Carrier Rubber Mounts (4) 33311091422 $76.91
Axle Carrier Rubber Mount (front) 33171090389 $18.93
Azle Carrier Rubber Mount (rear) (2) 33171093008 $33.38
Driveshaft UNIVERSAL JOINT 26111229065 $110.44
Ball Joint (2) 33326767748 $63.35
Snap Ring (for ball joint) (2) 33321091687 $1.25
INTEGRAL LINK (2) 33326770749 $48.90
Guiding suspension link (2) 33326768791 $236.12
ECCENTRIC BOLT (2) 33306760591 $4.50
Wishbone, left 33326767831 $240.76
Right wishbone 33326767832 $240.76
Stabilizer link (2) 33551095532 $32.08
Engine / Auto Trans mounts:
LEFT RUBBER MOUNTING WITH FLANGE 122111092823 $92.13
RIGHT RUBBER MOUNTING WITH FLANGE 122111092824 $92.13
Auto Trans Vibration absorber 133316770851 $79.65
2001 BMW 540i E39
Old 11-25-2009, 11:54 PM
Mark@EACTuning Mark@EACTuning is offline
Senior Member
Supporting Vendor
Cars: any time, any place
the list looks really good for an overhaul, and if you enter the part numbers into our site you will see that a lot of those prices are high on realoem. I am assuming you did upper strut and shock mounts when you did the shocks.
I would suggest one thing however, and that would be to drop this stuff:
In favor of a set of these:
http://www.eactuning.com/e39-thrust-...ngs-p-453.html
You would get the same Lemfoerder arms as you would by ordering with the above part numbers, but instead of the factory fluid filled bushings you get Meyle HD solid bushings, which is truly one of the best upgrades you can do to the front end of any e39. You don't have to take my word for it either, there is a good number of e39 guys who are running them. They also are just a bit cheaper than the realoem listed price.
We press the bushings in for you with our HD arms, so all you need to do is install the arm on your car. If you ordered as your list you would need a hydraulic press to put them in the arms before you could use them.
If you have any questions shoot me a PM or email.
Click the image above to visit our Store!
Service available by appointment in Northwest Indiana
///EAC SPECIALS FOR BIMMERFORUMS!!
http://forums.bimmerforums.com/forum...php?p=18617463
