Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1996 - 2003 (E39)
Old 11-25-2009, 05:15 PM
Brandon540m Brandon540m is offline
Cars: 03 540 6 speed
My car took a pee pee yesterday.. :( pic
Heh, upper radiator hose decided to explode on me after a bout of acceleration. Luckily the dealer had my part and it is about the easiest hose you can ever change. Total time to change about 25 minutes including new coolant and bled. Why, why would BMW use plastic parts for a cooling system? Thank god it wasnt the bottom hose.. lol if you look way back you can see my trail of coolant around the building.
03 540 6-speed
Dinan exhaust, sway bars, short shifter..
Old 11-25-2009, 05:25 PM
crdiscoverer's Avatar
crdiscoverer crdiscoverer is offline
We're not an island!
Cars: 97 Euro 528, 78 KE30
Send a message via MSN to crdiscoverer
Damn! I need to change that hose now... thank you for making me worried about something else in my car. lol.
"Whenever I'm suffering from Insomnia, I just look at a picture of a Toyota Camry and I'm straight off."
Old 11-25-2009, 06:38 PM
Constructo003 Constructo003 is offline
Cars: 1997 528i
hahah, sounds like a good idea
Old 11-25-2009, 07:03 PM
Fiziks's Avatar
Fiziks Fiziks is offline
my name is andy.
Cars: e39 540
Send a message via AIM to Fiziks
Just because it failed on someone else's car does not mean it's about to blow on your car. Wasted money imo.
Old 11-25-2009, 07:04 PM
I was kidding. Serious guy
Old 11-25-2009, 07:10 PM
OJwerks OJwerks is offline
Cars: just germans
Send a message via AIM to OJwerks Send a message via MSN to OJwerks
well...thats a common sight... lol
2001 BMW 540i E39
Eibach l Bilstein l iForged l Nitto l Magnaflow l Euro-Dyne
under construcion...http://forums.bimmerforums.com/forum...1#post16144513
Old 11-25-2009, 07:47 PM
cal45fan's Avatar
cal45fan cal45fan is offline
Out and About
Cars: 97 528i 00 ML430
That happened to me, too. Though it was not the hose but the upper radiator neck breaking off.
FS:
2003 E39 CELIS Tail lights $250
HAMANN CAPS 65mm O.D. $30
E34 A/C control unit no scartches like new $40
E38 E39 Heater Valve $50
Cruise Control Switch $5
Amber sidemarkers $10
Hood plunger switch $5
OEM Bosch Injectors X6 $50
Intake Air Temp Sensor $10
Read driver side door lock assembly (no actuator) $30
Used (10k miles) Water Pump with metal impeller $20
Fan Clutch $40
Radiator Fan (mechanical) $25
CD Changer from a '99 540i $150
Rear OEM tail lights 1997 (no scratches-pristine) $60
E46 (3 Series) Business Indash CD Player $150
PM me.
PLUS SHIPPING...
Old 11-25-2009, 07:55 PM
Cars: 1997 528i
Cool
haha for real guy!
Old 11-25-2009, 07:58 PM
Yea that woulda really ruined my day.. luckily it was just the plastic inside the hose that broke on mine.. I think my radiator was replaced around 2 years ago according to maintenance records..
Heres' another funny thing, do you think BMW coolant is any different then other coolant? The guys at the dealer were convincing me that it was, so I ended up doin it but i feel stupid paying 15 bucks for a jug of that crap..
03 540 6-speed
Old 11-25-2009, 08:51 PM
Maybe it prevents the cooling system from having suicidal tendencies? Haha... it's so sad
Old 11-25-2009, 09:07 PM
jamesdc4's Avatar
jamesdc4 jamesdc4 is offline
Rogue Moderator ಠಠ
Cars: 98 540iA (Prd 11/97)
So, did part of the radiator neck break? You mention plastic and this...
E39 Ugly Mugs________________________________Registry Photos
Old 11-26-2009, 03:37 PM
No just the plastic in the radiator hose.. you can see the pic i posted with the big red arrow pointing to the crack. theres hard plastic inside the hose all the way past the clamp, because the clamp is what holds the rubber onto the the plastic connector..
03 540 6-speed
Old 11-26-2009, 05:08 PM
jamesdc4's Avatar
Rogue Moderator ಠಠ
That's a different kind of clamp than I'm used to. My 98 540 has this instead...
Still, it sounds like your radiator neck DID break off. Tell me if I am wrong, but part of the rad. neck snapped off. A common problem. You can temporarily fix it by clamping on to the existing part of the neck that remains, but it may just break off again.
How old is the radiator? If you are even slightly unsure of the rad. replacement, I would recommend replacing with a new one.
Old 11-26-2009, 05:21 PM
Cyrix2k's Avatar
Cyrix2k Cyrix2k is offline
V8 Power!
Cars: e39 540i/6, e36 318iC (now my parents)
the factory hoses are really thin. It worries me. I had a generic hose on my car before and it was easily 3x as thick as the oem hose. Unfortunately, I put my fan into it when the motor mount ripped in half. Amazingly, the fan didn't cut through the hose and everything was fine until I received the new hose... at which point I did a double take when I saw how thin the new hose was.
Mods: 3.15 diff, high performance coil packs, 17x9" rear wheels, clear tails, K40 stealthed radar detector, 3" exhaust, Thrush 17661 muffler
Old 11-26-2009, 05:59 PM
boomshakalaka boomshakalaka is offline
Cars: 99 540i6
I had the same problem, theres a plastic fitting that secures the hose to the neck. When I explained it to the shop on the phone while I waited for a tow they were not hopeful. They thought it was most likely the neck, and I was like "uhh, nah unless Im retarded..." And luckily they were wrong, cuz I had just had my radiator replaced!
Old 11-26-2009, 07:08 PM
nah not the radiator neck.. i wish i had my old hose id take a pics.. heres an amazing paint diagram i made for you as a cutaway view.. hopefully you understand it..
03 540 6-speed
Old 11-26-2009, 07:26 PM
jamesdc4's Avatar
Rogue Moderator ಠಠ
So it is a completely different kind of connector. Thanks.
Nice drawing, too.
Old 11-26-2009, 09:53 PM
bluebmw83 bluebmw83 is offline
Cars: bmw 528i sport
Send a message via Yahoo to bluebmw83
wow the same thing happen to me two days ago and my father also my mechanic said the same thing why did they use plastic piece, and autozone nor murrarys carry the correct hose so we had to retrofit so i could get to work. and how much did u pay for the right hose wit plastic piece?
damn i love this car.
Old 11-27-2009, 02:24 AM
Well i got a hookup on wholesale price so for me it wasn't much at all, it was 25 bucks for the hose OEM from the dealer.. but even if you would have ordered it OEM through an independent it was like 37 dollars (i went to an indy first cause it was closer to where it happened, but they didnt have it in stock)
03 540 6-speed
Old 11-29-2009, 04:05 PM
ok 37 isnt bad but it does come with the plastic piece right?
