Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1983 - 1991 (E30)
1983 - 1991 (E30) (1983 - 1991) Born from the sporty character of the 2002 and the sharp design lines of the E21, the E30 was a blend of the best of BMW's heritage. The second generation 3 Series provided a thrilling driving experience that used the best technology available.
Old 11-25-2009, 03:28 PM
Popobo69 Popobo69 is online now
Cars: 90 325iC, 90 325is
would this rebuild work?
rebuilding an m20 motor and changing gaskets. Does this have all the gaskets I need? http://www.carpartsdiscount.com/auto...tml?3593=58910
Thank you
Old 11-26-2009, 11:58 PM
Old 11-27-2009, 12:12 AM
strad strad is online now
1-5-3-6-2-4
Cars: one too many
The top end set is fine. I haven't worked on the bottom end so can't help ya there. It's probably fine too since VR is a reputable company.
edit: you'll need the tb gasket if you separate the tb and intake manifold. Not in the top-end kit.
1997 328is, 90.5k-118.7k miles, Cosmos Schwartz Metallic
1992 325ic, 148k-162.2k miles, Lagunengruen Metallic
1991 535i, 127.5-136k miles, CalypsoRot Metallic
SÜNDE REISEN
1 out of 1 members found this post helpful.
Old 11-27-2009, 01:49 AM
Wojtek79 Wojtek79 is offline
Cars: 99 M Rdstr, 89 325is
Price is ok. Although you may want to research the manufacturer. I know nothing of this though.
Old 11-27-2009, 02:22 AM
draccent's Avatar
draccent draccent is offline
GI
Cars: Moby Dick the whale.
Victor Reinz is one of the more notable and durable brands for gaskets.
I tend to use their gaskets for pretty much anything I replace if I have the choice and they are top notch.
My car has a front and back deck
Diving boards need love too.
Old 11-27-2009, 06:15 AM
AlarmedBread's Avatar
AlarmedBread AlarmedBread is online now
Gauges work!
Cars: 88 325is
Send a message via AIM to AlarmedBread Send a message via Yahoo to AlarmedBread
Missing the oil cooler housing orings and such if applicable.
Old 11-27-2009, 08:55 AM
Recommend it for a rebuild on a 90k mile engine?
Old 11-27-2009, 09:03 AM
Ranger1's Avatar
Ranger1 Ranger1 is offline
Voice of reason
Cars: E30, E36 DD, Ram Tow
Re. Rebuilding a 90k motor. God no. I recall reading a while back that M20's are at their peak hp around 80k miles. Rebuild it when a compression or leakdown test tells you the piston's aren't sealing, your headgasket fails or you lose a bearing.
Re. type of HG. There is a good thread at E30Tech that strongly suggests OEM or Goetz HG's instead of VR. It's a pretty compelling thread.
Porsche Certified Performance Driving Instructor
www.Gress.org
Old 11-27-2009, 09:32 AM
Do don't change any seals or anything when it's out of the car??
So*
Old 11-27-2009, 10:51 AM
thejlevie thejlevie is online now
Cars: 99 M3, Spec E30 #96 (NASA-SE)
This is a re-seal job, not a rebuild. Which means replacing gaskets & seals, but not the head gasket.
Jim Levie, Huntsville, AL
NASA & BMWCCA Certified Instructor
Old 11-27-2009, 12:43 PM
Are replacing all the seals something that's a DIY?
Old 11-27-2009, 12:52 PM
1-5-3-6-2-4
Cars: one too many
Of course. Make sure you have a torque wrench for gaskets. Proper torque, if not critical in most instances, is at least very important.
SÜNDE REISEN
Old 11-27-2009, 01:02 PM
Stück's Avatar
Stück Stück is online now
455BHP 6SPD E30
Cars: '91 332iS, '95 M3
Send a message via AIM to Stück
So wait.. you are going to rebuild a 90k mile M20, but are asking if replacing seals is a DIY?
I think you really need to consider what you are planning to do... on several levels.
- Jordan Sarette : '91 332iS.SC - '95 M3 - '95 740iL - Mods - My Photo Galleries
Old 11-27-2009, 01:08 PM
kishg's Avatar
kishg kishg is online now
E30 fan
Cars: too many bmws
he has re-sealing and re-building confused. OP, please do a search, there are many threads on replacing seals. You do not need to "rebuild" your 90k M20 unless your down on compression as ranger mentions. You can do a compression/leakdown tests to determine that but unless the motor has been abused i'm pretty sure the bottom end is fine. Again, research a bit more before you start new threads.
'90 E30 M3
'91 325i Sport
'87 325ic
'03 540i/6 M-Sport
'05 X5 3.0 Sport
BMWCCA #360858 SCCA# 374179 NASA # 128290
My Track Schedule
Lemons South Fall 2009 Blog
Old 11-27-2009, 01:09 PM
Poor choice of words on Popobo69's part. The intent is to replace the gaskets and seals, other than the head gasket, before installing the engine in the car. Even on a 90k mile engine that is a good idea. They may not be leaking yet, but it won't be long before they will be. And it is, o so much easier, to do that with the engine on a stand than in the car.
Old 11-27-2009, 02:29 PM
Sorry guys I was on my iPhone and I needed last min advice. I was meaning to say "refresh" rather rebuild. Sorry
