Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > General BMW Discussions sponsored by Intercity Lines
General BMW Discussions sponsored by Intercity Lines General discussions about BMWs, not specific to a particular model or one of our other Forums. Intercity Lines.
Old 11-25-2009, 04:39 AM
sm32589g sm32589g is offline
Cars: 1999 323is, M-package
is my car leaking coolant?
ok so i am starting to wonder if i have a leak in my system. Once every 1 month i have to replace about 8 ounces of coolant into my reservoir tank. is this normal or do i have a leak somewhere?
Old 11-25-2009, 04:44 AM
Cheyne's Avatar
Cheyne Cheyne is offline
Cars: E38 740i, MK1 Abarth Uno Turbo
Sounds like you have a leak. Get your system pressure tested before it gets worse.
Old 11-25-2009, 05:31 AM
kornkid8600's Avatar
kornkid8600 kornkid8600 is online now
Foxhound Unit
Cars: '96 Boston M3
Send a message via AIM to kornkid8600
Not normal.
Petition to eradicate CA front plate:
http://www.petitiononline.com/caplate/petition.html
Rule the Bends, Bend the Rules
Old 11-25-2009, 10:59 AM
marinm88's Avatar
marinm88 marinm88 is offline
Cars: 1999 323is
yeah man. get it checked out quick before it gets worse.
Old 11-25-2009, 01:05 PM
robmpulse's Avatar
robmpulse robmpulse is offline
The Bee's knees
Cars: 1990 325i cabrio, 19
Send a message via AIM to robmpulse Send a message via Yahoo to robmpulse
coolant system is a sealed system. Not only on your car, but EVERY car. That means if you have to keep adding it.... it's going somewhere....
Is this your first car?
Signature Disabled - Check the Signature Rules... Fix your signature FIRST!
Afterwards post in the signature/avatar request thread in the forum suggestions forum.
Old 11-25-2009, 01:42 PM
ks6gp0 ks6gp0 is offline
Cars: 1986 325es (2), 1989
Get it checked may be as simple as a bad cap.
Old 11-25-2009, 01:56 PM
slocar's Avatar
slocar slocar is offline
fastcar
Cars: e36
Are you sure you're not just overfilling it and having it blown out from under the cap?
Old 11-25-2009, 03:11 PM
sweet e36 pimp's Avatar
sweet e36 pimp sweet e36 pimp is offline
Bavarian Cream
Cars: e36, e34, e28 (rip)
Send a message via AIM to sweet e36 pimp Send a message via Yahoo to sweet e36 pimp
^^^ what he said... top off when the motor is ice cold, it should be at the "kalt" (cold fill line) in the expansion tank.
BMW Parts Whore... BUY THEM PLEASE!!!
Old 11-25-2009, 07:53 PM
ptarditi ptarditi is offline
Cars: '83 e23, 01e39 540/6
Get it pressure tested, but even though the coolant system is a closed system the modern car runs at such a high temp that some coolant will eventually evaporate.
Old 11-26-2009, 07:34 PM
amyracecar007's Avatar
amyracecar007 amyracecar007 is offline
Cars: E36 328is and E46 M3
My car suffers a smiliar disorder
I had an issue with the cooling system - long story short it said it needed coolant and it wound up with a totally new cooling system (from a to z). No matter what I do (keep coolant at full) it decides it likes to operate at about half way down from the cold/full line.
The sensors are all good, it never says low coolant except twice a year and it is still at its 1/2 full self preferred level. The system has been bled, pressure tested, and as I said completely replaced.
I decided the car has its own mind...or some sensor is lying to it....or I don't know but everything runs smoothly and I keep a close eye on regular pressure test and coolant flush.
I have even had different shops do the pressure test....car has been like it since i bought her about 5 years ago.
Old 11-26-2009, 08:04 PM
MJFX328's Avatar
MJFX328 MJFX328 is offline
Cars: 2.8L Sedan
Send a message via AIM to MJFX328
The expansion tank should only be half full
