| 1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life. |
Thread Tools |
Loud noise heard in car
I have a 2000 323ci, and when I take off from a stop I hear a loud noise coming from underneathe the parking brake handle and armrest area. It kinda sounds like a coke can is stuck in there or something, any ideas on what this could be? Drive shaft?
well i looked under the car, i didnt see anything out of the ordinary, so i doubt its a subframe issue. i think its the u-joint, and as from reading u cant just buy the little piece you have to get the whole assembly, am i right?
Ya on these cars you cant just buy a U-joint and put it in, you have to get the entire driveshaft. Did you check the... um cant remember the name, but the flange thing that connects to the transmission for any excess wear or damage?
When does the noise happen can you give more details?
Could be the center support bearing or flex disc.
Imola Red 2004 330i ZHP | ESS TS2+ SC | KMS 3.23 LSD | AST 4100 coilovers | H&R anti-roll bars | Vorshlag camber plates | Vorshlag RTAB limiters | TMS subframe & swaybar reinforcements | UUC SSK & DSSR | UUC TM & TME | BimmerWorld engine mounts | Dinan strut & shock tower bars | EMP Stewart water pump | XM Radio
the noise is really bad at low rpms during take off. seems to be right under where the arm rest is. sounds like something is clanking around when i start off from a stop, its really loud when under a hard acceleration from a stop or going under 10 mph. ill check into the other parts such as the guibo, center support bearing and the flex disc as well. |
guibo = flex disc
I had a loud clank or thud in my car, and I just raised the rear end off the ground and had my dad dumped it in gear at around 1500 rpm while I crawled around under the car looking for the problem. For me at least it turned out that my rear subframe mounts/bushings were finised.
I think you will have a good chance of locating the problem if you do as I did, raise the rear of the car and get under there with a flashlight and dump it in gear if you have a manual.
i do have a 5spd, but that sounds kinda dangerous, sounds like it will work tho, i may have to try it. what do you mean by dump it in gear tho? thanks |
Dumping into gear usually means reving the engine up a bit before engaging the gear... Like when trying to do a burn out, you rev it up and then dump the clutch... slang speak for grease monkeys and motor heads.
Well i believe the problem is the center support bearing and the flex disc looks pretty bad. so i ordered a center bearing, anyone know a good place to get the flex disc along with some exhaust pipe gaskets and some new nuts for the exhaust piping?
Well i ordered the flex disc, lock nuts, exhaust gaskets and exhaust nuts from pelican parts. I ended up ordering the center bearing from advance auto, (pelican was out at the time) but advance didnt give me the backing plates or the new circlip. Do i really need new ones or can i just reuse the old parts?
| Bookmarks |
| Thread Tools | |
