Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1988 - 1996 (E34)
Old 11-24-2009, 07:47 AM
jfj707's Avatar
jfj707 jfj707 is online now
Cars: '95 525i/5
Car runs cold in winter
My wife's car (the 525i) seems to take forever to warm up (any season), but especially in the winter - and it hardly gets above the 11:30'-ish mark.
Should I suspect a lazy temp sensor? Or go ahead and pull the t-stat housing to make sure I have a thermostat? =)
I have not heard of a failed thermostat sticking open; is this possible, too? I guess they normally stick closed and cause overheating.
edit: corrected because my clock analogy was way off. It hovers near or just above the hash mark to the left of noon.
FS - UUC Short Shifter + DSSR (from early E36 325i, will work with E34's), E36 Getrag manual swap parts, M30B35 and M50tu parts
Old 11-24-2009, 08:21 AM
auto da fe's Avatar
auto da fe auto da fe is offline
Cars: 535i x 2
Just replace the thermostat. It's not working properly.
"You don't know..what you're talking about." Norman, to Enid in Ghost World.
Old 11-24-2009, 08:36 AM
Miche's Avatar
Miche Miche is offline
BMW Mechanic
Cars: Alot of bimmers &...
I will second that it's a broken (open) thermostat that's causing it. A thermostat that is stuck open makes the waterflow to be very high, which causes the engine to run cooler, and that's why it can take forever to get hot air inside.
And yes, a thermostat can be stuck open or closed when it's broken!
PREVIEW for fuckers who has a hard time believing.
Old 11-24-2009, 10:20 AM
jfj707's Avatar
Cars: '95 525i/5
Make any difference on the 88C or the 92C thermostats? I'll get this done in the next week or two.
So the stuck/broken thermostat could actually keep it from ever quite getting up to temp?
Old 11-24-2009, 10:54 AM
LouieD's Avatar
LouieD LouieD is offline
Cars: e34x2 & '87 e30
I'm not sure if it's by design but it seems that a lot of us with e34's have experienced stuck open thermostats. I'd start with the 'stat and go from there.
Old 11-24-2009, 11:02 AM
David325e David325e is offline
License Suspended
Cars: 89525i 87325is 94540
Send a message via AIM to David325e
Yea, thermo will stick open. Happened to JACD1 this week and to myself last winter. Mine came out in 3 whole pieces.
Old 11-24-2009, 12:37 PM
Miche's Avatar
BMW Mechanic
88C is a "summer"thermostat and 92C is a winter thermostat.
But you can use any of them as you like any time of the year.
The benefit with a 92C thermostat on the winter is that you get warmer air in the car faster, usualy you have a 88C thermostat in the car though.
A broken thermostat will give you no hot air as the waterflow is at max all the time, and even higher when you're driving (faster rpm's on the waterpump)= cools more.
So you usualy end up never coming up to the middle line on the temp gauge as the temp won't go up there thanks to that.. So yes on your question!
Old 12-14-2009, 11:52 PM
jfj707's Avatar
Cars: '95 525i/5
I replaced the stat and the cars runs up to its proper temp now =) I could not see any visible defects in the one I removed - but the new one fixed the problem.
Thanks all!
Old 12-15-2009, 12:03 AM
mtg729's Avatar
mtg729 mtg729 is offline
BMW CCA Member
Cars: e34, wrangler
Thanks all!
If you feel like checking it for shits and giggles drop the old tstat in a pot of boiling water (or in the temp range) and see if it opens.
^ unter dem messer^
Old 12-15-2009, 12:05 AM
jfj707's Avatar
Cars: '95 525i/5
Makes sense... btw, what coolant temp does "noon" give us?
Old 12-15-2009, 12:09 AM
mtg729's Avatar
BMW CCA Member
Cars: e34, wrangler
For some reason I want to say 210 degrees F. I could be wrong though.
^ unter dem messer^
Old 01-04-2010, 10:15 PM
renegadeforce's Avatar
renegadeforce renegadeforce is offline
Cars: e34 525i 93
Send a message via AIM to renegadeforce
whats the best brand to get a thermostat?
Old 01-04-2010, 11:07 PM
schindig000's Avatar
schindig000 schindig000 is offline
enthusiast
Cars: 1995 540i e-34
I am having the same exact symptoms with my 95 540, will this cause the check engine light to come on too? Thanks!
Old 01-05-2010, 12:41 AM
alvino alvino is offline
Cars: E34 520i
BEHR thermostat
