Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1999 - 2005 (E46)
1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life.
Old 11-23-2009, 12:58 PM
jcwaybmw jcwaybmw is offline
Cars: 325ci
Special bmw tool? - oil filter housing gasket
Hello,
I am about to replace my oil filter housing gasket.
I read on here that a special bmw tool is required to remove the fan.
is this correct? if so, where do i get the tool?
is a 36 mm required? where do i get that.
thanks,
Old 11-23-2009, 01:01 PM
fermunky's Avatar
fermunky fermunky is offline
I am NOT impressed.
Cars: 01 330i, Unicycle
Send a message via AIM to fermunky
There is a special tool, and it is not "required", just makes things easy. The special tool will help keep the engine from turning when trying to loosen the fan's large nut. However, if you get the wrench and it has a long handle, you can knock it loose with a large mallet.
Old 11-23-2009, 02:27 PM
danewilson77's Avatar
danewilson77 danewilson77 is online now
Quandt member wannabe
Cars: 01.5 TiAg 325i..134k
Yup......36mm and a 2lb Kobolt sledge from Lowes worx great.
18" Enkei EKM3's w/Khumo ASX's ~ DDM Tuning Coilovers ~ Matte Black Kidneys ~ B&W Hood/Trunk Roundels ~ Smokes All Around With LED Eagle Eyes ~ Bavauto License Frames ~ M-Style Lip ~ Debadged ~ VANOS Rebuild-Done ~ GPS Mount Mod ~ Pillar Mod ~ Custom Trunk Interior~Colgan Nose Bra~Xenon Plate Bulbs~Custom Interior Trim By Feia0303
nathancarter's Avatar
nathancarter nathancarter is online now
You said 'Member'
BMW CCA Member
Cars: 2002 330i 118k
The wrench is 32mm (36mm is for the oil filter lid). I think. Maybe I'm mis-remembering. Yeah, I don't know, I always get 'em mixed up.
Anyway, if the sharp smack with the hammer doesn't work, you can wedge a big screwdriver between the fan pulley bolts, to counter-hold the pulley. Not an elegant solution, but it worked for me.
Old 11-23-2009, 02:39 PM
Or, apply reverse tension to the tensioner pulley to prevent pulley rotation....while someone, loosens the fan
32mm...Nathan is correct...
Old 11-23-2009, 03:02 PM
Cars: 325ci
32mm socket? where
does sears sell this 32 mm socket?
do i need a 32mm socket? or a 32 mm wrench?
Old 11-23-2009, 03:13 PM
yonmoor yonmoor is offline
Cars: BMW ZHPoop
I did the oil filter housing gasket yesterday and got away without removing the fan. Not sure if you'll have to on yours - mine is the clutchless type.
Old 11-23-2009, 04:03 PM
Cars: 325ci
so you have an automatic.
what series bmw do you have?
i have a 325ci
Old 11-23-2009, 06:18 PM
Cars: BMW ZHPoop
I have a 2003 330i in a manual. I've read that on the older ones the fan drive is attached to the water pump or some shit. Don't know, but you might be able to get around it.
What I did was basically stick a ratchet into the belt tensioner and attach a long pipe from my jack to the ratchet to use as a cheater bar. Worked like a charm and belt slipped right off.
Old 11-23-2009, 06:35 PM
as pictures above
