Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > General BMW Mechanical Help sponsored by RM European Auto Parts
General BMW Mechanical Help sponsored by RM European Auto Parts Do you need help with general mechanical problems or have questions about maintenance procedures? Talk to your friends and RM European Auto Parts.
Old 11-23-2009, 08:46 AM
ponton ponton is offline
Cars: 04 X3
04 E83 Loud bang and smoke
04 E83 Wife started car this morning and as soon as it caught there was a bang like a gunshot. Little smoke under the hood, smelled like something electrical. I started car and it ran but there was a light banging noise and rpm's were all over the place. I shut it off in less than 15 seconds. This is a new one on me, any ideas?
Old 11-23-2009, 02:12 PM
Stück's Avatar
Stück Stück is online now
455BHP 6SPD E30
Cars: '91 332iS, '95 M3
Send a message via AIM to Stück
Sounds like a intake backfire, blowing lose a vacuum hose.
Tow it to the dealer...
- Jordan Sarette : '91 332iS.SC - '95 M3 - '95 740iL - Mods - My Photo Galleries
Old 11-23-2009, 11:37 PM
turbovrGTI turbovrGTI is offline
Cars: 08 GTI, 97 540i
i did see an e53 x5 blow its intake manifold apart last week when it was a colder morning...you wanna talk about COOL. haha
Old 11-24-2009, 06:48 PM
Cars: 04 X3
That is exactly what happened. Got it to BMW today and the manifold had exploded.
Dealer says the crankcase vent was plugged causing excessive pressure. I believe him but don't understand how it would cause an explosion.
Old 11-28-2009, 01:51 PM
PixMan PixMan is offline
Cars: '02 530i/A
Send a message via Yahoo to PixMan
Covered under warranty or not?
Old 11-28-2009, 02:08 PM
EURO M3 CSL's Avatar
EURO M3 CSL EURO M3 CSL is offline
Tee Hee...
Cars: E36M,E46M,951S,CBR
Send a message via AIM to EURO M3 CSL
wow subscribed.. got any pictures?
Old 11-28-2009, 02:35 PM
bimmer_boyis bimmer_boyis is offline
BMW Tech
Cars: Avus e30(sold), '95 Avus ///M, '94 525i 190k Daily
Send a message via AIM to bimmer_boyis
Wow that's impressive, never seen an m54 manifold break. They usually just smoke like hell or hydrolock when the seperators freeze up. Make sure they get you the cold weather one as a replacement. Also forgo the new dipstick tube. Its not that different and is way expensive.
Level 1 Certified BMW Technician
Old 11-28-2009, 03:24 PM
thejlevie thejlevie is online now
Cars: 99 M3, Spec E30 #96 (NASA-SE)
I've seen an S52 manifold blow a big chunk out of the bottom on a backfire. We were mystified as to why the engine wouldn't run and couldn't see the gaping hole underneath the manifold.
Jim Levie, Huntsville, AL
NASA & BMWCCA Certified Instructor
Old 11-28-2009, 11:32 PM
bmwdirtracer's Avatar
bmwdirtracer bmwdirtracer is offline
Cars: E34 535, E28 Racer, Lotus 7 clone
Saw this, too, M54 X5; mine was easy to see, tore a 1"x 20"rip just above the seam of the manifold. I agree. turbo, it was cool, in a perverse way. And we don't get cold, here, it was just a wierd intake pop (but loud).
Not supposed to happen, with modern Fuel Injection; but it sure does make me like aluminum manifolds. My old beast has popped at various times (piggyback fuel management and a radical cam), but never blew anything up.
Chris Powell
Master Auto Tech, at an independent, formerly @ dealer
BMWCCA 274412 SCCA 334928
Old 02-07-2010, 03:43 PM
jellezee jellezee is offline
Cars: BMW X3
Ponton,
Did replacing the CCV fixed the problem? Was it covered under warranty?
This morning when I started my X3 2.5 2004 (55K miles) in my garage (40 F) I had the same problem. A very loud explosion and smoke came out from the engine. When I opened the hood I saw that the intake manifold exploded and the fuel injectors were ejected from their cavities. I think the engine backfired and I can think of a number of reason why this could happen (valve stuck?, ECU failure?)
I don't think a blocked CCV can cause an explosion of such magnitude (correct me if I'm wrong) so I'm guessing this is something bigger. I was suspicions of the vacuum system because I had the valve cover gasket replaced due to oil leaks and I asked the dealership to check the vacuum system and they said everything was fine. Before this happened I was noticing some hesitation during the engine start up and small variance in RPMs when idle. This can be casued by problems in the vacuum system but no engine codes were ever shown or stored.
Can anyone help with this problem? What do I need to ask the dealership to fix and check? Can this explosion cause damage to any other parts/components? Thanks.
