Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1999 - 2005 (E46)
1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life.
Old 11-22-2009, 09:26 PM
ozkural ozkural is offline
Cars: 2002 330i
Angry Reprogrammed key now my headlights are not working at dusk time
Hello,
I am new to this forum and I have a 2002 330i BMW. Yesterday, I had to replace my key and re-programmed it. Today, I was driving at dusk time and I noticed that the dash board lights as well as my headlights are not coming back on. Is this a problem with re-programming my new key that I did last night or is this another problem that is causing my headlights to not go on at night time. Please help! When I turn the knob to my brights, the lights on the dash and my bright head lights do turn on, but when I turn the knob back to the regular setting, they lights do not turn on. I don't want to drive with my brights on at night and I cannot drive without any lights at all. Anyone have a solution? thanks, Shari
Old 11-22-2009, 10:58 PM
nick325xit 5spd nick325xit 5spd is offline
Slumlord
Cars: '04 M3 & #999 KP
Send a message via AIM to nick325xit 5spd
Something else is wrong. Also, technically, you're in the wrong forum.
2006 GMC Sierra 2500HD - 4WD Duramax LBZ/Allison 6-speed
2002 BMW M3 Alpinweiß/Black - AST 4100 - H&R 160-90 / TCKR VVS 400, Fikse Profil 13 w/285/30-18 AD08s, H&R Front/GC Rear bars,
----..-.....-----.-------------------- Rogue Octane SSK, Deka ETX30L, Hybrid C61-2 active on Kenwood X4R, IDQ12v3 on Blaupunkt VA1400
1999 323i KP/GTS2 Alpinweiß - Stock-ish, added front downforce, reduced visibility
1989 325is Alpinweiß/Black - S50B30, etc.
1988 M3 Alpinweiß/Black - Yes, I have a problem...
Hers: 1996 Porsche 911 Turbo Black/Black
Hers: 1988 325iX Coupe Diamantschwartz/Black 5spd - Lengthened front driveshaft, racetep cam, Bilsteins, H&R Sports
Old 11-23-2009, 04:32 AM
bishop1977's Avatar
bishop1977 bishop1977 is online now
Cars: 2004 330i zhp s/c
Keys have to be programed to settings
Old 11-23-2009, 05:28 AM
alongfortheride alongfortheride is offline
Cars: not my car, I am just along for the ride
Sounds like they pulled a fuse and didn't replace it.
Check out my husband's website
Old 11-23-2009, 01:32 PM
Critter7r Critter7r is offline
Craziness ensues....
Cars: 2005 325Xi
The lights coming on at dusk is not a function of the key, it's a function of turning the headlight switch to the "A"(Auto) position.
You don't "turn the knob" to get your brights to come on, you push the turn signal stalk forward. When you turn the knob you are either turning on the lights manually, or you're putting the light switch in the "A" (Auto) setting.
So when you say "When I turn the knob to my brights, the lights on the dash and my bright head lights do turn on, but when I turn the knob back to the regular setting, they lights do not turn on.", it's confusing. Turning the headlight switch to the right will make the headlights come on regardless of the outside lighting. Turning the knob to the left will put it in the Auto setting and the lights should come on when it gets dark. Pulling the turn signal stalk towards you momentarily activates your brights but doesn't turn on the dash lights (except the little blue icon), and pushing the turn signal stalk away from you turns on the brights manually and they stay on till you turn them off.
Any advice I may give here is - at best - tongue-in-cheek, and just as likely outright offensive. I've been doing this for a long time and I usually have a pretty good idea of that which I speak - but not always. So break out your grain of salt and try to keep up.
