| 1992 - 1999 M3 (E36) (1992 - 1999) BMW's second generation M3, and the first M3 to feature BMW's classic inline six motor. Featuring 240hp (european models had a 286hp and 321hp), a slick shifting gear box, and near perfect weight balance, the E36 M3 was named Car & Driver's "Best Handling Car At Any Price." |
Thread Tools |
oil change 1000 miles ago, oil light
I bought my m3 about 2 weeks ago and I put a 1000 miles on it. The day I bought the car, the shop did an oil change with 5w-30.
If I drive the car hard the oil light turns on for a split second. Only happens as i m taking fast turns and braking hard. I know the sensor isn't bad. Also I checked the oil level and it seems a little bit low. The car doesn't burn oil and its not leaking either. Where did the oil go? unless they didn't fill it up right. Also I thought Ms use different oil then 5w 30.
![]() Performance BMW car Sponsored by : www.euro-spec.net www.bimmian.com BMW Motorwerks support: www.vmwerks.com www.esstuning.com www.my330i.com |
Also, all of your oil type questions can be answered via this thread: http://forums.bimmerforums.com/forum....php?t=1003372 |
there is not enough oil in the motor - add more. when you turn hard the oil moves and throws the sensor.
Garage Queen: 2009 BMW M3 Coupe (Alpine White over Black Novillo Leather)
![]() Daily Driver: 2008 Mercedes Benz E350 Sport Sedan Previous: 1995 BMW 325is 1995 BMW M3 Coupe 1998 BMW M3 Dinan Coupe 2000 BMW 323CI 2001 BMW M3 Coupe (6MT) 2003 BMW M3 Coupe (SMG) |
You can use 5w30, but recommended weight is xW40 or higher. I'm running 5w40 Shell Rotella T synthetic.
Just so long that it isn't Mobil 1 5w30, because apparently it's too thin for what it is. You need 7 quarts for an S52. I usually do 7.5.
| Bookmarks |
| Thread Tools | |
