Fog light issue. Need help
My fogs are driving my absolutely insane. I run 6k HID headlights and 6k HID fogs. I just redid all the wiring in the fogs and both of them flicker (driver side much more then the passenger).
I need ideas on what the hell is wrong with them. Where is the Fog Light relay?
Could be the check system sending small amounts of engergy to the lights to check resistance causing the lower than factory resistance HID's to flicker...
![]() I think you can have the check fog system turned off via programming.
Just a thought, but do you use the error code eliminator adapters?
Upgrades: M5 rear sway bar, Apexcone 6000K HID, M5 lip spoiler, Ipod DICE kit, AFE Pro Dry air intake, 18" Beyern Mesh, mtecpower AE bulbs, black grill and window trim, silver gauge rings, rebadged as 3.0 E39 after some douche swiped the 530i off the back
Bro...sounds like the ballasts are going bad...try swapping your ballasts from your lows.
![]() authorized distributors of:: carbon 8 :: mycarr authorized seller of :: linea corse :: miro design :: dp engineering please don't hesitate to contact me for your BMW needs! AIM : eur0dyne || Yahoo : euro_dyne || MSN : eur0dyne Email : sales@euro-dyne.com || Phone : (657) 464-0728 ![]() |
I had three sets of ballasts going into today and three sets of bulbs. I tested all the ballasts and only one was broken and one bulb was blown so I definitely had a working set connected.
The dealer could program the computer or any indy shop with the GT1 software.
The code eliminator can be bought a DDM if I am not mistaken. I am sure there are others that sell it as well. try Google!
![]() ![]() ![]() 1997 540IA Arctic Silver 1999 328IC M Sport Titanium Silver |
is this the case with fog lights? i'm not sure you're able to select whether or not to run cold/hot checks individually. |
You can eliminate fog light check with Navcoder.
2003 530iA Sport - Titangrau Metallic/Schwarz Montana
Build Codes: ZSP/ZPP/ZCW. Born on date: 09/02, Dingolfing, Deutschland NAV MKIV | PP | CWP | Xenons | Style 42s | Rear Shades | OEM Bluetooth | Euro Armrest | Beisan Vanos Seals | 2001 525iA Sold |
| Bookmarks |
| Thread Tools | |
