Thread Tools |
Cigarette lighter on accessories?
Hi, I did a bit of googling and couldn't find anything of use on this subject. How would I go about changing the cigarette lighter config so it is active when the key position is on accessories?
I have to wait anywhere up to 4 hours in my car sometimes, and would like to be able to at least have my iPhone charging and playing music through my FM transmitter without wasting all my fuel. Thanks. Last edited by Tristan8712; 11-21-2009 at 09:17 AM.. |
It should charge even WITHOUT the key in the ignition... just sitting.
FS - UUC Short Shifter + DSSR (from early E36 325i, will work with E34's), E36 Getrag manual swap parts, M30B35 and M50tu parts
I wish mine was that way.....the front cig lighter should work at any time. I wish it would go off with the key out of the ignition so I don't have to turn the radar detector off and on separately all the time.
Chad // 1994 BMW 530i 5-spd // 1996 Range Rover 4.0 SE // 1990 Mercedes-Benz 300SE // 1996 Honda CBR600 F3
mine charges with the key out
Accepting Best Offers! Silver/Silver E34 M5 Part Out http://forums.bimmerforums.com/forum....php?t=1375237 |
I'm going to, just haven't had the time. I liked that the Jag would turn it off when I turned the car off.
OP: If yours doesn't work in ACC you need to rewire it so it taps into something that's hot in ACC, or even tap into the back of the ignition switch. Another option would be to wire in a second plug (in the back of console, or in the glovebox) that is hot in ACC, then you have a choice. Option 2 is probably about the same amount of work, with more benefits. |
http://forums.bimmerforums.com/forum....php?t=1334600 i have the lighter for it too.
I have a question for you; Do you live in your car? I know no one that would even bother to wait fo(u)r hours just to have the cig lighter turned on. That's just nuts!
And to topic, my cig lighter is on always too, the front one that is, and the one in i've wired in the glove box is on all the time as so is also the one i got in the hatch area. My rear (at the back seat) cigg lighter is wired so it is on when ignition is on and off when ignition is off.
PREVIEW for fuckers who has a hard time believing.
IIRC around 93-94 was when they changed (in the US) to ignition activated instead of constant on lighters. thus the disparate experience.
`03 Summit White Tahoe LT LM7, G80, GT4, PDZ, ZW7, G65, PDP, etc. Mutual Admiration Society Member #5 |
Tristan, I had a look in the Supplementary Owners manual - Australian Version and the cigar lighter can be used in the position 2 only (ignition switched on). It must be for compliance to the Aust. Design Rules, a local regulation that manufacturers have to comply to, just like installation of child restraint anchor points in the rear parcel shelf, among other things.
I think the solution offered by sfgearhead will do you and it will be fairly easy to get an ACC feed or a hot at all times feed for the lighter, just remember to protect the circuit with the correct fuse rating. Last edited by 530 i; 11-21-2009 at 07:27 PM.. |
AE - My '95 has power with out the keys, air'd up my tires today with a plug in pump and no keys
Mine's a 03/94 build and is always hot, and my 1998 540i/6 was also always on, as was my 94 E36.
95 540i/6 cig lighter is always hot.
Darren
91 V2500 Suburban 94 K1500 Blazer 95 540i 6 speed (E34) Women come and go, but a man can depend on a truck The Pessimist Complains About The Road. The Optimist Expects It To Get Better. A Leader Never Lifts The Throttle. |
Haha, really. I live in davis now, but my parents are still in fremont.
I'd bring the bmw by while i'm in town, but drove the sububan down this time
Darren
| Bookmarks |
| Thread Tools | |
