Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1999 - 2005 (E46)
1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life.
Old 11-21-2009, 06:33 AM
gjbimbli gjbimbli is offline
Cars: 2002 325i
LED Tail lights burned cells
Hi huys. I just noticed tonight that my DDM tuning led tails have burned cells in the yellow signaling part. What do i do? Is there a way to fix this by replacing only the burned LED or do I need to get the whole circuit with LEDs on them. Any advice is appreciated
Old 11-21-2009, 08:45 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Extremely Legit
Cars: Yes
Are they covered under any sort of warranty?
BMW E36 & MINI Cooper Graduate
"Do not believe anything you read on the Internet unless it is consistent with what you already know to be true, or you have taken the time to verify the information with another source." --Neal Boortz
E36 DIYs: Air Pump | Trunk Wire Harness | Vent Gauge | E46 Armrest | SmarTire TPMS
E46 DIYs: Hella TPMS | Aftermarket Horns Part 1 | Aftermarket Horns Part 2 | Window Regulator Notes
Old 11-21-2009, 07:26 PM
gamberroski gamberroski is offline
Cars: 330ci 2003
They are usually wired in series, so they usually go out by entire rows. Also the connections damage if the connecting cables are tight when installed. To repair them you have to open them. If you do post pics.
2003 330ci, Manual, K&N Intake, AC Schnitzer Alum. Strut Bar, LED taillights, 19" wheels (8.5 front and 9.5 rear), CSL V1 Front, 35% Tint, Red Gauge Needles, Blacked out headlight trim
Old 11-21-2009, 09:21 PM
Nick@Jlevi SW Nick@Jlevi SW is offline
www.jlevisw.com
Supporting Vendor
Cars: 2009 135i
Send a message via AIM to Nick@Jlevi SW
You will have to replace the entire tail light, they should be covered under warranty.
1.888.JLEVISW | sales@jlevisw.com | AIM: Nick at JSW
