Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1991 - 1999 (E36)
1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury.
Old 11-21-2009, 01:43 AM
tballin227 tballin227 is offline
Cars: 1994 Bmw 325i
Digital Climate Control ?'s
I have recently done the analog to digital climate control swap. Everything seems great except it seems like the blower isn't as strong as it was with the analog setup so i have a question.(especially if you did this swap but if you guys have the digital climate control your still able to help)
With the analog setup the air was pumped through the center vent but now with the digital setup its just coming out slowly.(the drivers side vent feels more powerful) Is this normal for you digital climate control users?
If not do you guys believe the blower motor is bad or i aligned the vents improper because when i'm outside of the car i can hear that the blower is definitely sucking a lot of air.
Or maybe any other ideas?
Thanks any help will be greatly appreciated,
T
Nevermind problem solved
