Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > Z (Roadsters & Coupes) > Z3 (E36/7, E36/8)
Z3 (E36/7, E36/8) (1996 - 2002) In 1996 BMW added the Z3 to the lineup. First available only with the 1.9 liter engine, the Z3 went on to carry every 6 cylinder produced between 1996 and 2002. A fun, sporty little 2 seater came both in convertible and coupe form. Being a bit of a “parts bin” car, the Z3 is part E30, part E36, but all original.
Old 11-20-2009, 04:57 PM
cainer cainer is offline
BMW CCA Member
Cars: '98 Z3 2.8,'04 FLTRI
Wooden E-brake handle loose
My wooden e-brake handle just slides on and off the e-brake metal handle. Clearly the glue dried up. Any suggestions on what adhesive to use to reattach the wooden handle. It matches the steering wheel and shift knob and all are in nice shape and I like the look so I'd prefer to keep it and save my money.
Suggestions appreciated.
Cainer
Old 11-20-2009, 05:02 PM
luciano136 luciano136 is offline
Cars: Z3-ML320-SV650-GTI
There are a few things that would work. It depends if you ever want to be able to remove it? Gorilla glue is strong stuff but I'd be a little hesitant in case the handle breaks and you need to remove it.
Mods: 6psi Supercharger kit; Rogue RSM's; Bilstein HD front and Sports rear (M springs rear); DINAN strut brace; Magnaflow exhaust; Stewart waterpump; Stoneguards, Glove box fix, M Shift knob; Aux input adapter; Mesh bumper grill; Projector Z II headlights (35W Xenon). Future: steering wheel leather, fix/replace rear window, sound upgrade, subframe bushings, alu radiator, wheels
Z3Couper's Avatar
Z3Couper Z3Couper is online now
[ǝıʞunɾ ǝoɥs uʍoןɔ]
Cars: Smurf Blue Clown Shü
Send a message via AIM to Z3Couper
I wonder if they use adhesive only on the wooden handle. I have taken off a few of the black leather handle, and they were all just friction fit. There was no residue on the metal lever beneath, or on the inside of the leather handle.
I don't have a specific recommendation for adhesive, but you'd want something that dries somewhat slowly. That way you could apply it to the metal lever, then slide the wood handle on and let it dry completely.
"Whoa? How Coupe is not a Z?" - TexaZ3
Old 11-20-2009, 10:37 PM
ssnobrakes ssnobrakes is offline
Cars: 01 Z3 2.5I
Maybe silicone adhesive would be the way to go..........It would be strong enough to hold and if you wanted to remove the handle just heat it up with a hair dryer and the adhesive would loosen up.
Steve
Old 11-20-2009, 11:20 PM
KBH22102's Avatar
KBH22102 KBH22102 is offline
Cars: 97 Roady, 02 M Coupe
Before going to the adhesives, maybe try wrapping the metal handle with a few layers of masking tape and then twisting the wooden handle on
Old 11-20-2009, 11:29 PM
rocknroad's Avatar
rocknroad rocknroad is offline
Slowly fading
Cars: MZ, MB, IT
What he said.
You don't want a permanent seal in case you ever want to replace your ebrake boot.
Old 11-20-2009, 11:43 PM
BMW CCA Member
I do like the tape idea and will give that whirl tomorrow. If it doesn't work out I can move to some kind of adhesive. Thanks for all the ideas and feedback.
Old 11-21-2009, 08:58 PM
Z3Couper's Avatar
[ǝıʞunɾ ǝoɥs uʍoןɔ]
Great input guys. Good idea with the tape.
