Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1988 - 1996 (E34)
Old 11-20-2009, 11:05 AM
78kitty 78kitty is offline
Cars: 5-series soon
Got Traction Control?
Hey all, Noob to BMWs here. I've been looking for a reasonably priced 90's BMW 5 series for a bit now. One thing I haven't found out is how to tell if the car has traction control. Is there an easy way to tell if the car has traction control or posi type rear end versus the standard open differential?
Old 11-20-2009, 11:09 AM
PorscheDude's Avatar
PorscheDude PorscheDude is offline
Old school punk
Cars: E34T Porsche 951
There is a button under the ashtray.
It says ASC.
I'M not sure, but I think it was common on the '94's and '95's.
95 E34 Touring Black/Black Project Sinister
86 951 Black/Black Lindsey 3" Exhaust, Lindsey DP Wastegate, Lindsey Black Knob, 3 Bar FPR, MaxHP Chips
SOLD
94 968 Polar Silver/Black, 6 speed, LSD, Kinesis K58's, Short Shift, Adjustable Konis, M030 Swaybars, KLA Upper Strut Bar, Design 1 Racing Lower Strut Bar, Air Box Mod, B&B Catback, RS Barn Chip, Big Reds
http://www.cardomain.com/ride/2426788
"I got kicked out of Barnes and Noble for moving all the Bibles to the Fiction section."
Last edited by PorscheDude; 11-20-2009 at 11:10 AM.. Reason: Automerged Doublepost
Old 11-20-2009, 11:30 AM
Cars: 5-series soon
Oh OK, thanks PorscheDude, so if it has the button it has a posi-traction type axle and if there's no button then it's probably a open differential.
Old 11-20-2009, 11:34 AM
Old school punk
No, I think most automatics with TC are open dif.
SOLD
Old 11-20-2009, 12:05 PM
Cars: 5-series soon
OK, so is there any way to tell if a car's got a posi rear end? Like on Ford's if the axle code is 2 numbers it's open and if it's there's a letter in with it that means it has posi-traction, or whatever Ford called it at the time.
Old 11-20-2009, 12:10 PM
4500 RPM's Avatar
4500 RPM 4500 RPM is offline
Don't judge me
Cars: '09 Miata
For the LS unit there will be an S on the case underneath the grime. A later car won't have it from the factory, they stopped around '92/'93
-Denton
Old 11-20-2009, 12:11 PM
ss109's Avatar
ss109 ss109 is offline
'Ringer
Cars: 07 335-93 M5-87 528e
Send a message via AIM to ss109 Send a message via MSN to ss109 Send a message via Yahoo to ss109
You can look at the metal tag attached to the final drive unit. If it starts with a 'S' (ex. S 373) then it has a limited slip differential. There isn't a way to tell without getting under the car, and most of them (especially since TC migrated into the cars) don't have a LSD.
Old 11-20-2009, 12:49 PM
Cars: 5-series soon
WOW great info! So I'm guessing if is says S 373 it means there's a 3.73 geared limited slip differential under the car?
What would a 1995 regular 540I with a 6-speed likely have for traction control if any?
Old 11-20-2009, 01:24 PM
GarrettSR5's Avatar
GarrettSR5 GarrettSR5 is offline
I hate you.
Cars: E34 6spd, Impulse RS
Send a message via AIM to GarrettSR5
Not sure I get what you mean here.
It would have BMW's ASC for traction control. Not much else there unless you want the tech specs
Yea there is, you can call the dealer and give them your serial number and they can tell you. Or there are members on here who can do the same
Originally Posted by The5Guy View Post
Garrett; From my days of lurking here sourcing information, to my first post, to the day I bought my car; every one of your posts has shown you to be an arse.
You, sir, are the first person I have ever encountered that makes me embarrassed to be from Boston.
I may be an elitist, a snob, and a complete jerk at times; but you take the cake on being an arsehole daily.
Good to know I inspire
Old 11-20-2009, 01:40 PM
ss109's Avatar
'Ringer
Perhaps, but the unit could have been replaced/swapped. I had that happen once.
Old 11-20-2009, 02:21 PM
Cars: 5-series soon
OK sorry. I assumed the 373 on the metal tag would mean it had 3.73:1 ratio gears in it, which apparently is not the case.
Old 11-20-2009, 03:09 PM
ss109's Avatar
'Ringer
No, that is correct. The tag will indicate which ration is in the case.
Old 11-20-2009, 09:00 PM
coolvegase34 coolvegase34 is offline
Cars: 1994 e34 525i
If i have a 94 e34 525i without an asc button, I am guessing it is open differential?
