Thread Tools |
Why is my car stronger when it's humid?
I noticed it runs better with alot more pull throughout the RPM range. Also any detonation like noises are completely gone. Just a solid rumble from the V8 and pulls hard in any gear. I noticed this effect when it's very humid outside and if it's been raining for a while. Why?
First rule of politics - the voters don't decide the election, the counters do.
The appearance of the Law must be upheld, Especially when it's being broken. |
Hmmm... a possible cracked intake? or a vacuum leak that is somehow stopped in the rain. BTW when has it last rained instead of snowed in NJ
![]() ![]() Old car->1992/E34/525iA/70k |
I have no vacuum leaks that i know of. lol. The car runs and idles just fine. Also the temp has actually been higher here, 60 deg now as opposed to the 50's and 40's. So i dunno what gives. Maybe a water injection system can benefit after all? BTW: It rained all last night. Quote:
You mean the air is denser when it rains? If not, could it be the steam effect of the water coming out of the air under combustion?
The appearance of the Law must be upheld, Especially when it's being broken. Last edited by Wolfen; 11-20-2009 at 09:40 AM.. Reason: Automerged Doublepost |
water vapor reduces the intake air temp (due to high specific heat) which in turn makes the air even more dense. It also further reduces the intake temp if the water vaporizes (due to high latent heat) and also tries to increase in volume. When water vaporizes in the chamber (Since volume is finite), this means a small amount of added pressure.
I am sure you guys have heard of water injection for turbo intakes back in the 60's. I have heard of many European, African and Asian turbo diesel trucks being setup with homemade water injectors. This was also beneficial in reducing hot spots inside comb. chamber and cleaning up some of the deposits. i am not sure the exact optimal ratio and even if the added power is actually measurable. You do feel it on the butt-dyno though..
www.google.com
In regards to intake of moisture into your car's engine, the advantage is two-fold: firstly, humidity can tend to go hand-in-hand with cooler ambient temperatures. Yes, I know it's not always the case (Florida, North Carolina, Thailand), but more often than not, air tends to get cooler with the presence of moisture. And we all know that cooler ambient temperature increases engine performance. HOWEVER, the most applicable advantage to adding a bit of moisture is thermodynamically. As the water is injected into the hot intake stream, it wants to vaporize and expand. Fortunately, when liquids vaporize, or compressed gases expand, they take in a lot of heat. This intake of heat is manifested by a removal of heat from the surroundings -- thus the air feels cooler. Likewise, when you compress something, huge amounts of heat are given off -- which is why your turbo gets so damn hot. This vaporization of the water lowers your intake temperature. And, as we've discussed, lower intake temperature = better performance. at 70F 30% RH air density ~ 0.075 lb/ft^3 80% RH air density ~ 0.073 lb/ft^3 a 1.5% difference, not much, but it adds up at constant RH of 50% 40F density ~ 0.079 lb/ft^3 90F density ~ 0.070 lb/ft^3 an 11% difference so both temp and humid have an effect, but temp's is greater at 40F/30% RH density 0.080 lb/ft^3 at 90F/80% RH density 0.069 lb/ft^3 a 15% difference almost directly proportional to HP gain (loss) |
Sport mode just ensures your car starts off in 1st gear, and holds the gears longer. Normally it'll start off in 2nd, or shift to 2nd immediately, so it feels like less power.
BTW water injection was in lots of production model GM engines prior to the 90s. It was a great system that allowed higher compression ratios and thus more power off less sophisticated engine degins. Problem is people werent refilling their systems, so a lot of the water injection engines have bit the dust. If I can find one I want to buy it, think it would be a fun little ride
![]() Evolution created man and man created Religion to explain the creation of man in the absence of the knowledge of the existence of Evolution. |
Is there much use of water/meth systems on NA cars? I want to get an AEM kit for my volvo along with a bigger turbo but NA applications dont have near as much heat going on as far as the air temp at the throttle body is concerned..
First interesting thread I've seen in a while! Good question OP.
I've actually had a dissimilar experience with humidity in VA on really hot days. My motor feels like its struggling more compared to cooler evenings when the air is chilly. I guess that is more due to the air temperature than the humidity though... Interesting nonetheless!
Rules to live by:
- Fast, reliable, cheap. You can only have two. - BMW: Just because you can afford to buy one, that doesn't mean you can afford to own one. |
| Bookmarks |
| Thread Tools | |
