So I have always heard and thought once the codes started flashing they would cycle through and show each code. Well, on mine the same code just flashes over, and over, and over, and over ad infinitum. I sat there for a good 8 minutes (yeah, I had too much time on my hands) watching the same damn 1222 code flash.
Finally started playing with the throttle, holding it, pushing 5 times, pushing once, etc. Suddenly it went to a new code. Waited a while, started playing, and it advanced again. Then finally got the 1000 I was waiting on.
Is it normal that you have to push the pedal in some pattern in order to see each code? If so, what's the pattern? I couldn't quite figure out what triggered it.
Searching didn't help much since so many threads have similar words but aren't what I'm looking for.
Chad
Not all quotes you see on the internet are genuine. -Abraham Lincoln
after first code is displayed stomp again 5 times and it will go to the next code(should there be one) and to clear codes you hold the pedal down for ten seconds.
OK cool, I'd never heard that you had to do that to go to the next one in any of the instructions. Thanks.
Chad
you have to do it (5 stomps for each code) until you get code just get 1000. I think the codes are alos in order (i.e. highest or lowest code # shown 1st).
e34 540i/6 :: e30 M62/6 :: e30 318is :: c5 Z06
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
+1 in all the writeups, and the Bentley for both the E36 & E34 I've never once seen it mentioned that you have to push 5 times for each code, or to get to the 1000 code. It was pissing me off that I couldn't get to the 1000 code to reset it cuz it just kept blinking the same thing over and over.
Thanks for the tip, guys.
Chad
Thanks! This was driving me crazy. NOWHERE does it say to do the stomp for each code.
hot damn this helps an awful lot
Gawd this is an old thread but I appreciate anyone's help with interpreting the codes. Does anyone have a link for a Bentley Manual in order to interpret the codes?
Here is a listing of the fault codes for our OBD E34's:
1211 DME Control Unit
1215 Air Mass Sensor
1216 Throttle Potentiometer
1218 Output Stage, Group 1
1219 Output Stage, Group 2
1221 Oxygen Sensor 1
1212 Oxygen Sensor 2
1222 Lambda Control 1
1213 Lambda Control 2
1223 Coolant Temperature Sensor
1224 Intake Air Temperature Sensor
1225 Knock Sensor 1
1226 Knock Sensor 2
1227 Knock Sensor 3
1228 Knock Sensor 4
1231 Battery Voltage/DME Main Relay
1232 Throttle Idle Switch
1233 Throttle Wide Open Throttle Switch
1234 Speedometer A Signal
1237 A/C Compressor Cut Off
1242 A/C Compressor
1243 Crankshaft Pulse Sensor
1244 Camshaft Sensor
1245 Intervention AEGS
1247 Ignition Secondary Monitor
1251 Fuel Injector 1 (or group 1 for DME 1.3, cylinders 1, 3, 5)
1252 Fuel Injector 2 (or group 2 for DME 1.3, cylinders 2, 4, 6)
1253 Fuel Injector 3
1254 Fuel Injector 4
1255 Fuel Injector 5
1256 Fuel Injector 6
1257 Fuel Injector 7
1258 Fuel Injector 8
1261 Fuel Pump Relay Control
1262 Idle Speed Actuator
1263 Purge Valve
1264 EGO Heater
1265 Fault Lamp (check engine light)
1266 VANOS
1267 Air Pump Relay Control
1271 Ignition Coil 1
1272 Ignition Coil 2
1273 Ignition Coil 3
1274 Ignition Coil 4
1275 Ignition Coil 5
1276 Ignition Coil 6
1277 Ignition Coil 7
1278 Ignition Coil 8
1281 Control Unit Memory Supply
1282 Fault Code Memory
1283 Fuel Injector Output Stage
1286 Knock Control Test Pulse
1444 No Fault Codes stored
1000 End of fault code output
Hope this helps
