Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1991 - 1999 (E36)
1991 - 1999 (E36) (1991 - 1999) The first modern 3 Series, the E36, was the model that paved the way for the 3 Series to be named "Car of the Year" every year since the model was driving off showroom floors. Radically redesigned in 1992, the E36 was not the same 3 Series as the E21 and E30. Larger, less boxy in design, and equipped with a dual overhead cam engine, multilink rear suspension, and a more finished interior, the E36 balances sport with luxury.
Old 11-13-2009, 01:51 AM
Engineer Joe Engineer Joe is offline
Cars: '98 328i
Lots of Smoke on Startup
My '98 328i has been a bit of a problem child since I got is 7 months ago, but I have most of the major items worked out. Once of the last items is that on startup (it takes several tries to get it going) it runs rough (vacuum leak) and smokes a lot. 1 minute later the smoke is gone but the rough running is still there. 3 minutes in it still runs a bit rough but not particularly bad.
I expect it has something to do with the oil seperator, but a friend suggested that it was related to the transmission modulator, which will leak a small amount of tranny fluid into the vacuum system and kill the pvc. I hope not.
Any ideas of good and easy tests to see what might be the source. I have a new PVC ready to go (I tried it but it buzzed so I put the old one back). I am hoping that the PVC by itself will do the trick, but I am a bit wary that I might be looking at a combo problem with something on the fuel side.
Any ideas?
Old 11-13-2009, 01:53 AM
PHARMDVIPER's Avatar
PHARMDVIPER PHARMDVIPER is offline
auto>manual swap crew
Cars: A black one
Send a message via AIM to PHARMDVIPER
what color is the smoke?
white=coolant/water
blue= oil
black= fuel
Old 11-13-2009, 01:54 AM
Cars: '98 328i
It seems a bit blueish but smells a bit of rich fuel.
Old 11-13-2009, 07:33 AM
BMWMPow3r BMWMPow3r is offline
Cars: bimmer
sounds like you may have leaky valve guides, headgasket, piston rings, fuel injectors, etc. not sure though, need more info.
Old 11-13-2009, 07:54 AM
r36vo's Avatar
r36vo r36vo is offline
Cars: E36 Individual 318is
Is there an aftermarket chip on ur car?
I have the same prob with my M42 engine with SuperChips, rich fuel startup, a bit smokey for 10 sec then everything goes fine.
WTB OEM FOGS + LEFT CLEAR CORNER LAMP
(Ship to Mauritius -_-)
Old 11-13-2009, 10:34 AM
fun2drive's Avatar
fun2drive fun2drive is offline
Cars: M-3 4dr/ 335 Convertible/M-3 Convertible
Do you mean ICV not PCV?
Sounds like a bad vacuum leak and possible CCV. Fix the vacuum leak is cheap if you do it yourself and stick a new CCV in if you think they are related which they could be as the CCV goes into your dip stick via a vacuum hose...
Old 11-13-2009, 12:55 PM
choffa choffa is offline
Cars: 1996 328is, 2004 Audi AllRoad 4.2
Not trans fluid, no modulator on these transmissions, all electronic. Sort out your vacuum leaks (check intake boot between mass air flow sensor & throttle body, common to have crack at that age), spark plugs, coil boots.
Old 11-13-2009, 09:01 PM
jmo69's Avatar
jmo69 jmo69 is offline
Cars: 1998 328is
Old rule of thumb, oil smoke on cold start usually means valve guides, on older GM and Ford engines you could put an umbrella shaped seal over the valve stem under the springs to restict the oil leaking down the stem. About the only good thing about push rod engines. lol
328 Mafia #7
1998 328is 5sp Cosmos schwarz Metalic CDV delete urethane LCAB
OEM Sachs replacement clutch tranny mounts and shifter bushings
Sparco strut brace ASC-T delete, blacked out tails and side markers smoked corners and fogs
Apexcone Ellipsoid w/6000K HID angel eyes/smoked Lamin-X Prosport gauges 35% tint all around DDM pedals
Old 11-14-2009, 03:57 PM
Cars: '98 328i
Thanks for all the suggestions. Sorry for not getting back to them earlier but my mom was in town.
I have had this problem (along with a few others for a while) even before I replaced the head gasket. I got a used but tested flat head (M50 actually) and had new guide seals put in, so I am sure it is not the valve guides. Also guides would smoke all the time, not just on startup.
As far as I know, no mod chip. Good to know no modulator, the idea of tranny fluid going into the intake was disturbing.
Idle control valve could be an issue, but I was thinking oil seperator as I though it would explain oil loss to the intake and vacuum leak. I see your point that maybe the ICV is too far open early on.
Since I need not worry about tranny fluid wasting a new oil seperator, I'll give it a try and hopefully that will narrow down the issues.
Thanks, for the help. I'll post what I find.
Old 11-23-2009, 01:06 AM
Cars: '98 328i
After installing the new CCV (which still buzzes) the symptoms of vacuum leak have cleared up, but the smoking problem persists, though it is a bit better. I am considering if it might be due to some type of leaky injector.
