| 1999 - 2005 (E46) (1999 - 2005) Starting in 1999 the E46 3 Series picked up where the E36 left off. Larger, with smoother lines, and with more advanced engines than its predecessor, the E46 easily held the title of "Best Car of the Year" throughout its life. |
Thread Tools |
'03 325xi tail light assembly
My question is about the connectors which are in the assembly to the wiring harness. Where can I obtain the harness and connectors? It appears the only problem is the turn signal connectors (tabs both male & female) are burned out. Oh, and if I appear to be unaware of current terminology please enlighten me. Help me out friends!
It's a fairly common repair, the dealer should have the electrical connectors. Unless it's super bad, you can usually re-use the plastic housing. You'll also need to add a ground wire to keep it from happening again. The ground wire gets extended from it's current position in the plastic housing, put a new electrical connector on it and connected to the lug on the tail light housing.
Any advice I may give here is - at best - tongue-in-cheek, and just as likely outright offensive. I've been doing this for a long time and I usually have a pretty good idea of that which I speak - but not always. So break out your grain of salt and try to keep up.
Is this the piece you need? Pc. 3 in the oem drawing below? The metal tabs are corroded? Please confirm. If so.....it's 35 bux at ECSTuning.com...
http://www.ecstuning.com/Search/63217165865/ES174649/ Be advised though....different part numbers for right and left sides.... ![]() ![]()
![]() 18" Enkei EKM3's w/Khumo ASX's ~ DDM Tuning Coilovers ~ Matte Black Kidneys ~ B&W Hood/Trunk Roundels ~ Smokes All Around With LED Eagle Eyes ~ Bavauto License Frames ~ M-Style Lip ~ Debadged ~ VANOS Rebuild-Done ~ GPS Mount Mod ~ Pillar Mod ~ Custom Trunk Interior~Colgan Nose Bra~Xenon Plate Bulbs~Custom Interior Trim By Feia0303
| Bookmarks |
| Thread Tools | |
