Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Tire & Wheel Forum sponsored by The Tire Rack
Tire & Wheel Forum sponsored by The Tire Rack Talk about tires and wheels/rims for your Bimmer with Jim from The Tire Rack.
Bimmerforums Upgrade Garage The Tire Rack
Old 11-12-2009, 01:10 AM
srinivas1729 srinivas1729 is offline
Cars: bmw 328i
Question Tire newbie questions
Hello friends
I swapped out the OEM summer bridgestone rft's on my 328i sport with Michelin Pilot A/S+ last week. The new tires feel much nicer and generate negligible tramlining.
I noticed that the tire sizes are listed as:
225/45ZR-17
255/40ZR-17
Can someone tell me what the "Z" stands for? I know what the other bits mean, but couldn't find what Z means online.
Also I wanted to confirm that I should inflate these to the same tire-pressure as my oem potenza's since they're the same size. The installer had them at 3-4 psi's over suggested limit. I wanted to check they hadn't done that because of the Z or anything.
thanks
Srinivas
Old 11-12-2009, 09:24 AM
DuWrk M3 DuWrk M3 is offline
Cars: E36 M3
The final letter stands for the amount of traveling speeds that the tire is capable of sustaining safely under optimal driving conditions. "The speed ratings are S for up to 112 mph, H for up to 130 mph, V for up to 150 mph, Z for 150 mph+. At high speeds, the tire can get very hot and the tread can separate from the belts. The speed ratings tell you how fast you can go and still be safe. Easy way to say it Z=go fast tires and still be safe
HTML code is On
